Plugging oil galleys article...
Page: Previous  1, 2, 3, 4, 5, 6, 7  Next
Dangermouse
Dangermouse is offline
PostPosted: Thu Mar 17, 2011 5:04 pm    Post subject: Reply with quote
lnrbry wrote:
Did you skip the 1/16" tap because you could not find it?
No, I just substituted the 1/8" size there; I had read that somewhere... And also the pack of plugs I got (BugPack) didn't include 1/16" plugs, just 7 x 1/8NPT, 2 x 1/4NPT and 3 x3/8NPT (even then I had a couple of 1/8"s left over Confused )
FOOD FOR THOUGHT
All the above taps are also available (at a much higher cost) as interrupted thread taps, which place less torque on the material being tapped (and less chance of cracking the case)
I think the interrupted taps were very helpful and cut without a lot of force. Worth it.
The only thing I'd add now in retrospect would be that, if and when I come to do this again, I'd get a second one of each tap size (or at least the 3/8" one) and cut it short (as described in the http://www.cal-look.com/tapping-oil-galleries/ article) so that it isn't necessary to drill and tap quite as deep to form the correct size threads, particularly in the area of the pressure relief valve (see http://www.thesamba.com/vw/forum/viewtopic.php?p=5199298)
And I probably wouldn't bother with the small plugs that close off the camshaft gallery as you can access these quite well from inside the case anyway.
My 2c anyhew...
HTH,
- DM
Do not follow me, for I may not lead. Do not lead me, for I may not follow. Do not walk beside me either; actually just bugger off and stand over there will you.
BugMan114
BugMan114 is offline
PostPosted: Fri Jul 08, 2011 7:50 pm    Post subject: Reply with quote
so a quick question for yall. I get that the restrictor is there for two purposes.
1- To keep oil from slinging past the crank pulley
2- to have more oil go to the other bearings that need it more
and i understand in an airplane, you want to remove it, as all the force from the prop is on the small #4 bearing, so you'd want more oil there.
so my question is, has anyone ever had oil leak past a sand seal from removing the restrctor?
1974 Super Beetle: Custom resto in progress
1972 Super Beetle: Daily Driver
1971 Std. Beetle w/ 1929 Mercedes Benz Gazelle kit
1960 Baja Bug
1969 Baja Bug
Sand Rail- Homemade
Sand Rail- FUBAR
Aircooled Airheads
Why the hell do they call it a gland nut. its obviously a big fat bolt!!!
lnrbry
lnrbry is offline
PostPosted: Fri Jul 08, 2011 10:46 pm    Post subject: Reply with quote
bugninva wrote:
that's alot of work to do what the bearing already does... I prefer to use this to restrict the oil flow... notice the outline of the oil galley around the tiny oil inlet hole:
I concur with Buginva, the oil galley outline going into the bearing shows that the hole in the bearing is where the restriction is. So, sand seal or not if you have oil leaking from the pulley you have some more pressing issues. why VW used a stepped plug? I don't know, but it wouldn't change how much oil is going to the itty bitty hole in the #4 bearing.
Now if there was some sort of other reason they did it, I sure can't figure it out. BTW I just collected up all the taps, drills and reamers to do my couple of cases. still need plugs but will post pics when i have everything.
modok
modok is offline
PostPosted: Sat Jul 09, 2011 12:00 am    Post subject: Reply with quote
the stepped plug arrangement is harder to plug up in an engine with no oil filter.
schadenfreude
Banned
schadenfreude is offline
PostPosted: Sun Jan 29, 2012 8:21 pm    Post subject: Reply with quote
data: (and my 2 cents)
my 2 sets of new old stock, bearings , both Metal leve
that shell oil hole is .090" or 2.3mm
my guess is that some are huge, given so many made.
the engineer just knew some shell maker or racer would, bore those shells larger.. seem to me he was smart.
but is so easy to clog-up, that is why i'm reading this, (looking and worrying)
i remember this post last summer and i wanted to clean that area...
boy is that tight!
a fabulous post here, what great detail. Thanks!
I will now state my opinion on this device.
(see if you find fault? in my alleged facts)
1: no engineer puts a device in the block for the prime purpose of blocking grit. that over the top. A true WOW factor in any eng. school.
I say , don't fly air craft like that...
My joke is , that restrictor replaces the missing oil filter (sick huh?)
2: the bearing clearance is in fact the true limit. (sure is day one)
3: the front of the engine has no real seal. ( a lame slinger)
4: the front of the crank loves to wear out first. (use ball mics and check)
5: looking at many cranks at my local yard, is see most have worn
grooves in the #4 journal , many , in fact all i saw with high mileage.
That slinger lets IN lots of crap ,sure does. just look at old cranks.
Think how crank case pressure go Plus and minus ! and this is clearer.
This fact is why sand seals are sold. it is not hype. I'ts a fail point.
6: keep in mind , this car is sold to all countries including ones with lots of sand. or other nasty driving conditions (gravel roads, is one)
7: so , the engineer can not control the engineering of the shells (aftermarket does as it pleases) so he chose to do so, in the block.
8: he never dreamed of 50 year later rebuilds, (im sure)
nor did he dream of so many bearing makers, but he was ready,no?
solutions:?
blocks apart, after all, why would you ever pull plugs with it NOT.?
so, put in the bearings shell that is .090" oil holed. Metal Leve !
end.
if you messed up, and built a motor that you expect to run for 100k
you might want to correct this. (big hole bearings and no restrictor)
if racing, ahh who cares. blown engines sell tickets, no?
if you work lots of motors you will find hidden restrictors all over them.
many motors DOHC (or single) have a restricters in the heads.
many SBC have them in the main block and they unscrew.
this is not new science or eng. design.
Prime goal, keep pressure at all costs.
What it really does:
the restrictions limit worst case flow, (saying that you have no problems with it missing is irrelevant, you are not running worst case) no?
( read how well Madman Muntz designed TVs and the folly of that)
he remove parts , till it failed then put back the last part, (odd guy ,him)
(he was the anti thesis to engineering, good to study in school )
what is important is why they are present. (b hoover knows as does others, how posted)
it makes sure that under ALL conditions the mains NEVER STARVE for FULL PRESSURE 24/7 running...
including, the limiting of CASCADE failures.
like the Aircraft poster said, he speaks in the generic and nobody listens.
that is because they don't understand how bad CASCADE can be.
it can be the difference from , spinning one bearing or
having it whole motor explode in your face and you crash.
in the air or the ground (ever had rear wheels lock up at 80mph? in the rain?)
in Air craft they care about that, on VeeDUbs, not so....??
and Thank you for that great photo of the 90 fitting ground down
im doing that , now.
my block is now done, just cleaning it the last time.(3rd)
PS: i have one suspension, that is that, that gallery plug fails (stuffs)
so get it out of there forever ! and use the correct shells. .090" holed
I am,
btw, if you run full flow filter , none of this is important, zero grit. no clogs.
and not saying #4 bearing spin will cascade motor, unless the metal shavings hits
1,2,3 shells. and packs them.... but the furthest rod will fail first, if my money is good on table.
easy e
easy e is offline
PostPosted: Thu Dec 12, 2013 9:20 am    Post subject: Reply with quote
If anybody installed a drilled hole in plug restrictor replacement and isn't relying (or know) bearing hole size... consider chamfering (countersink drilling with a couple bigger size drills) the pressure side of the plug.
If it's sharp edged... less oil may be going through the hole. Example "A".
aka: Evan
haz77
haz77 is offline
PostPosted: Thu Dec 12, 2013 2:24 pm    Post subject: Reply with quote
Hi all,
Been linked to this thread by DM who posted on here earlier as hes advising / helping me with my type3 rebuild.
Now Ive also followed the huelsmann way, and now find my self in the tricky what to do with #4 plug situation also Shocked
Man theres been a lot of input & theory bashing on this here but I think I get the picture & can see most sides of the arguments, however my thoughts / concerns are:-
I like the look of the stepped restrictor either with a bolt through a plug or by getting a machine shop to make one,, BUT,,, worries me that if the centres of the restrictor & the threaded plug where off then you could possibly end up blocking the outlet hole a bit like a cam lock effect, wonder if putting a drilled plug down the throat of the supply passage or into the bearing journal outlet would be a safer bet?
I do how ever see reason with what is being said about the bearing restricting the flow thus making the plug a bit of a red herring but dont really want to have to pull the engine down again when Im proved wrong Laughing
Finally, what is the reason that it has been said to push a alloy rod into the bearing journal rather that to drill, tap & screw a plug in here to, is it due to the size of this oil way?
Cheers.
c.ruber
c.ruber is offline
PostPosted: Fri Oct 17, 2014 6:11 am    Post subject: Reply with quote
Glad I revisited this thread...
...and progress is not intelligently planned...
pupjoint
pupjoint is offline
PostPosted: Mon Apr 17, 2017 9:46 am    Post subject: Re: Plugging oil galleys article... Reply with quote
bump. been a while now. anyone running without the restrictor having issues oil coming out from pulley on high mileage engines?
67 Sunroof
67 Sunroof is offline
PostPosted: Sat May 04, 2019 8:17 pm    Post subject: Re: Plugging oil galleys article... Reply with quote
Bump!
I just drilled all of mine out and tapped them. (Even the #4 bearing one)
Any up to date info on longevity of just using the plug in the hole without a restrictor?
It makes sense that only as much will go through that small hole in the bearing as it will allow-effectively reducing the amount of oil, right?
modok
modok is offline
PostPosted: Sat May 04, 2019 8:30 pm    Post subject: Re: Plugging oil galleys article... Reply with quote
The oil flow at the bearing will be determined by the bearing clearance and size of the oil hole in the bearing.
it is possible that the "restrictor" is actually a filter.
RWK
RWK is offline
PostPosted: Sun May 05, 2019 5:53 am    Post subject: Re: Plugging oil galleys article... Reply with quote
Filter maybe, catch all definitely! all plugs I have pulled had crap on them and the galley is always full of crap,look close at pic of case, debris down it the hole,
this case had been "cleaned".
73 Type 181
63 Type 113
63 Type 261- 428 071
62 Type 241-378 025 178 530
DeathBySnuSnu
DeathBySnuSnu is offline
PostPosted: Sun May 05, 2019 8:01 am    Post subject: Re: Plugging oil galleys article... Reply with quote
My Claudes Buggies super case that I bought in 1981 and still run to this day never had a restrictor. Never a known problem. But I would not call it high mileage. It has always been a hot rod and only sees around 30K before a freshen up rebuild. It has been through this cycle many times, worn out 2 sets of heads, but has always been a fair weather toy
modok wrote:
And look at the SHAPE of the curves, just smooth, like gods own slingshot. .
67 Sunroof
PostPosted: Sun May 05, 2019 11:05 am    Post subject: Re: Plugging oil galleys article... Reply with quote
I have read many, many articles including yours and that’s what made me want to drill/tap/plug them.
My question is if drilling the small plug out without having a “restrictor” is there would matter. I would imagine that, ultimately, the bearing hole would restrict how much oil gets through the bearing anyway.
The posts I read were old and wanted to know if there was any current issues with just tapping the small hole without restricting the gallery. (Haha even read on the proper terminology of galley or gallery)
So, will just plugging the hole be fine??
Ready to start on my build and I’m excited!
RWK
RWK is offline
PostPosted: Mon May 06, 2019 4:36 am    Post subject: Re: Plugging oil galleys article... Reply with quote
That's what I do, I have done "all" of them, especially in old case's, anywhere there is a plug there is a chance of debris collected there, it's kind of like water/plumbing systems, where ever there is a dead head there is always junk there, (no offense to Dead Heads, for I'm one also) or a faucet that hasn't been turned on in awhile. I will post a pic later of how I pulled and plugged the one above the oil pressure sender on the top of case.
73 Type 181
63 Type 113
67 Sunroof
PostPosted: Mon May 06, 2019 6:25 pm    Post subject: Re: Plugging oil galleys article... Reply with quote
Yeah if you don’t mind I would appreciate it.
Thanks for your insight!
RWK
RWK is offline
PostPosted: Tue May 07, 2019 4:18 am    Post subject: Re: Plugging oil galleys article... Reply with quote
I used a threadless plug in the vertical galley by the oil pressure sender, seems there wasn't enough mat'l to tap it, IMHO, so made a plug similar to the 1 shown, which is an item I use in mold making for water lines, it just needs to be backed up or held down, no treads to worry about, just a little oring lube and press in, they never leak, and they come out easy with tapped pull hole, hole does have to be accurate though, reamed hole, std. oring tolerance apply. Its been in 15 years.
73 Type 181
63 Type 113
67 Sunroof
PostPosted: Tue May 07, 2019 5:30 am    Post subject: Re: Plugging oil galleys article... Reply with quote
What does this do compared to threading a plug in?
I already have all holes threaded. I was just wondering if the small hole I tapped needs a type of restrictor plug in it?
I’m not sure I would trust a plug with a rubber o ring in the block for years though.
It’s worked for you though!
RWK
RWK is offline
PostPosted: Tue May 07, 2019 7:47 am    Post subject: Re: Plugging oil galleys article... Reply with quote
No, most just plug the hole, no restrictor, believe the newer style bearings have a smaller hole that does the same, just showing the plug as a way to seal holes when there isn't enough depth to tap, o-rings are used extensively in high pressure hydraulics, they can leak though over time, but with low pressure oil system not likely, then you just pull and replace the ring, just my way of doing that particular oil line, I also have pipe plugs everywhere else. Pipe plugs have a limited number of R&R in a soft metal case, case can break easily so be careful.
73 Type 181
63 Type 113
Clatter
Clatter is offline
PostPosted: Thu May 09, 2019 8:13 pm    Post subject: Re: Plugging oil galleys article... Reply with quote
Been running several motors now for years with no restrictor plug..
No sand seal, no issues with oil behind the pulley.
If you really care, make sure your #4 bearing has a small hole.
If you worry about failure in this area, make sure it’s clean and not plugged with crap.
We can put this one to rest now.
Bus Motor Build
It does not exist!
Page 6 of 7
