kgj Samba Member
Joined: February 25, 2013 Posts: 424 Location: Uk, Cornwall
Posted: Tue Feb 05, 2019 1:45 pm Post subject: Rocker drain holes |
Help needed.
How many drain holes should be in the rockers and where?
My car is in the paint shop.
I haven’t done a final inspection before topcoat but will tomorrow. I just want to be sure any haven’t been lost in the primer filler stage. I’ve had a look at my own photos but omitted to record this detail completely.
What I do know is the lower front fender has 3 drain holes.
The centre section has 2 holes. One either end close to the seam.
I am however a bit sketchy about the rear section.
Here is a photo from my archives of my previous car with my guess as to how many drain holes there should be and where.
Then I saw this photo in the gallery. I hope the owner doesn’t mind. It does show my first 4 hole guesses seem to be correct....
But what happens as we work rearward?
Help! Please...
Thanks for looking. _________________ 1958 coupe |
c21darrel Samba Member
Joined: January 22, 2009 Posts: 8241 Location: San Dimas
Mellow Yellow 74 Samba Member
Joined: October 14, 2014 Posts: 1615 Location: Sydney, Australia
Posted: Tue Feb 05, 2019 5:39 pm Post subject: Re: Rocker drain holes |
The NOS rear quarter for my 62 has drain holes near the cutout for the jacking point as follows:
-80mm behind the rear of the jack cutout
-50mm in front of the front of the jack cutout
-150mm in front of the front of the jack cutout
My repro repair panel for the other side has vent slots (not holes) that line up with these but the flange on the bottom is longer toward the rear so make sure you measure from the jack cutout. I will need to shrink these drain slots and drill holes to match the other side and trim the flange.
My repro panels for the front repair sections don't have any drain holes so please advise details on here when you find out. _________________ 1962 Karmann Ghia
1974 Deluxe Microbus
1985 Caravelle (Vanagon) |
sputnick60 Samba Moderator
Joined: July 22, 2007 Posts: 4151 Location: In Molinya Orbit
kgj Samba Member
Posted: Wed Feb 06, 2019 12:55 am Post subject: Re: Rocker drain holes |
Thanks guys. That’s awesome. Measurements as well!
And may be of use if someone else searches this topic.
Best regards. _________________ 1958 coupe |
Posted: Wed Feb 06, 2019 3:27 am Post subject: Re: Rocker drain holes |
Just in case you don't have these, there is also a drain hole in the rear quarter behind the wheel to drain the wheel well in the side of the engine bay and a drain hole in the bottom of the spare wheel well at the front. _________________ 1962 Karmann Ghia
tommu  Samba Member
Posted: Wed Feb 06, 2019 10:22 pm Post subject: Re: Rocker drain holes |
We're going to need to see some photos when it's done! _________________
