Timing type 4, 2.0 L dual dellorto 40’s w/ Petronix ignition
buzz cut hippie
buzz cut hippie is offline
PostPosted: Wed Jan 30, 2019 3:03 pm    Post subject: Timing type 4, 2.0 L dual dellorto 40’s w/ Petronix ignition Reply with quote
Not having luck finding timing information when I search on the forums. Tips or pointers on how to search? Links? And yes I know this question has probably been answered and discussed thousands of times on the Samba but I can’t seem to find those threads. Would like to set proper dynamic (and static) timing on my type 4, 2.0 L engine with dual 40’s dellortos. Thank you in advance to all responses!
skills@eurocarsplus
Samba Peckerhead
PostPosted: Wed Jan 30, 2019 3:36 pm    Post subject: Re: Timing type 4, 2.0 L dual dellorto 40’s w/ Petronix ignition Reply with quote
you want about 30-32* @ 3200 RPM, vacuum hose disconnected and plugged. where it falls at idle doesn't matter...unless you have to pass emissions testing
gprudenciop wrote:
[email protected] wrote:
Jake Raby wrote:
Brian wrote:
buzz cut hippie
PostPosted: Wed Jan 30, 2019 4:14 pm    Post subject: Re: Timing type 4, 2.0 L dual dellorto 40’s w/ Petronix ignition Reply with quote
Right on. Thank you. Curious about why the number 3200 rpm is used as the reference point to set dynamic timing? Is that the power point or responsive range of acceleration on the engine?
At a highway speed of 65 mph I believe my rpm is between 3500 to 3800 depending on conditions— wind, incline, cargo weight etc
buzz cut hippie
PostPosted: Wed Jan 30, 2019 4:17 pm    Post subject: Re: Timing type 4, 2.0 L dual dellorto 40’s w/ Petronix ignition Reply with quote
What should the static timing be set at?
SGKent Premium Member
SGKent is offline
PostPosted: Wed Jan 30, 2019 4:43 pm    Post subject: Re: Timing type 4, 2.0 L dual dellorto 40’s w/ Petronix ignition Reply with quote
Disconnect the vacuum advance hose then run the engine up to where the timing stops advancing. That is around 3200 RPM +. Then set the timing at 29 - 30 BTDC. You'll have power and the engine will run cooler than 32 BTDC. Make sure your timing scale is accurate. You don't time a VW engine statically except to start it the first time, and then you immediately set the timing. When you are done reconnect the vacuum advance and BE SURE it is connected to the ported vacuum meaning above the throttle plate. These instructions have been given some 45,000 times by 3500 different members here so I call BS on you couldn't find it.
buzz cut hippie
PostPosted: Wed Jan 30, 2019 5:10 pm    Post subject: Re: Timing type 4, 2.0 L dual dellorto 40’s w/ Petronix ignition Reply with quote
Thank you kindly for the accurate information. When you call “bs” on I couldn’t find it, are you saying that 45,000 other people had the same problem I did? Lol 😉
Wildthings
Wildthings is offline
PostPosted: Wed Jan 30, 2019 5:29 pm    Post subject: Re: Timing type 4, 2.0 L dual dellorto 40’s w/ Petronix ignition Reply with quote
Since SLC is 4000+ feet in elevation I would tend to use the slightly more advanced timing that Skills suggests, it is within book specs for sea level and should be just about right for your elevation.
In answer to your question about the timing to go with your carbs, timing doesn't vary much between various fuel systems, the ignition system makes no difference assuming the timing curve is the same. Pretty much you want your burn completed at around 11 degrees after top dead center no matter the make of the engine, fuel system, or cam. The fastest burn for the mixture is near stochiometric and as you lean out from there the burn slows which is part of the reason to have a vacuum advance setup. A richer mixture than stochiometric will be more stable and thus less prone to knock and to a point will put out more power than a stochiometric mixture.
buzz cut hippie
PostPosted: Wed Jan 30, 2019 6:34 pm    Post subject: Re: Timing type 4, 2.0 L dual dellorto 40’s w/ Petronix ignition Reply with quote
Wow very grateful for your fascinating and valuable information
SGKent is offline
PostPosted: Wed Jan 30, 2019 7:52 pm    Post subject: Re: Timing type 4, 2.0 L dual dellorto 40’s w/ Petronix ignition Reply with quote
yes Smile
KentABQ Premium Member
KentABQ is offline
PostPosted: Wed Jan 30, 2019 10:00 pm    Post subject: Re: Timing type 4, 2.0 L dual dellorto 40’s w/ Petronix ignition Reply with quote
yes Smile
My turn to call bs on you, Steve...
I only found 858 threads when doing a search of titles with "timing" in it. Razz
-Kent-
1976 Riviera, 1.8l FI chrome yellow VAN - "Chloe"
"I must say, how can you be in a bad mood driving this vehicle full of vibrant color.
Cars of today are so bland in comparison. It's like driving a celebration!"
---WildIdea
Bus ownership via emoticons:
Very Happy Shocked Mad Sad Embarassed d'oh! Pray Brick wall Pray Dancing Dancing Dancing ---williamM
SGKent is offline
PostPosted: Wed Jan 30, 2019 10:11 pm    Post subject: Re: Timing type 4, 2.0 L dual dellorto 40’s w/ Petronix ignition Reply with quote
yes Smile
search harder Smile
KentABQ is offline
PostPosted: Wed Jan 30, 2019 10:27 pm    Post subject: Re: Timing type 4, 2.0 L dual dellorto 40’s w/ Petronix ignition Reply with quote
SGKent wrote:
yes Smile
search harder Smile
Yeah, you're probably right. Those timing numbers are shown in a ton of other threads too.
Maybe timing stats should be in TCash's "welcome" message, along with the 9 ft-lb max torque warning...
I still miss TCash.
-Kent-
---WildIdea
alman72
alman72 is offline
PostPosted: Thu Jan 31, 2019 7:28 am    Post subject: Re: Timing type 4, 2.0 L dual dellorto 40’s w/ Petronix ignition Reply with quote
me too. that guy was the bomb. at least his threads of knowledge still exist to help others.
CarlosZ
CarlosZ is offline
PostPosted: Sat Jan 04, 2020 10:46 am    Post subject: Re: Timing type 4, 2.0 L dual dellorto 40’s w/ Petronix ignition Reply with quote
Happy new year everyone. Am I supposed to A)plug the vacuum port on the carb while leaving the distributor end open or B)Leave both ends unplugged while timing an svda with 40 IDFs? I’m assuming (A) but it’s been described so many different ways and lingo varies a bit.
SkillS states “disconnected and plugged” while SGKent says “disconnect the vacuum hose”
Don’t meant to beat a dead horse with a stick but I’ve always wondered if I did it correctly. Thanks!
Type 4
SVDA
40IDFs
Petronix
busdaddy
busdaddy is offline
PostPosted: Sat Jan 04, 2020 10:55 am    Post subject: Re: Timing type 4, 2.0 L dual dellorto 40’s w/ Petronix ignition Reply with quote
On models with advance only there's usually no need to plug anything, plugging is required on a retard line (carb end) because it causes a huge vacuum leak and won't idle correctly (or at all).
IDF's should idle fine with the hose disconnected and left open since they shouldn't start making vacuum until you open the throttle, by that time a small leak doesn't effect anything that concerns you for just setting the timing.
If you do notice a change when you pull off the hose you should confirm your throttle plates are closing fully before proceeding further, that's going to cause problems if you leave it alone.
Слава Україні!
TomWesty
TomWesty is offline
PostPosted: Sat Jan 04, 2020 10:56 am    Post subject: Re: Timing type 4, 2.0 L dual dellorto 40’s w/ Petronix ignition Reply with quote
Plug the carb port so no vacuum leaks. Distributor end open so no vacuum signal to distributor.
