thomast Samba Member
Posted: Mon Jul 08, 2019 9:51 am Post subject: Headlights not working, again! |
They were working great. Stopped for gas and when I started the motor again, no headlights.
I put in a new switch
Redid the grounds
Checked the fuses
The yellow running light work.
The blue high beam indicator light comes on, but get no lights to come on.
Thoughts on what else I might check?
Thanks! _________________ 1986 Westy Syncro SVX
1970 Bay Window |
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 10487 Location: Orbiting San Diego
Posted: Mon Jul 08, 2019 9:54 am Post subject: Re: Headlights not working, again! |
Does the blue indicator consistently turn on/off when the high/low switch is actuated?
Does it then stay on when you release the high/low lever in the high position?
Mark |
Posted: Mon Jul 08, 2019 10:19 am Post subject: Re: Headlights not working, again! |
Yes, blue high beam indicator light stays on like it normally would _________________ 1986 Westy Syncro SVX
1970 Bay Window |
Posted: Mon Jul 08, 2019 10:39 am Post subject: Re: Headlights not working, again! |
My question is does the blue indicator stay in both the OFF and the ON modes as it should, when you take your hand away from the lever after selecting each mode?
Mark |
levi Samba Member
Joined: February 11, 2005 Posts: 5522 Location: Las Vegas
Posted: Mon Jul 08, 2019 1:30 pm Post subject: Re: Headlights not working, again! |
Connector plug immediately behind the headlights?
A few years ago I was driving at night when one went out.
Noticed a little slack there so some tinfoil got me home. _________________ One of these days I'm gonna settle down,
but till I do I won't be hangin round.
Going down that long lonesome highway,
gonna see life my way
https://youtu.be/cSrL0BXsO40 |
tjet Samba Member
Posted: Mon Jul 08, 2019 3:58 pm Post subject: Re: Headlights not working, again! |
I ended up re-wiring my headlights because I had a similar issue. I tied off and stowed away the factory h/l harness and installed a good used harness with the addition of relays. I also went to a "key-on" power source. For switches, I installed a pair of high quality toggle switches from a vintage Cessna. I wired it in a way that I can turn on the headlight only and use them as DRL lights.
I still use the factory headlight switch to turn on the parking lights.
Posted: Mon Jul 08, 2019 9:54 pm Post subject: Re: Headlights not working, again! |
Crazyvwvanman, the blue light stays on after I click it. I don’t have to hold it to stay on. _________________ 1986 Westy Syncro SVX
1970 Bay Window |
VicVan  Samba Member
Joined: July 01, 2015 Posts: 2001 Location: Vancouver Island, BC
Posted: Mon Jul 08, 2019 10:08 pm Post subject: Re: Headlights not working, again! |
| thomast wrote: |
Redid the grounds
Checked the fuses
Thanks! |
This might sound trivial, but your list doesn't show that you've tested or changed the bulbs themselves. _________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
Posted: Wed Jul 10, 2019 9:14 am Post subject: Re: Headlights not working, again! |
Bulbs all look good.
Recap:
-Ground is good
-Bulbs are good
-Fuses are good
-Installed new headlight switch
-Blue high beam light will stay on without holding in the lever
-Yellow running lights work.
-Low and High Beams do not work at all
Hitting the road home tomorrow. Would love to figure this out today.
If anyone has any other suggestions on what to look for, I’d appreciate it. _________________ 1986 Westy Syncro SVX
1970 Bay Window |
Posted: Wed Jul 10, 2019 9:28 am Post subject: Re: Headlights not working, again! |
That only answers half of my question. The fine details matter for solving problems.
Mark
| thomast wrote: |
| Crazyvwvanman, the blue light stays on after I click it. I don’t have to hold it to stay on. |
SCM Samba Member
Joined: January 26, 2011 Posts: 3481 Location: Bozeman MT
Posted: Wed Jul 10, 2019 9:44 am Post subject: Re: Headlights not working, again! |
| crazyvwvanman wrote: |
Mark
Mark, I'm a little confused by your question too. Are you asking whether the blue light stays ON even when the high beams would be OFF if they were operating normally? _________________ '91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine |
Posted: Wed Jul 10, 2019 9:54 am Post subject: Re: Headlights not working, again! |
Here is my question again. Read the whole thing, paying attention to the last 4 words.
Mark
Mark |
dobryan  Samba Member
Joined: March 24, 2006 Posts: 17336 Location: Brookeville, MD
Posted: Wed Jul 10, 2019 9:58 am Post subject: Re: Headlights not working, again! |
Mark
Mark |
Mark, are you asking if the blue light stays on regardless if the high beams are selected as ON or OFF (lever released after selection)? _________________ Dave O
The Western Syncro build
outcaststudios Samba Member
Joined: February 09, 2015 Posts: 1756 Location: Maine
Posted: Wed Jul 10, 2019 10:19 am Post subject: Re: Headlights not working, again! |
Test the bulbs. ( I see that you did) also be sure to recheck the connectors on the back of the bulb housing, rubber cover etc. _________________ '88Doka JX td
'69 westy
(rip)couple bugs
(rip)three type III"s
(rip) '81 vanagon
a bunch of french stuff,and 9 motorcycles.
https://www.thesamba.com/vw/classifieds/detail.php?id=2573791 |
Posted: Wed Jul 10, 2019 1:15 pm Post subject: Re: Headlights not working, again! |
The blue hi beam light works as it should. Pull back the lever, it clicks and it’s on. Pull it back again, it clicks and it goes off.
T _________________ 1986 Westy Syncro SVX
1970 Bay Window |
Posted: Wed Jul 10, 2019 1:36 pm Post subject: Re: Headlights not working, again! |
Assuming the led is switching completely off when you click the lever to that mode, then you likely have more than 1 problem.
Assuming again, this is your 86 with a 22 fuse panel and not some other year?
Also you have a 4 headlight setup?
With the KEY OFF, if someone stands in front and looks closely at the headlights while you pull the hi/lo lever up and hold it, do any bulbs come on at all?
The dash indicator should come on and stay on while you hold the lever up. Does it?
Mark |
Posted: Wed Jul 24, 2019 1:15 am Post subject: Re: Headlights not working, again! (Solved) |
I replaced the GW high-power headlight relays and the lights are again working.
Thanks everyone for the help! _________________ 1986 Westy Syncro SVX
1970 Bay Window |
