Metal Twister Samba Member
Joined: January 24, 2013 Posts: 405 Location: licking, MO.
Posted: Fri May 17, 2019 8:01 am Post subject: Re: "What did you do with your Thing today"? |
Ordered a nice set of replacement tail lights for it last week and just got them today. Man o man what a whirl wind year so far! Moved the business from San Diego to Licking Missouri the first of the year. Its taken all this time to truly get settled in and to the point where I can start thinking about playing on the toys once again. The juices are bubbling to get back on the Thing where I left off mid last year. It looks like the mission has changed from being a Desert machine to dirt roads, trails, and woods! The 181’s new home!
_________________ Change is Opportunity!
Instagram=metaltwister |
Joe 20 Samba Member
Posted: Sat May 18, 2019 7:47 pm Post subject: Re: "What did you do with your Thing today"? |
Put a crank nut, tin and crank in "The Toy." Pretty neat. Will use the crank at shows.  |
Posted: Sun May 19, 2019 6:57 am Post subject: Re: "What did you do with your Thing today"? |
LOL, have enough vehicles with crank starts, Not anxious for anymore.👍 _________________ Change is Opportunity!
Joe 20 Samba Member
Posted: Sun May 19, 2019 7:57 pm Post subject: Re: "What did you do with your Thing today"? |
Like I said, only for shows (and an emergency). |
obus  Samba Member
Joined: March 08, 2001 Posts: 11631 Location: just off Garden State Parkway Exit 81
Strichtarn Samba Member
Joined: March 14, 2019 Posts: 19 Location: Fort Bliss
Posted: Wed Aug 14, 2019 6:05 pm Post subject: Re: "What did you do with your Thing today"? |
Got my thing back from the shop and repainted finally, got some rust spots and Bondo spots taken out and put new metal in. Finally getting closer to how I want it.
Here's the original.
Joe 20 Samba Member
Posted: Thu Aug 15, 2019 7:17 pm Post subject: Re: "What did you do with your Thing today"? |
Cleaned up the Toy  |
kenj06 Samba Member
Posted: Tue Aug 20, 2019 5:59 pm Post subject: Re: "What did you do with your Thing today"? |
Yesterday:
Driving down the road and the damn Thing died.
Today:
Out with the new...
In with the old...
Backstory - had a 009 distributor and never could get rid of the flat spot on acceleration. Bought the Flame Thrower a few years ago since I wanted a SVDA and electronic ignition. I came across the DVDA with a good can about a year ago for a good price and bought it with the intention of keeping it as a spare. Unfortunately I didn't have it with me yesterday.
After driving around about 45 minutes yesterday, no issues, it just died while approaching a stop light. Wouldn't restart and I diagnosed no spark. Popped in the DVDA, adjusted the points and timing and ran around for over an hour today with no issues. I swear it starts better than it did previously and runs smoother too.
No more electronic ignition for me.  |
Technut27 Samba Member
Posted: Mon Sep 16, 2019 6:59 pm Post subject: Re: "What did you do with your Thing today"? |
I was finally motivated to trace all the mystery wires I bundled up out of the way, it has been that way since I bought the car.
Most went between a pair of door switches in the body and a toggle switch mounted up under the dash on the drive side. I think the toggle was wired in to close the circuit when the doors were off and those switches were open. Quality work with masking tape holding the tap wire on the fuse block and splices together. Whatever they used to do they sure didn't anymore, most were cut or spliced into each-other.
Many of the others (9) went to a switch labeled "Tape/Radio" panel mounted near the headlight switch, none of them went anywhere, just twisted and wrapped around inside the dash. I cut them all off the same length, taped them up and remounted the switch, might come in handy some day.
I have one loose wire left to trace on the wiring diagram, in the green box in the picture. As you can see unless the wires were inside the dash they were all painted orange once upon a time
disneyherbie Samba Member
Joined: September 02, 2006 Posts: 375 Location: Albuquerque, New Mexico
Posted: Sun Oct 06, 2019 9:02 am Post subject: Re: "What did you do with your Thing today"? |
Went for my 1st drive after getting my newest project back on the road. I found this 73 Thing on eBay in upstate NY of all places. 32k original miles. It cleaned up nicely. I figured a pumpkin patch would be an appropriate first picture...
Dopevolkswagen Samba Member
Posted: Thu Oct 10, 2019 2:25 pm Post subject: Re: "What did you do with your Thing today"? |
took her for a surf check after replacing the ignition switch
obus  Samba Member
obus  Samba Member
Joe 20 Samba Member
Posted: Fri Feb 07, 2020 8:36 pm Post subject: Re: "What did you do with your Thing today"? |
Monday February 3, 2020...I drove it!! A one day warm snap in Ohio...big rains a few days ago and the salt was gone from the roads. It was nice to get it out, even for a day!! Took some pictures too!!
pallettman Samba Member
Joined: September 04, 2019 Posts: 20 Location: Florida
Posted: Sat Mar 07, 2020 3:18 pm Post subject: Re: "What did you do with your Thing today"? |
Finally got the valves adjusted. Cleaned up the valve covers. Got the twin carbs synched, and got to take it for a spin. The new wheels and tires make a world of difference and it runs great! Took the grand-kids with me and they had a ball. My next project will be finding a set of side curtains. |
obus  Samba Member
obus  Samba Member
kenj06 Samba Member
Posted: Sun Mar 29, 2020 8:29 pm Post subject: Re: "What did you do with your Thing today"? |
Installed new engine compartment seals. Found a pretty good technique using a painters tool and a paint can opener. Cleaned and straightened the channel before starting
I started with the bottom of the gasket inserted in the slot all the way around. Sprayed the top of the gasket with silicone spray. Inserted the paint can opener into the upper slot.
put the painters tool under the paint can opener against the gasket, pulled down on the opener while pushing in with the painters tool. I used 2 hands to do it, I had the camera in the other hand while taking the picture.
Once I got the technique down. it went pretty quick.
Check while you are going along to make sure the bottom of the gasket is still in the channel.
I did the rear seal the same way, a little tougher but still easier than trying to slide it in the channel. At times I had to go back and finish pushing the gasket in the channel, I think it would have been easier with something a about twice the width of the paint can opener.
Another step towards being ready for summer cruising.  |
obus  Samba Member
Robert181 Samba Member
Joined: September 03, 2019 Posts: 7 Location: San Francisco, CA
Posted: Mon May 25, 2020 11:24 am Post subject: Re: "What did you do with your Thing today"? |
Pulled my stock engine and trans.
2110cc and built Limited Slip trans going in soon.
