tjet Samba Member
Posted: Mon Mar 11, 2019 9:25 pm Post subject: Questions on Kennedy CARB approved (California) Subaru EJ22 kit |
I have some questions on the California smog legal Kennedy kit using a Subaru Legacy 2.2L engine and emission parts to replace the factory Vanagon engine. It specifically calls out for a '90-'94 OBD I EJ22. Is there a code on this engine which identifies the year (cast, stamped, or decal) that the smog certifier would look for? The reason I'm asking this is because I bought a '95 EJ22 engine, which is the first year for OBD II & not correct for the KEP kit. It's complete minus the engine harness. Can I install a '90-'94 harness on this '95 engine and keep it CARB compliant? Are the sensors OBD I or II specific? Lastly, is there any other small differences on the '95 EJ22 vs the '90-'94 EJ22 I should be aware of? From what I can find online, it looks like the EJ22 engines between 1990 to 1996 are all the same except for '95 & '96 being OBD2.
I plan on purchasing the Kennedy kit & registering my '87 Syncro in CA.
Thanks.
Here's the excerpt & link below:
The California Air Resources Board Issued us an Executive Order allowing the installation of the ’90 – ’94 dual port Subaru 2.2 engine into the 1980 – 1991 Volkswagen Vanagons. It requires that the Subaru engine be used complete, from its air flow meter to its O2 sensor (except for exhaust manifold piping and optional section of the intake air duct.) The Subaru ECU and wiring are retained, but modified per KEP instructions. A check engine light must be installed on the dash. The Vanagon charcoal canister is retained. The CARB Executive order refers to a complete kit, and is to be sold this way, not as individual components. Kits will include copies of the Executive Order and a self-adhesive label to be attached to the body in the engine compartment. Individual pricing of the parts is available for out of state applications as well as for customers wanting them for use on other model or year Volkswagens that do not need to be CARB compliant. The Executive Order does not cover 1979 and earlier vans, the air inlet duct interferes with the gasoline tank on these vehicles.
https://www.kennedyeng.com/subaru-vanagon
AZ Landshaper Samba Member
Joined: February 08, 2009 Posts: 1706 Location: The Old Pueblo
Posted: Tue Mar 12, 2019 5:04 am Post subject: Re: Questions on Kennedy CARB approved (California) Subaru EJ22 kit |
Seems to be the same engine w some added smog stuff. I’m sure there’s a code difference stamped into the case but it’s very hard to see below the plenum and wiring harness etc.there does appear to be a few differences that one in the know would be able to ID w/o any problems or inconvenience esp w one of those border patrol search mirrors _________________ Support Small Business.
85 Weekender w/ EJ22
Previously
64, 71, 72, 73, 76, 81, 84, 85 & 87 Campmobiles and Westfalias
and a 67 bug. |
Joined: April 29, 2015 Posts: 704 Location: Berkeley Ca
Posted: Tue Mar 12, 2019 5:43 am Post subject: Re: Questions on Kennedy CARB approved (California) Subaru EJ22 kit |
I think you will need to swap out a few things. There are some groups on Facebook that you will need to access. Let me know if you need the links. Also the Yahoo group. I would think you are best off if possible to get a 94 and under with ecu and harness. Like find a beater for $500. |
markswagen Samba Member
Joined: January 28, 2018 Posts: 1555 Location: san diego
Posted: Tue Mar 12, 2019 6:41 am Post subject: Re: Questions on Kennedy CARB approved (California) Subaru EJ22 kit |
Good luck finding a cheap beater, not down here at least, you may have better luck north of LA, I search at least twice a day every day looking for donors, there are a few in Portland right now.
Last one down here was $1500, there was one before Christmas at $650, when I spoke to the guy, someone had PayPal'd him a deposit, for collection a month later, it went to oceanside, and into an early Bay, that didn't need to pass smog anyway
[email protected] wrote: |
_________________ markswagen {mobile mechanic} san diego area all early VW's cared for.
619 201 0310 |
joetiger  Samba Member
Joined: January 27, 2005 Posts: 5266 Location: denver
Posted: Tue Mar 12, 2019 7:07 am Post subject: Re: Questions on Kennedy CARB approved (California) Subaru EJ22 kit |
markswagen wrote: |
Last one down here was $1500, there was one before Christmas at $650, when I spoke to the guy, someone had PayPal'd him a deposit, for collection a month later, it went to oceanside, and into an early Bay, that didn't need to pass smog anyway  |
I paid $250 for a 90k mile '91 EJ22 and harness, pulled and ready for pickup. But that was back in 2006. I love that motor and consider swapping one into my Syncro if I couldn't get the ABA running right.
Maybe try car-part.com? There are a bunch of EJ22 motors listed in CA. Here's a small sample:
1990
Engine Assembly
Subaru Legacy 90 LEGACY 2.2 ENGINE 42384 $550 Shamrock Auto Salvage USA-CA(Ridgecrest) Request_Quote 760-446-5865
Engine Assembly
Subaru Legacy (2.2L, VIN '6' 6th digit), w/o turbo- 307,000 C A0013 $550 Shamrock Auto Salvage USA-CA(Ridgecrest) Request_Quote 760-446-5865
1992
Engine Assembly
Subaru Legacy 92 LEGACY 2.2L ENGINE w/o turbo 232,000 C A227 $550 Shamrock Auto Salvage USA-CA(Ridgecrest) Request_Quote 760-446-5865
1991
Engine Assembly
Subaru Legacy (312S-A) 19180 $650 Standard Auto Recycling USA-CA(Chula-Vista) Request_Quote 619-426-9476
1993
Engine Assembly
Subaru Legacy 2.2 MT(O3A2S) 29772 $650 Standard Auto Recycling USA-CA(Chula-Vista) Request_Quote 619-426-9476 _________________ Joe T.
'02 Baja-ish Beetle "Bubbles"
Justice for Megan: https://linktr.ee/justiceformegantrussell |
Posted: Tue Mar 12, 2019 7:20 am Post subject: Re: Questions on Kennedy CARB approved (California) Subaru EJ22 kit |
Finding an engine is MUCH easier than the harness, I'm not brave enough to trust that someone has pulled the entire harness without damaging it, not on my $ anyway, I have 3 customers who want conversions doing, shelling out $ on their behalf, and finding I now own an almost complete rats nest wouldn't be good for my bank balance.
joetiger wrote: |
1990
Engine Assembly
Engine Assembly
1992
Engine Assembly
1991
Engine Assembly
1993
Engine Assembly
Subaru Legacy 2.2 MT(O3A2S) 29772 $650 Standard Auto Recycling USA-CA(Chula-Vista) Request_Quote 619-426-9476 |
619 201 0310 |
Posted: Tue Mar 12, 2019 7:26 am Post subject: Re: Questions on Kennedy CARB approved (California) Subaru EJ22 kit |
markswagen wrote: |
Agreed! Just offering a possible alternative. On mine, the harness went right through my hands, into a box, and off to Tom Shiels. There were a couple of areas that were cut and shouldn't have been which he repaired as part of the service. _________________ Joe T.
Posted: Tue Mar 12, 2019 7:31 am Post subject: Re: Questions on Kennedy CARB approved (California) Subaru EJ22 kit |
I would be the samee, sending them out to Jeff, but I feel it would not be cool to send him most of a harness, and expect a complete harness to be returned.
Thank you for your input, I will be looking in on a couple of the engines you suggested.
Biggest problem, after the smog, is the conversion shops locally, I think they have people go look around the breakers yards here, and get when ever they find, I've NEVER found one intact here
joetiger wrote: |
Agreed! Just offering a possible alternative. On mine, the harness went right through my hands, into a box, and off to Tom Shiels. There were a couple of areas that were cut and shouldn't have been which he repaired as part of the service. |
619 201 0310 |
Posted: Tue Mar 12, 2019 7:35 am Post subject: Re: Questions on Kennedy CARB approved (California) Subaru EJ22 kit |
markswagen wrote: |
Biggest problem, after the smog, is the conversion shops locally, I think they have people go look around the breakers yards here, and get when ever they find, I've NEVER found one intact here |
I just grabbed a few random ones from Car-part.com. It's an oft-overlooked source for parts by our community, it seems. I've actually scored some hard-to-find Vanagon bits there.
This is one of those rare cases where I think Colorado is actually a better source for car parts than California. Subarus everywhere. _________________ Joe T.
Posted: Tue Mar 12, 2019 8:02 am Post subject: Re: Questions on Kennedy CARB approved (California) Subaru EJ22 kit |
joetiger wrote: |
markswagen wrote: |
This is one of those rare cases where I think Colorado is actually a better source for car parts than California. Subarus everywhere. |
Agreed also Washington and Oregon. You want a rust bucket or rearender or blown transmission vehicle. |
Posted: Tue Mar 12, 2019 2:01 pm Post subject: Re: Questions on Kennedy CARB approved (California) Subaru EJ22 kit |
Keep your eyes peeled.
I just bought a 2001 Forester w a bad tranny. 145k on the motor with new head gaskets as of 2012. $1300 but thats worth the headache of not doing the gaskets and timing belt anytime soon. Now if I could only find a broken down westy. _________________ Support Small Business.
Previously
and a 67 bug. |
tjet Samba Member
Posted: Tue Mar 12, 2019 3:15 pm Post subject: Re: Questions on Kennedy CARB approved (California) Subaru EJ22 kit |
AZ Landshaper wrote: |
Seems to be the same engine w some added smog stuff. I’m sure there’s a code difference stamped into the case but it’s very hard to see below the plenum and wiring harness etc.there does appear to be a few differences that one in the know would be able to ID w/o any problems or inconvenience esp w one of those border patrol search mirrors |
Thanks. I did find the vin stamped into the right rear side. EJ22 is cast in on the top.
Yeah send me the yahoo link. I dont have a facebook acct though.
markswagen wrote: |
Last one down here was $1500...( |
I see the prices are higher in the SW. I had to grab this motor as it was only $250.
markswagen wrote: |
Finding an engine is MUCH easier than the harness, I'm not brave enough to trust that someone has pulled the entire harness without damaging it, not on my $ anyway, I have 3 customers who want conversions doing, shelling out $ on their behalf, and finding I now own an almost complete rats nest wouldn't be good for my bank balance. |
Thats good to know. I'm gonna hit the junkyards for a harness when it starts warming up.
joetiger wrote: |
...On mine, the harness went right through my hands, into a box, and off to Tom Shiels. There were a couple of areas that were cut and shouldn't have been which he repaired as part of the service. |
Do you have any pics of that harness? Did he thin it down by removing unnecessary wires?
FYI, I pick the motor up tomorrow. |
termuehlen  Samba Member
Joined: May 02, 2012 Posts: 1033 Location: Redwood City
Posted: Tue Mar 12, 2019 7:54 pm Post subject: Re: Questions on Kennedy CARB approved (California) Subaru EJ22 kit |
If you ever end up going to see a California smog ref, they will want to know your VIN number of the donor vehicle, so they can check the smog equipment that it is supposed to have. If your vin number is not the correct year, this will be a problem. Plenty of people here have a Kennedy conversion and have never visited a ref, so this may be a moot point. But times do change and California smog will continue to change, as well. _________________ 1988 Westfalia automatic Subaru OBD1
1986 syncro tintop wbx |
Posted: Wed Mar 13, 2019 5:56 am Post subject: Re: Questions on Kennedy CARB approved (California) Subaru EJ22 kit |
Get all info on engine year model vin ect. Jeff might have a spare wire loom for you. |
tjet Samba Member
Posted: Wed Mar 13, 2019 10:18 am Post subject: Re: Questions on Kennedy CARB approved (California) Subaru EJ22 kit |
Got it noticeably lighter and smaller than wbx.
Posted: Wed Mar 13, 2019 10:59 am Post subject: Re: Questions on Kennedy CARB approved (California) Subaru EJ22 kit |
Boom boom boom let the fun begin |
Posted: Wed Mar 13, 2019 11:40 am Post subject: Re: Questions on Kennedy CARB approved (California) Subaru EJ22 kit |
Congratulations! _________________ Joe T.
Posted: Tue Apr 23, 2019 8:04 am Post subject: Re: Questions on Kennedy CARB approved (California) Subaru EJ22 kit |
They go REALLY quickly if and when he gets them, I have been asking him for an OBD1 loom for a while, I thought I'd gotten lucky, a week or so back, but it fell though.
I did get lucky yesterday, and now have an OBD1 loom, which will be winging it's way to Jeff, I'm still on the lookout, as I have 2 possibly 3 customers who want to go this route.
619 201 0310 |
