junkyard efi
Page: 1, 2, 3  Next
WReel
WReel is offline
PostPosted: Mon Feb 18, 2019 11:28 pm    Post subject: junkyard efi Reply with quote
I assume that someone here has already done this or can point me in the right direction.
In the past I was considering doing a junkyard efi conversion using an s10 as the donor vehichle for an amc eagle I had a few years ago, never actually did it but read enough to understand the basics of it.
Now I'm looking to get a little more power out of my motor and was thinking of doing this to my 1600 dp. What would be the best donor for this ? A 4cyl gm or does it really matter as long as the vehichle doesn't have a chipped ignition? "Because of the anti theft system"
Looking for any helpful info. Thanks in advance
UK Luke 72
UK Luke 72 is offline
PostPosted: Tue Feb 19, 2019 3:13 am    Post subject: Re: junkyard efi Reply with quote
There's plenty of parts that can be repurposed for your beetle but engine management wise you're creating a whole wrath of complexity by not using a standalone ECU. Check out the megasquirt subforum on Shoptalkforum.
2276 Beetle build https://www.thesamba.com/vw/forum/viewtopic.php?t=670744&highlight=2276+beetle+daily
2276 EFI Conversion https://www.thesamba.com/vw/forum/viewtopic.php?t=689172
oprn
oprn is offline
PostPosted: Tue Feb 19, 2019 5:30 am    Post subject: Re: junkyard efi Reply with quote
I have been wondering the same thing. Is it because of a lack of software to access the factory EFI to make changes?
Dale M.
Dale M. is offline
PostPosted: Tue Feb 19, 2019 8:11 am    Post subject: Re: junkyard efi Reply with quote
You are are trying to stuff 10 pounds of apples into a 5 pound bag if you are trying to use a junkyard ECM.... Sure you can fab up a lot of hardware (tb and censors and manifolds and injectors) but when getting into controlling all that there is a lot more precision involved..... Trying to get into a "factory" ECM is a bitch and it usually wants a whole lot in inputs from "body" functions that you either have to remove (re-configure) from ECM or build in hardware garbage to satisfy the ECM ... Do you know how to cheat the clutch pedal depressed for start or trans in neutral or door open or dome light on or about 50 other things the ECM thinks has to be a certain way just to start up?
We did this on a 3.5 liter Ford motor and tried to adapt the dedicated ECM and harness to get it work in a 46 Ford convertible, and it was a bitch, wasted to many hours and to many brain cells ... All I could say to buddy was you should put a carburetor or MS on it...
Spend many hours just trying to fake ECM into thinking it was ok... But there was a slew of trouble codes that had to be dealt with before it would even start.... Plug and play (aftermarket) is actually best....
Dale
Krochus
Krochus is offline
PostPosted: Tue Feb 19, 2019 8:19 am    Post subject: Re: junkyard efi Reply with quote
You can use all sorts of junkyard parts to fuel inject an engine
Just not the ECM. Which is no different than swapping on a junkyard carb from a completely different engine that you cannot rejet and expecting it to work good.
An aftermarket ECM can be as little as $250 and will be money well spent
1970 Turbo Baja Bug Turbaja 2165 t3/t4 Speeduino sequential EFI LS3 coil on plug ignition
1965 Chevy c30, Microsquirt turbo aluminum 5.3/nv4500
oprn
oprn is offline
PostPosted: Wed Feb 20, 2019 6:06 pm    Post subject: Re: junkyard efi Reply with quote
So I am to understand then that all OEM ECMs are untunable? even the older ones without all the interlinking to everything conceivable?
I am thinking specifically of the early '8o's Porsche 944 system.
Krochus
Krochus is offline
PostPosted: Wed Feb 20, 2019 6:28 pm    Post subject: Re: junkyard efi Reply with quote
Some can be tuned. If you had the software and can burn EPROM chips which requires obsolete and highly specialized equipment.
Those old jetronic systems were horrible. You would be better off with a GM TBI setup than you would with one of those. Either way this is neither the cheap nor the easy way of doing this just buy an aftermarket computer.
You could probably use a late model GM computer. But I think a software license for hp tuners to do so yourself is like a grand!
Dale M.
Dale M. is offline
PostPosted: Wed Feb 20, 2019 7:44 pm    Post subject: Re: junkyard efi Reply with quote
Think of OEM systems as password protected.... If you don't have password you are not going to get in, once in where are you going to go, do you have road map.......
With MS and other aftermarket its all there as close as your cell phone, or tablet or laptop and all you need is "Tuner Studio" or aftermarket producers tuner app....... And oh.....NO password... And no obnoxious unimportant things to remove/defeat....
Dale
oprn
oprn is offline
PostPosted: Wed Feb 20, 2019 9:49 pm    Post subject: Re: junkyard efi Reply with quote
As horrible as they are we have 3 of them in the yard here that I have yet to put a dime into one of which I have owned for 10 years now. But I get what you are saying about access to changing the programming.
modok
modok is offline
PostPosted: Wed Feb 20, 2019 10:08 pm    Post subject: Re: junkyard efi Reply with quote
Computers come in a wide variety of flavors.
I've been amazed at the diversity. some are very stupid and crude, others quite sophisticated, some good, some bad. Some well known, others obscure.
For instance a early 90's mustangs had a darn good computer, even though the engine itself was a dinosaur, compared to the same era mazda mx5 is mechanically cutting edge, but it's computer is dumber than a toaster. other models of ford had the ignition modules integrated..god help them, and you'd THINK they'd all be the same!! not at all.
Hondas ruled that era. The honda compters are quite good. I don't know about a 4cyl s-10, might be in the category of tragically obscure, along with it's engine, (which was pretty good IMO).
petrol punk
petrol punk is offline
PostPosted: Thu Feb 21, 2019 12:24 am    Post subject: Re: junkyard efi Reply with quote
What's to stop someone from using a chipped Honda ECU? Seems like all the EF/EG/EK Honda guys run a chipped OEM ECU, regardless if its 200hp N/A B16 or a 600hp turbo D16. There's always at least 2 dozen D or B series Hondas in the local junkyard in OBD0, OBD1, and OBD2 flavors.
36hp '56 European DeLuxe oval
'70 bug 1835cc
WReel
WReel is offline
PostPosted: Thu Feb 21, 2019 2:44 am    Post subject: Re: junkyard efi Reply with quote
I had figured trying to use a smaller 4 cylinder similar to the 1600 would work. "Honda / possibly Toyota from the mid 80s" I should be able to supply the ecu with all sensors aside from coolant temp. I'm not sure what effect that will have.
The next time I'm at the junkyard I'll see if I can't find something. Does anyone know of any 4 cylinder tbi cars?
Also was wondering if anyone has any experience with speeduino?
-Alex77-
-Alex77- is offline
PostPosted: Thu Feb 21, 2019 3:00 am    Post subject: Re: junkyard efi Reply with quote
If you want to go cheap but tunable ECU, go with megasquirt. Kits start at 197 dollars:
https://www.diyautotune.com/product/megasquirt-i-programmable-efi-system-pcb2-2-kit-w-black-case/
https://www.diyautotune.com/product/megasquirt-i-programmable-efi-system-pcb3-0-kit-w-black-case/
Lasercut parts and CAD design
karu
karu is offline
PostPosted: Thu Feb 21, 2019 4:23 am    Post subject: Re: junkyard efi Reply with quote
If you want to go even cheaper, check out
https://speeduino.com/wiki/index.php/Speeduino
About 100+. I have not used it but this is what I plan to use some time later.
slalombuggy
slalombuggy is offline
PostPosted: Thu Feb 21, 2019 5:24 am    Post subject: Re: junkyard efi Reply with quote
Finding injection parts for mid 80s, early 90s cars is going to be a crapshoot of frustration. Crappy systems to start with and no one is making replacement parts for them any more. The only tbi 4 banger I remember is the one in Dodge Omnis and it was sketchy at best.
And in most efi systems. Coolant temp is king, so you need to figure out that input or you'll never have a functioning system.
brad
oprn
oprn is offline
PostPosted: Thu Feb 21, 2019 5:38 am    Post subject: Re: junkyard efi Reply with quote
I am not thinking of going FI on my present project anytime soon but I do have 2 parts cars with it on and it seems a shame to junk them and go buy a different system for a future project.
Dale M.
Dale M. is offline
PostPosted: Thu Feb 21, 2019 9:25 am    Post subject: Re: junkyard efi Reply with quote
Believe there is company out there that buys old ECU/ECM's and refurbished them to sell as replacements.... Might scout I-net to see if so, if so you might get a few dollar but not enough for a happy meal....
But its like a lot of things today, old technology just has no place in to day realms no matter how much it cost in the beginning....
Dale
mcmscott
mcmscott is offline
PostPosted: Thu Feb 21, 2019 10:38 am    Post subject: Re: junkyard efi Reply with quote
Gotta love the samba,, full of people who believe if they can't do something it can't be done.
I have a customer that used the ecu from an ecotek. Got the software on line to tune it, and it runs awsome. For even less than m/s.
There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250
Max Welton
Max Welton is offline
PostPosted: Thu Feb 21, 2019 11:51 am    Post subject: Re: junkyard efi Reply with quote
I take the view that if I can do it, anyone can do it.
Max
1967 Type-3 Fastback
slalombuggy
PostPosted: Thu Feb 21, 2019 12:09 pm    Post subject: Re: junkyard efi Reply with quote
Yup, but an ecotech is 30 year new technology than mid 80s. I'm no it saying it can't be done, but you're not gaining anything trying to use 30 year old technology that no one supports any more and was pure crap compared to today.And most small Japanese cars ran carbs until the late 80s.
A buddy just did an ecotech swap in his Baja last year. Getting the stand alone reworked GM ECU and new harness was dirt cheap. Hooked up 3 wires and turned the key.
brad
Page: 1, 2, 3  Next
