Vent window latch, easy to replace?
sonoma_vw
sonoma_vw is offline
PostPosted: Fri Jul 19, 2019 9:09 pm    Post subject: Vent window latch, easy to replace? Reply with quote
Took beetle to get waxed. Picked it up and
the vent window latch is missing Laughing (it’s ok, it was hard to manipulate, but was also very wobbly)
So, how hard is it to install a replacement latch?
Do you have to remove the chrome frame from the glass?
Thanks
Bug-nut
Bug-nut is online now
PostPosted: Fri Jul 19, 2019 10:41 pm    Post subject: Re: Vent window latch, easy to replace? Reply with quote
It’s a fun one for sure. Yes you have to pull the glass out of the chrome frame. The new latch is riveted in place and then you have to reinstall the glass, preferably with a new rubber seal. I had great fun getting mine to go back together properly. There’s a few threads here on the topic on getting the glass back in correctly. However the latch itself is pretty easy!
1959 Fjord Blue Volkswagen Beetle
http://www.thesamba.com/vw/forum/viewtopic.php?t=6...highlight=
1962 Austin-Healey Sprite
Snort wrote:
A 59 Beetle is just an Oval-Window car with aspirations of modernity.
RichardinNZ
RichardinNZ is offline
PostPosted: Sat Jul 20, 2019 2:52 am    Post subject: Re: Vent window latch, easy to replace? Reply with quote
Hoping to piggy back your thread...
The locking handle fell off my vent wing today. I'd like to put it back together but don't know what parts are still on the floor in my car or on my driveway. I have the handle and button and washer which sits behind the handle. Does anyone know what I'm missing? I can't find a parts diagram for it.
Thanks
Richard
'58 Beetle; NZ Assembled
Dual Carb 36hp
My Car https://www.thesamba.com/vw/forum/album_page.php?pic_id=1750253
View user's profile Send private message Visit poster's website AIM Address Instagram Gallery Classifieds Feedback
Sharp64
Sharp64 is offline
PostPosted: Sat Jul 20, 2019 5:53 am    Post subject: Re: Vent window latch, easy to replace? Reply with quote
I don’t know the quality of them, but ISP West sells complete replacement vent windows. As much fun as I’ve heard these are to refurbish, i would consider just buying a new one.
1960 Indigo Blue Ragtop (Blue Barry)
1967 Ghia
1985 Westy Money Pit
“...some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn.” - Michael Caine
andk5591
andk5591 is offline
PostPosted: Sat Jul 20, 2019 6:41 am    Post subject: Re: Vent window latch, easy to replace? Reply with quote
Yeah - I would go with a repro vent window. I have got replacement latches from some vendors and they are not correct (rivet holes don't line up, etc.) I did get a couple from Wolfsburg West for a 67 that did fit correctly. Until you are done paying $25 for a latch and then spending a lot of time removing and reinstalling the glass, a new one is an attractive option.
Just replacing the handle is usually a fail. The shaft is not always the same size.
D-Dubya Manx clone 1914. Ex wifes car.
Maxine 61 Cal-look bug - Ex-wifes car.
There's more, but not keeping them...
65 Sunroof
65 Sunroof is offline
PostPosted: Sat Jul 20, 2019 6:11 pm    Post subject: Re: Vent window latch, easy to replace? Reply with quote
Thanks
Mine was the same. There is a compressed pin that goes in an keeps it on. You should see the two holes it goes through. However, it could be that the circle of soft metal that the pin goes behind broke off. Check to see if the circle is still intact on the piece still in the window.
panicman
panicman is offline
PostPosted: Tue Jul 23, 2019 8:37 am    Post subject: Re: Vent window latch, easy to replace? Reply with quote
Agree with the others- replace the wing assembly. You’ll have to tear the door down a bit, but you’ll save hours and a lot of frustration.
To replace the glass only you’ll need to create a press with a custom jig to get the glass seated properly without breaking the glass. You’ll have to remove and replace the chrome mounting rivets or figure out how to work around the wing with the bracket attached.
I’d just get a good original replacement or consider aftermarket and replace the whole shebang.
