Will 16x8 wheels fit on my 95 Eurovan Camper
wildabeast
wildabeast is offline
PostPosted: Sat Apr 13, 2019 12:21 am    Post subject: Will 16x8 wheels fit on my 95 Eurovan Camper Reply with quote
I came across some used tires and wheels and am wondering if they'd work on my 1995 Eurovan camper:
Wheels: 16x8 and 66.6 centre bore, ET 51
Tires are 235/60/16
Note: van is not yet lifted but I would be doing that as part of this upgrade
Thanks
PS I saw the megathread about vanagon wheels / tires but didn't see one for Eurovan -- sorry if it exists and I missed it
1995 VW Eurovan Winny
1985 VW Vanagon GL
1996 VW Jetta
1987 VW Golf (RIP)
Maurz
Maurz is offline
PostPosted: Sat Apr 13, 2019 7:26 am    Post subject: Re: Will 16x8 wheels fit on my 95 Eurovan Camper Reply with quote
That is a somewhat commonly used tire size but usually on a 7.5 inch rim. I'd think you will be fine depending on how much lift you add.
Broseph Stalin
Broseph Stalin is offline
PostPosted: Sun Apr 14, 2019 12:30 pm    Post subject: Re: Will 16x8 wheels fit on my 95 Eurovan Camper Reply with quote
Tires are 235/60/16
Thanks
I think those are far off from ideal. See this - http://www.cavevan.com/forum/index.php?PHPSESSID=09440beb29cb2837dc7c73918b55ddbb&topic=8.0
Center bore should be 57mm and offset max I think is 48mm.
'68 Bus in West Germany, 1977-1979
'67 Riviera poptop conversion in the US, 1984-1990
'95 EVC Winnie, 2018, Sold
'03 EVC Winnie, 2018, Sold
wildabeast
PostPosted: Mon Apr 15, 2019 8:39 pm    Post subject: Re: Will 16x8 wheels fit on my 95 Eurovan Camper Reply with quote
Thanks all.
I'm scouring the forums trying to figure out the range of wheels that will work on the 95 Eurovan, but can't seem to find a all-in-one source.
I'm more or less trying to mimic the wheel and tire setup thats in the gowesty lift kit, but have decided to try to source some used wheels and tires to save some $$ (I'm in canada, so between exchange rate, shipping, and duty, its a pricy package).
So assuming I decide to go with 16" wheels, I'm trying to figure out:
- What wheel width will work? I've seen 6.5 to 7.5" but wondering what the max/min/ideal are
- For offset, is et38 the standard? How far could I deviate from that?
- 5x112 I'm guessing is non-negotiable?
- Center bore 57 mm -- also non-negotiable?
Once I get that figured, I probably have some questions about tires too... but I'll defer that for now
Cheers
1985 VW Vanagon GL
1996 VW Jetta
1987 VW Golf (RIP)
rcowan
rcowan is offline
PostPosted: Tue Apr 16, 2019 1:39 pm    Post subject: Re: Will 16x8 wheels fit on my 95 Eurovan Camper Reply with quote
As far as the exact limits of every combination. Good luck. I doubt anyone knows all the options. Some are try them and see if they fit.
You can buy spacers to correct for the offset in one direction. You can buy centering rings if the center bore is larger than 57. These start adding up and if you are looking at all the options to find the cheapest solution, often sticking with the recommendations is best.
However, if you have found something you really love and don't mind the extra cost, you have options. Smile For example, I found some 16x7.5s that I really liked with the wrong center bore... I bought rings and problem solved.
Zeitgeist 13
Zeitgeist 13 is offline
PostPosted: Wed Apr 17, 2019 5:40 pm    Post subject: Re: Will 16x8 wheels fit on my 95 Eurovan Camper Reply with quote
As a general rule, most 16" Audi and late model VW rims (w/5x112 PCD) fit these vans very well.
Casey--
'01 Weekender --> full camper
y u rune klassik?
samba415
samba415 is offline
PostPosted: Fri Apr 19, 2019 2:55 pm    Post subject: Re: Will 16x8 wheels fit on my 95 Eurovan Camper Reply with quote
This is a nice calculator.
https://tinyurl.com/y6adzftm
wildabeast
PostPosted: Tue Apr 30, 2019 10:22 pm    Post subject: Re: Will 16x8 wheels fit on my 95 Eurovan Camper Reply with quote
Great responses.
I've decided I'm useless and I'm gonna by the gowesty lift kit and get er fitted where i can.
anyone got a good spot in bellingham?
1985 VW Vanagon GL
1996 VW Jetta
1987 VW Golf (RIP)
wildenbeast
wildenbeast is offline
PostPosted: Wed May 01, 2019 8:06 am    Post subject: Re: Will 16x8 wheels fit on my 95 Eurovan Camper Reply with quote
This is worth a read for upgrading an early EV to 16" wheels:
https://www.thesamba.com/vw/forum/viewtopic.php?p=8239277&highlight=#8239277
- Bill, '93 Eurovan Syncro Weekender (2.5 manual ACU)
wildabeast
PostPosted: Wed May 01, 2019 2:42 pm    Post subject: Re: Will 16x8 wheels fit on my 95 Eurovan Camper Reply with quote
To upgrade to 16" wheels, you would need to upgrade the rear brakes to discs.
Really? Why is that? I'm surprised neither my mechanic nor gowesty has mentioned this when I discussed putting the larger wheels on my EVC...
1985 VW Vanagon GL
1996 VW Jetta
1987 VW Golf (RIP)
CdnVWJunkie Premium Member
CdnVWJunkie is offline
PostPosted: Wed May 01, 2019 2:52 pm    Post subject: Re: Will 16x8 wheels fit on my 95 Eurovan Camper Reply with quote
Wrong info.
chrslws
chrslws is offline
PostPosted: Wed May 08, 2019 1:12 pm    Post subject: Re: Will 16x8 wheels fit on my 95 Eurovan Camper Reply with quote
Don't be afraid to try something different. Center bore rings run $10 for a set and wheel spacers and longer bolts are not gonna break the back. The UK guys are much more adventurous about wheel choices; take a look on the vw t4 forum or any of the Facebook groups for UK t4 owners for inspiration. And you definitely don't need to install rear discs.
wildabeast
PostPosted: Thu May 09, 2019 12:24 pm    Post subject: Re: Will 16x8 wheels fit on my 95 Eurovan Camper Reply with quote
Thanks for the encouragement!
1985 VW Vanagon GL
1996 VW Jetta
1987 VW Golf (RIP)
wildabeast
PostPosted: Thu Dec 12, 2019 3:42 pm    Post subject: Re: Will 16x8 wheels fit on my 95 Eurovan Camper Reply with quote
Just to close this off, I ended up grabbing the Gowesty wheel and lift kit. Definitely not the cheap route but saved me search time and I'm very happy with the new look and feel!
1985 VW Vanagon GL
1996 VW Jetta
1987 VW Golf (RIP)
