Timing light Recommendation
dhoulf
dhoulf is offline
PostPosted: Tue May 07, 2019 5:15 pm    Post subject: Timing light Recommendation Reply with quote
Any recommendations on a new timing light ?
Vanapplebomb
Vanapplebomb is offline
PostPosted: Tue May 07, 2019 5:28 pm    Post subject: Re: Timing light Recommendation Reply with quote
Just about any cheap inductive timing light will be good enough. No need for the fancy ones with electronic advance, etc....unless you want one just so you can have a tachometer on the timing light. I just use a $30 light and my multimeter for a tach.
1800 Type 4 Berrien 295
busdaddy
busdaddy is offline
PostPosted: Tue May 07, 2019 5:31 pm    Post subject: Re: Timing light Recommendation Reply with quote
Lots to read here: https://www.thesamba.com/vw/forum/viewtopic.php?t=715047&highlight=timing+light+shopping
Слава Україні!
Howard 111
Howard 111 is offline
Mine is an Actron CP7504. I got it at one of the Auto Parts stores, like Auto Zone. It was 10 years ago, but it still works great. You need a timing pulley, or mark the stock pulley at the timing mark you want to see.
1973 Karmann Ghia
Turbocharged, Fuel Injected
http://www.thesamba.com/vw/forum/viewtopic.php?t=531270
Dale M.
Dale M. is offline
PostPosted: Wed May 08, 2019 6:52 am    Post subject: Re: Timing light Recommendation Reply with quote
Any basic low end inductance light will do (minimally) ... Having good timing marks (highlighted) on crankshaft pulley really helps....
Dale
Bruce Amacker
Bruce Amacker is offline
PostPosted: Wed May 08, 2019 8:30 am    Post subject: Re: Timing light Recommendation Reply with quote
Agreed, pass on the timing advance models as I've seen them be inaccurate. I'm clumsy so I prefer metal body lights with metal clamps, most are plastic bodies with plastic clamps and easily broken. Older Penske lights seem to work well and hold up.
'66 Deluxe Bus
'65 Standard Bus
Build threads:
'66- http://www.leakoil.net/forum/viewtopic.php?f=23&t=2888&sid=54d8dedfb3822f99c7f2ea430cb4e856
'65- http://leakoil.net/forum/viewtopic.php?f=23&t=4263
drumbum68
drumbum68 is offline
PostPosted: Wed May 08, 2019 10:02 am    Post subject: Re: Timing light Recommendation Reply with quote
A dial back is very handy.
Calibrate against a non dial back.
