Fuel Gauge
John W2
John W2 is offline
PostPosted: Thu Jul 22, 2010 11:10 am    Post subject: Fuel Gauge Reply with quote
What year/month was the fuel gauge introduced to the Type 1? The bug I just purchased is registered as a 61 and it has a a fuel gauge. the VIN on the chassis and plate behind the spare match and it puts it being a Jan/Feb 61 car.
Thanks
John
PostPosted: Thu Jul 22, 2010 11:36 am    Post subject: Reply with quote
I thought it was 1962 as that is what it says in my "What year is it?" VW brochure.
http://www.thesamba.com/vw/archives/lit/64what_year.php
John W2
John W2 is offline
PostPosted: Thu Jul 22, 2010 12:38 pm    Post subject: Reply with quote
The VIN is 3630286 and our host VIN lookup states Jan 61 3628283 and Feb 61 3701251. According to that my is closer to Jan than Feb.
What month, say in 61, did the models roll off as 62 models?
Thanks
John
Helfen
Helfen is offline
PostPosted: Thu Jul 22, 2010 1:03 pm    Post subject: Reply with quote
Thanks
John
That would be September of 61 for the 62 model year in the deluxe type 113
Don
John W2
John W2 is offline
PostPosted: Thu Jul 22, 2010 1:30 pm    Post subject: Reply with quote
Interesting - I guess someone might have changed out the fuel tank and added the fuel gauge. I have not checked to see if it has the mounting for the shoulder harness, which I assume was introduced in 62.
Thanks
John
PSScoots
PSScoots is offline
PostPosted: Thu Jul 22, 2010 3:20 pm    Post subject: Reply with quote
I think you're on the right track here. Because of the modular nature of the bug dashboard, it would probably take an hour to do the whole set up.
Look at the back of your gas gauge, it should be stamped with a date in black ink (Sometimes it's hidden under lock-in bridge). In my 66, the gauge is two months older than the car.
Rebuilt to drive not decorate. -VOLKSWAGNUT
"Service the car and it will give you good service."
John W2
John W2 is offline
PostPosted: Thu Jul 22, 2010 3:45 pm    Post subject: Reply with quote
Thanks will do
kahala46
kahala46 is offline
PostPosted: Thu Jul 22, 2010 4:41 pm    Post subject: Reply with quote
I think the fuel tank changed size when the fuel gage was added
fluxcap
fluxcap is offline
PostPosted: Thu Jul 22, 2010 6:32 pm    Post subject: Reply with quote
nah, the 61 gas tank is the same size/shape as the the 62-67 tanks, but it doesn't have a cut-out for the fuel gauge sender. Fuel gauges started on July 31, 1961 at vin number 4010995, which is the beginning of the 62 model year.
Sounds like somebody just added a gauge to your car somewhere down the road in it's life. do you still have the reserve lever (or the hole where the lever would be) in the front fire wall?
Eric - 1966 camper bus
"It's like, how much more black could this be, and the answer is none.......none more black."
Helfen
Helfen is offline
PostPosted: Thu Jul 22, 2010 10:01 pm    Post subject: Reply with quote
The fuel tank was changed the year before (61) and that tank plus the ones in the standard models at least through 66 have the reserve tap. The top of the tank is the same as the 62 and above deluxe except there is a depression where the sending unit normally goes.
Don
John W2
John W2 is offline
PostPosted: Fri Jul 23, 2010 4:53 pm    Post subject: Reply with quote
thanks guys
I just bought the car and have not had a chance to crawl all over it yet. there's not a fuel shut off lever instead some kind of bolt.
John W2
John W2 is offline
PostPosted: Sat Jul 24, 2010 9:55 am    Post subject: Reply with quote
Mystery solved. Pull the gauge and the year stamped on it is '63 and it is mechanical. I did notice though that in 60-61 the fuel gauge was an option.
John W2
John W2 is offline
PostPosted: Tue Aug 31, 2010 10:09 am    Post subject: Reply with quote
Ok I just started to tear the car down. When I removed the "grill" panel with the fuel gauge I noticed that the sub-panel dash has a "factory" type cut-out for the gauge.
Did the '61 models have this cut-out in the sub-panel?
John
65'1300Deluxe
65'1300Deluxe is offline
PostPosted: Tue Aug 31, 2010 10:53 am    Post subject: Reply with quote
Yes, they did. Although at the time a different version of VDO gas gauge was available to fill the spot. It was round and electric, with an electric sending unit, like the standard type 2 version. A VDO clock was also a popular item to install there, and it had the same shape as the mechanical gas gauges introduced later.
1965 Deluxe Beetle "Camilla"
1972 Super Beetle Barnfind "Roland"
2001 GTI 1.8L Turbo
glutamodo Premium Member
The Android
glutamodo is offline
PostPosted: Tue Aug 31, 2010 1:18 pm    Post subject: Reply with quote
VW also had squre accessory electric fuel gauges to fit there as well! I know, I put one in my 62 at one point - and found the body was not cut to fit it - those accessory gauges have "ears" either side that require the opening in the body to match, and in 62 they don't have it. In 61 they did. I had to cut the body on my 62 to make mine fit.
VDO/VW had round and square accessories to fit that hole - examples:
VW tech bulletin with the square fuel gauge:
And then there was the VW tech bulleting that had them installing the round fuel gauge here:
John W2
John W2 is offline
PostPosted: Tue Aug 31, 2010 4:24 pm    Post subject: Reply with quote
That's the cutout it has - square with two, half circle cutouts on either side.
Thanks
John
vanity12
vanity12 is offline
PostPosted: Fri Sep 13, 2019 2:40 pm    Post subject: Reply with quote
Where can I get this clock.....I know Google is my friend but I've come up cold
car_cursed
car_cursed is offline
PostPosted: Fri Sep 13, 2019 3:31 pm    Post subject: Re: Fuel Gauge Reply with quote
Best bet is to post a wanted ad. I have one. Need to see how to take off the trim and remove the paint.
