Tore my right rear trailing arm
Big Al
Big Al is offline
PostPosted: Wed Sep 04, 2019 5:14 pm    Post subject: Tore my right rear trailing arm Reply with quote
So I removed it, and the one from my pats rail. Want to straighten the arm and just tack weld it to use on the parts rail so I can move it around. I've tried a few things but I cannot get the arm back in its original shape. There's a stamped steel plate inside the arm that's welded to the arm right where it cracked, goes to where the shock mount is welded. Anyway I can't hold the arm and keep it solid while I try to straighten it. It's stronger than it looks and heating it does not help because of the internal plate.
Tomorrow I'll get more creative, maybe clamp it to the trailer hitch on my truck so it stays put while I attack it. I thought I could just clamp it to a piece of angle iron but there are too many things sticking out of it. Like the spring arm mount, shock mount, bracket for the rubber bumper. Lots harder than I thought.
Anyone ever dealt with this?
Al
Wulfthang
Wulfthang is offline
PostPosted: Wed Sep 04, 2019 9:32 pm    Post subject: Re: Tore my right rear trailing arm Reply with quote
I had a bent one on my Trail Rail. I took it off and spent a couple of weeks experimenting with different rigs, press set ups and Rube Goldberg contraptions to try and straighten it. The only result was it scared the feces out of both my dog and me when it popped out of the jig while under lots of pressure. I gave up and bought a new set of already boxed in ones.
Big Al
Big Al is offline
PostPosted: Wed Sep 04, 2019 10:16 pm    Post subject: Re: Tore my right rear trailing arm Reply with quote
So I'm not the only one:) I just want to straighten it enough to use it on my parts rail. If I can't get it quasi straight tomorrow I'll build a dolly.
Al
Big Al
Big Al is offline
PostPosted: Thu Sep 05, 2019 10:06 pm    Post subject: Re: Tore my right rear trailing arm Reply with quote
Didn't get around to working on the torn trailing arm today. But I decided I'll never straighten it. So I'm going to cut it in half, grind the edges so it sort of fits together properly and just weld it back together. It's not going to be anything but a way to move the parts rail around.
Put the parts rail's trailing arm on the Chenowth. Looks like i need to relocate the upper shock mount. Have to come up with a way to do it. On my other rail I ground down a 1/2" nut and welded in a short piece of pipe, then welded that to the tube. Not real happy with that so I need to come up with something different.
Ideas?
Al
Wulfthang
PostPosted: Fri Sep 06, 2019 7:34 am    Post subject: Re: Tore my right rear trailing arm Reply with quote
Which side did you mess up? I may...I say MAY..have an old one that I'll let go for cheap. I see you're in Tucson. So am I.
Big Al
Big Al is offline
PostPosted: Fri Sep 06, 2019 8:43 am    Post subject: Re: Tore my right rear trailing arm Reply with quote
Right or passenger's side.
I think I know you, I'm the old guy that brings the old school sand rails to Bugtoberfest.
Last year I brought the rail that has the bad trailing arm, the three years before I brought a red one. I have 4 rails and a parts rail.
Al
Wulfthang
PostPosted: Fri Sep 06, 2019 8:31 pm    Post subject: Re: Tore my right rear trailing arm Reply with quote
Nope the right side is the one that I messed up bad too. I think I may have a stock drivers side but no passenger side for sure. Funny, mine was torn too. The whole bottom side had ripped right out of the arm. Rust had a lot to do with it.
I'm not sure if I know you. I've never been to one of the Bugtoberfests but I'm going this year. 4 rails and a parts rail! Wow! I only have my one but I lubs it! I built it as a Trail rail with extra framework and gusseting and All Terrain tires. It even has a winch on it! Mine is all done up in Woodland Camo pattern.
Big Al
Big Al is offline
PostPosted: Sat Sep 07, 2019 2:38 pm    Post subject: Re: Tore my right rear trailing arm Reply with quote
Bought one at Uncle Bob's this morning. I may buy a kit and box them. Just a lot of work as I also need to move the shock mounts.
We go out almost every Sunday, Willow Springs, Empire Ranch and Mammoth. My friends have Corvair powered rails. Mine are all VW. Red rail has a stock 1600, the one that broke the trailing arm has a ??? with a Weber carb, runs too good to be stock. We should go out sometime. I also have a 4X4 Quad that I'm trying to sell. Much easier for an old guy to get on and off:)
Al
Wulfthang
PostPosted: Sat Sep 07, 2019 8:43 pm    Post subject: Re: Tore my right rear trailing arm Reply with quote
Yeah, my trail partner has a Yamaha SXS and I get jealous when he just hops in and out. My rail is a low roof type and it's a pain for this crippled up old man to climb in and out. I built a removable steering wheel mount for it so that helped quite a bit. It's powered by a Ford 2.9 V6. Yeah, I'd like to go run some of the local trails sometime. I've been trying to find an off road club around here that travels rail style. Everybody wants to drop it into low range four wheel drive and climb over boulders!
Big Al
Big Al is offline
PostPosted: Sat Sep 07, 2019 9:48 pm    Post subject: Re: Tore my right rear trailing arm Reply with quote
We should move to email, yes?
We went here two weeks ago:
http://www.azbackcountryadventures.com/copper.htm
Al
