Rocker shaft spring washer
ladon67
ladon67 is offline
PostPosted: Sat May 04, 2019 5:21 am    Post subject: Rocker shaft spring washer Reply with quote
Folks, I just noticed some side to side play in the end rocker arm on one side. It appears that the spring washer that goes between the two large thin flat washers on the shaft is missing. All others are present and tight. Any idea where I might procure one?? -Mark
67rustavenger
67rustavenger is offline
PostPosted: Sat May 04, 2019 8:17 am    Post subject: Re: Rocker shaft spring washer Reply with quote
https://www2.cip1.com/ProductDetails.asp?ProductCode=C24%2D113%2D109%2D437%2DSET
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
Cusser
Cusser is offline
PostPosted: Sat May 04, 2019 10:48 am    Post subject: Re: Rocker shaft spring washer Reply with quote
Listed as out of stock. If I had a spare washer, I'd just put in mail to you.
67rustavenger
PostPosted: Sat May 04, 2019 11:13 am    Post subject: Re: Rocker shaft spring washer Reply with quote
Dammit! I just searched for the part. I didn't check if it was in stock.
Buy Once, Cry Once!
Zundfolge1432 Premium Member
Zundfolge1432 is offline
PostPosted: Sat May 04, 2019 1:25 pm    Post subject: Re: Rocker shaft spring washer Reply with quote
PM me I got a few
ladon67
ladon67 is offline
PostPosted: Sun May 05, 2019 3:22 am    Post subject: Re: Rocker shaft spring washer Reply with quote
Thanks Zundfolge!!
PostPosted: Sun May 05, 2019 5:47 pm    Post subject: Re: Rocker shaft spring washer Reply with quote
PM received and follow up sent Very Happy
