GreggK Samba Member
Joined: May 17, 2008 Posts: 1029 Location: Colorado/Philidelphia
Posted: Mon May 20, 2019 8:03 pm Post subject: How do I change this steering coupler..... |
This is the coupler down at the steering gear box. How can I get this on off? Maybe drill out this rivets and replace with short bolt and nut? Anyone do this before. Thanks for any help.
GreggK
markswagen Samba Member
Joined: January 28, 2018 Posts: 1554 Location: san diego
Posted: Mon May 20, 2019 8:06 pm Post subject: Re: How do I change this... |
Drill or grind off the rivets and replace with bolts and lock nuts.
Use antisieze, just in case you are the next one in there  _________________ markswagen {mobile mechanic} san diego area all early VW's cared for.
619 201 0310 |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 80680 Location: Sneaking up behind you
Looks like you drill it and use bolts to secure it.
Use a thread lock or nylocks. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
GreggK Samba Member
Posted: Mon May 20, 2019 8:18 pm Post subject: Re: How do I change this... |
| GREAT! Thanks for the help guys. |
E1 Samba Member
Joined: January 21, 2013 Posts: 8927 Location: Westfalia, Earth
Posted: Mon May 20, 2019 11:07 pm Post subject: Re: How do I change this... |
We had both of ours replaced by what turned out to be a slipshod shop last fall.
When time permits, I'm redoing the hardware and using safety wire to assure the nuts can't come out. The result if they did could be fatal. _________________ If ever twice as rich, we’re gettin’ a double-wide
’84 “Westfailure”/2.1 Digijet/5.43 Ring & Pinion/Peloquin/D-rated BFG KO2s
AI has spoken to further illiteracy, to steal, to cheat, and to replace humans
The caveman’s first question to the headhunter: “Hey, you got any coffee?” |
GreggK Samba Member
Posted: Sun Jun 16, 2019 3:19 pm Post subject: Re: How do I change this... |
Hey Guys,
So here is what I could source at a trip to the closest Auto Zone. I did NOT use any kind of thread lock paste. Does it look safe enough. Thanks!
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 10322 Location: Mt Lemmon, AZ
Posted: Sun Jun 16, 2019 3:56 pm Post subject: Re: How do I change this... |
| Something I sometimes do in a situation like this is mark the bolts and nuts with a paint pen such that I can tell by casual inspection if anything is loosening. |
E1 Samba Member
Posted: Sun Jun 16, 2019 4:43 pm Post subject: Re: How do I change this... |
Candidly, No, it does not "appear to be" safe enough without thread lock, safety wire, or lock nuts.
But even with those, there's no way to tell how tight they are — nor make any kind of rational judgment on whether or not it ISN'T safe. _________________ If ever twice as rich, we’re gettin’ a double-wide
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 10504 Location: Orbiting San Diego
Posted: Sun Jun 16, 2019 5:02 pm Post subject: Re: How do I change this... |
Those high grade lock nuts are fine for this purpose. That is what VW specified for this location and purpose. VW used the same type nuts for the steering parts of many VWs including Vanagons. Look at the list of VW vehicles in this link.
https://eu.vwheritage.com/n0221464-hexagonal-nylock-nut-m8-vw-spare
Mark |
Gizmoman Samba Member
Joined: September 10, 2011 Posts: 1561 Location: Nevada
Posted: Sun Jun 16, 2019 5:07 pm Post subject: Re: How do I change this... |
They appear to be locknuts - and very good ones as well. In fact, the lock washers may not be necessary at all.
Fine job. _________________ 82 Vanagon Westy - AAZ 1.9 TD, HE200 Holset, WAIC, 27.75 dia tires, Electric power steering, 5-speed AAP w/.078 5th
Oversize spare carrier - stock location (no longer for sale). |
GreggK Samba Member
Posted: Sun Jun 16, 2019 5:56 pm Post subject: Re: How do I change this... |
In the pictures I posted I was trying to show that I used the nuts in that were in the plastic package labeled "lock nuts". I shouldn't have assumed that would have been understood by everyone but that's what I was trying to show what I used and if you pay a slight amount of attention you can even see that the nuts installed look just like the nut sitting on the label
I did think there was not enough threads showing out of the (LOCK)nut, maybe if I do lose the "split lock washers" I'll get a few more threads out of it, which are also shown in the picture I posted but the label not as easily seen as the label for the "prevailing torque LOCK nuts" that can be seen plain as day to most people with decent sight or a good pair of perscription lenses.
Would it be overkill to add a blue thread lock paste? Im also not fimillar with the saftey wires I've seen suggested by E1 but would include for maximum defense against failure. |
GreggK Samba Member
Posted: Sun Jun 16, 2019 6:04 pm Post subject: Re: How do I change this... |
| Oh and that was good info on that list you posted Crazyvwvanman. Thumbs up. |
Posted: Sun Jun 16, 2019 6:06 pm Post subject: Re: How do I change this... |
You don't need to change anything. You used high quality fasteners of the same sort VW uses for that same purposes. If you have a spare nut and bolt of the type you used you can thread the nut on by hand and see how soon the self-locking aspect starts to happen. That should reassure you that the nuts are on far enough to lock. I wouldn't have used split washers for this but at least the ones you used were high grade.
Mark |
GreggK Samba Member
Posted: Sun Jun 16, 2019 6:07 pm Post subject: Re: How do I change this... |
| And I will be doing the paint mark as Ahwahnee suggested, but only after I torque each fastener to specs as per the Bently. |
GreggK Samba Member
Posted: Sun Jun 16, 2019 6:09 pm Post subject: Re: How do I change this... |
| Cool guys! Thanks for the concerns and solutions to the issue I had at hand. Love the forums! |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32987 Location: Reading Pennsylvania
Posted: Sun Jun 16, 2019 6:19 pm Post subject: Re: How do I change this... |
| The split lock washers set off alarm bells to me. Too many failures in other places over the years. I would replace them with a Grade 8 "or metric equivalent" flat washers and then probably use high strength loctite even with the lock nuts. |
GreggK Samba Member
Posted: Sun Jun 16, 2019 6:33 pm Post subject: Re: How do I change this... |
| Hummm... more good points. All I know is the coupler came from VC/RMW. Ill look at the box ot came in when Im back home. Thanks! |
wcdennis Samba Member
Joined: July 20, 2004 Posts: 955 Location: Winston-Salem NC
Posted: Sun Jun 16, 2019 6:44 pm Post subject: Re: How do I change this... |
| Your old coupler looks to be in really good condition. I would definitely save it. Judging by all the posted early failures of hoses, boots and mounts, it seems the secret to making rubber that lasts has been lost. |
Posted: Sun Jun 16, 2019 6:47 pm Post subject: Re: How do I change this... |
An alternative to the blue LocTite is the green version - it is applied after the piece is assembled. I have used it but really can't say how well it works compared to the blue formula.
Those nuts look like what I would call Stover Nuts - in my opinion a better choice than the more common Nyloc style. |
