jeffrey8164 Samba Member
Joined: January 06, 2018 Posts: 3823 Location: Georgia
Posted: Sat Jan 26, 2019 5:08 pm Post subject: Re: Ghia coming home |
That’s Feather Pluckin Insane!
Now the real fun can begin. _________________ Volkswagen!
(Compression 8.7:1) |
Evil_Fiz Samba Member
Joined: May 06, 2011 Posts: 1049 Location: Jacksonville, FL
Posted: Sun Jan 27, 2019 9:04 am Post subject: Re: Ghia coming home |
...Are you going to send a bill to Coolrydes for the improvements and additional engineering?
Nice work, you have clearly dialed this one up to "11."
Emil _________________ “…It's not just about what's interesting. It's also about what's helpful, and it's helpful even if it helps just one other guy working on a Ghia.”
kiwighia68
See my build on TheSamba at:
The K_R_A_K_E_N_N : a 70 Ghia Convertible reinterpreted |
KGCoupe Samba Member
Joined: July 01, 2005 Posts: 3580 Location: Putting the "ill" and "annoy" in Illinois
Posted: Sun Jan 27, 2019 10:04 am Post subject: Re: Ghia coming home |
With that kind of obvious skill level and effort, I expect to see you adapt a Subaru EyeSight System so that it will detect any upoming speed bumps/potholes in your path and automatically adjust your suspension height accordingly.
Keep up the great work, and thanks for taking the time to share your progress with us here.
I refreshed my memory of your project by going back and reading this thread from the beginning.
Now I'm no longer surprised by the amount of effort you seem to be willing to put into this project, nor by your skill level!
Your 2nd post held these clues of what was to come ...
halbug wrote: |
I really like to hide the performance potential. Good examples of what I mean are the shifter knob or the two main gauges: The speedo is an original 140 km/h unit that is recalibrated to show miles/hour with the km/h reading somewhat hidden in an inner ring. So it will show me speeds up to 140 m/h.
The tach face used to be an original time clock, the housing an old speedo, now fitted with an AutoMeter tach. 12 o’clock is neutral, 1 is 1000 rpm, 2 is 2000 … The minute hand is fitted with a counter weight and then repainted in matching color. The hour hand is adjustable from the outside.
Incredible level of attention to detail - Simply gorgeous work!
(I had to look very close to find the kph markings that you so cleverly hid in plain sight. ) |
halbug Samba Member
halbug Samba Member
halbug Samba Member
Posted: Sun Mar 31, 2019 8:41 am Post subject: Re: Ghia coming home |
The steering rack in place - with wooden brackets for try out:
The final brackets are being machined from aluminum right now. The idea of using the original steering column hole seems to be working - at least with my cardboard mock-up
I will have to place a bearing into the assembly, because I am using three joints. I will get back to this once the body is on the pan, because the mock-up is not exact enough to fabricate the bearing holder at this time.
But I am glad that everything looks like it is working all right
Cheers
Lars _________________ Stealth Ghia Transformation: http://www.thesamba.com/vw/forum/viewtopic.php?p=7226044&highlight=#7226044
My Berg5: https://www.thesamba.com/vw/forum/viewtopic.php?t=730276&start=0 |
Posted: Sun Mar 31, 2019 6:15 pm Post subject: Re: Ghia coming home |
Yeah Man. That's tedium right there.
Quite the feat. Kudos on the mock up. _________________ Volkswagen!
halbug Samba Member
Posted: Sun Apr 07, 2019 7:38 am Post subject: Re: Ghia coming home |
halbug wrote: |
Thanks Jeffrey!
All - guess what's next?
Cheers
Lars |
Those seats have a very cool retro 50s Sports Car look to them, ... and they look as though they'd be pretty comfortable and supportive as well.
IMO, they are an absolutely perfect choice for the direction you've taken with your Karmann Ghia. and I can't wait to see the completed project.
Are they genuinely vintage, or new reproduction seats?
What can you tell us about them? |
halbug Samba Member
Posted: Mon Apr 08, 2019 7:37 am Post subject: Re: Ghia coming home |
Thank you for the info and link, halbug - much appreciated.
One quesion for you, though - do you plan to compensate in some way for the fact that those seat backs are fixed and can not fold forward to make for easier entry to/exit from the back seat area?
I suppose if the seat tracks will allow the seat to travel far enough forward, then the seat back would not really need to fold.
Seeing how you've proceeded with both your Beetle in the past and the Karmann Ghia project thus far, though, I'd imagine you probably have some sort of custom fabricated mounting already planned out which will solve the problem in an elegant and creative manner.
For example, perhaps a way to allow pivoting at the front edge so that the entire seat can be raised up and tilted forward? |
halbug Samba Member
Gwarballs Samba Member
Joined: October 27, 2015 Posts: 26 Location: Zagreb Croatia
Posted: Tue Apr 09, 2019 3:20 am Post subject: Re: Ghia coming home |
halbug wrote: |
Thanks Jeffrey!
Cheers
Lars |
what seats are these? cobra? I've been looking into seats, but I'm a bit of a stocky guy. im 172cm and 110 kilos. so im a bit worried on pulling the trigger on seats with the fear that they will be too narrow. and chance i can get measurements of those seats and where you got them |
TRS63 Samba Member
Joined: December 17, 2017 Posts: 1001 Location: Stuttgart - Germany
Posted: Tue Apr 09, 2019 7:15 am Post subject: Re: Ghia coming home |
Gwarballs wrote: |
halbug wrote: |
Thanks Jeffrey!
Cheers
Lars |
Looking at the Cobra Seats website, it appears that the Roadster style seat is available in three different variations - Roadster SS, Roadster SR, and Roadster XL/XL+.
This is the info for the Roadster XL/XL+ ...
CobraSeats.com wrote: |
Roadster XL/XL+
The Roadster XL contains all of the design features of the Roadster SR, but offers more generous seating, while the Roadster XL+ can accommodate a larger driver still.
FEATURES
Classic/period fixed back sports seat
Traditional styling with modern construction
Tubular steel frame with base suspension diaphragm
Wider hip area for increased comfort
Heavy duty standard vinyl upholstery in black or grey
Extensive vinyl and leather Signature options
halbug Samba Member
Posted: Tue Apr 09, 2019 12:50 pm Post subject: Re: Ghia coming home |
TRS63 wrote: |
I really like the seats, will be following with interest how you arrange the tracks!
The tachometer in the clock is really brilliant, do you have any more details on what you used, how you did, etc..? I would love it in mine!
Thanks
Antoine |
Antoine - First I bought an Autometer tach with 30 deg increments. I used the hands and the clock face from a broken Ghia time clock. An old speedometer had to doner its housing. I opened up the speedometer housing for the tach hausing to fit into it from the rear. I adjusted the depth of the tach, so that the Ghia face, now mounted to the tach, would reside at its original depth. Cut the tach housing to match the speedo housing and welded the two together. I used an insolating material to create the electric connectors and used it to cover the remaining opening from the original fuel clock. I made two adapters on a lathe, to match a) the long hands to the tach and b) the short one to the adjuster from the time clock's glass. The large hand's short end was filled with solder to weight balance both ends Correct hand color was mixed and the two hands re-painted - DONE _________________ Stealth Ghia Transformation: http://www.thesamba.com/vw/forum/viewtopic.php?p=7226044&highlight=#7226044
halbug Samba Member
Posted: Tue Apr 09, 2019 12:55 pm Post subject: Re: Ghia coming home |
Gwarballs wrote: |
halbug wrote: |
Thanks Jeffrey!
Cheers
Lars |
I use Roadster XL. If you have a chance try them at a dealer, to sit in one because they really make them from narrow to wide for your own taste and fit. I bought mine from Bodo Schlaeper @ https://www.cobrasitz24.de/impressum/ he is a really nice guy.
Cheers
halbug _________________ Stealth Ghia Transformation: http://www.thesamba.com/vw/forum/viewtopic.php?p=7226044&highlight=#7226044
TRS63 Samba Member
Posted: Wed Apr 10, 2019 5:35 am Post subject: Re: Ghia coming home |
halbug wrote: |
TRS63 wrote: |
Thanks
Antoine |
Antoine - First I bought an Autometer tach with 30 deg increments. I used the hands and the clock face from a broken Ghia time clock. An old speedometer had to doner its housing. I opened up the speedometer housing for the tach hausing to fit into it from the rear. I adjusted the depth of the tach, so that the Ghia face, now mounted to the tach, would reside at its original depth. Cut the tach housing to match the speedo housing and welded the two together. I used an insolating material to create the electric connectors and used it to cover the remaining opening from the original fuel clock. I made two adapters on a lathe, to match a) the long hands to the tach and b) the short one to the adjuster from the time clock's glass. The large hand's short end was filled with solder to weight balance both ends Correct hand color was mixed and the two hands re-painted - DONE |
Thanks a lot, I will start to look after it, really love this idea!
Antoine _________________ Antoine
My 62 ragtop daily driver:
My 52 Standard Zwitter :
https://www.thesamba.com/vw/forum/viewtopic.php?p=10086685#10086685 |
Posted: Wed Apr 10, 2019 10:39 am Post subject: Re: Ghia coming home |
halbug wrote: |
Gwarballs wrote: |
halbug wrote: |
Thanks Jeffrey!
Cheers
Lars |
Cheers
halbug |
No dealersmin Croatia for Any kinda seat. So I’m kinda flying blind |
Olli from NJ Samba Member
