Nekomorgan Samba Member
Joined: March 23, 2018 Posts: 88 Location: South Carolina
Posted: Fri Oct 04, 2019 1:16 pm Post subject: Drilling into fan shroud ok? |
Is it ok to drill a couple holes and mounting screws into the fan shroud? As long as it's not drilling into the fan/alternator backing plate. Its a black doghouse fan shroud _________________ Life is an adventure. With a VW life is an endless adventure. |
kangaboy Samba Member
Joined: August 28, 2010 Posts: 1064 Location: St. Louis, Mo
Posted: Fri Oct 04, 2019 1:20 pm Post subject: Re: Drilling into fan shroud ok? |
Perfectly fine. Lots of people mount their coils on different spots on the shroud than they were originally mounted. Some have even cut large holes in their shrouds to run their intakes for FI mods. Just use self tapping screws or run bolts through the whole shroud from one side to the other. _________________ -74 Standard - "CaliBug" 2084T, MS3X w/FI and Crank Fire
-76 Westy - "Gandalf"
-18 GTI SE
| skills@eurocarsplus wrote: |
that fucking thing looks like it drove through a J.C. Whitney catalogue and hit everything on the way out  |
Cusser Samba Member
Joined: October 02, 2006 Posts: 33420 Location: Hot Arizona
Posted: Fri Oct 04, 2019 1:23 pm Post subject: Re: Drilling into fan shroud ok? |
I've drilled into it too. Look carefully at photo below of my 1835cc engine; I drilled a hole for the return spring for my Weber 40DCNF, and to the right, near that metal fuel filter are two holes with hex head screw plugs that I used to mount the coil remotely when this engine ran dealer-installed AC.
_________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 80339 Location: Sneaking up behind you
Posted: Fri Oct 04, 2019 1:53 pm Post subject: Re: Drilling into fan shroud ok? |
Is it off or on the engine?
The oil cooler is also inside the fan shroud. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
Posted: Fri Oct 04, 2019 2:20 pm Post subject: Re: Drilling into fan shroud ok? |
| Glenn wrote: |
The oil cooler is also inside the fan shroud. |
It's on the engine. Where inside it exactly is the cooler? So I won't drill into it _________________ Life is an adventure. With a VW life is an endless adventure. |
Glenn  Mr. 010
Posted: Fri Oct 04, 2019 2:27 pm Post subject: Re: Drilling into fan shroud ok? |
| Nekomorgan wrote: |
| Glenn wrote: |
It's on the engine. Where inside it exactly is the cooler? So I won't drill into it |
It's over #3. _________________ Glenn
Member #1009
#BlueSquare
Posted: Fri Oct 04, 2019 2:29 pm Post subject: Re: Drilling into fan shroud ok? |
| Glenn wrote: |
| Nekomorgan wrote: |
| Glenn wrote: |
It's over #3. |
Ok, so it isn't close to the front face of the shroud? Cause I checked, the cooler is in the extrusion behind the shroud, exiting behind the rear tin _________________ Life is an adventure. With a VW life is an endless adventure. |
glutamodo  The Android
Joined: July 13, 2004 Posts: 26625 Location: Douglas, WY
Posted: Fri Oct 04, 2019 3:08 pm Post subject: Re: Drilling into fan shroud ok? |
One reason I eventually replaced the fan shroud on my Baja Bug was all the damn holes I had drilled in it for mounting a generator style voltage regulator onto it. The holes would wallow out over time so I'd reposition it... eventually, moving it down on top of the generator itself. The holes remained, but I did cover them with some electrical tape until I retired it.
The holes were not the only reason I changed the shroud, I wanted to try an EFI shroud with the venturi ring at the air intake side, to see if engine cooling would be better with it, as I've found that VW engines tend run rather hot at my altitude due to a lack of air density.
you can see some traces of the old electrical tape that I had removed covering the holes in this image:
_________________ Andy T.
"What is Glutamodo, Horror of Toyko, besides total, fiendish, quality-a-you brain!" |
scottyrocks Samba Member
Joined: August 19, 2016 Posts: 2987 Location: Thornton, CO
Posted: Fri Oct 04, 2019 4:02 pm Post subject: Re: Drilling into fan shroud ok? |
Here is an oil cooler, sans fan shroud, at the base of cylinder 3. Be careful where you drill.
Please ignore the tin. Not my engine. _________________ “If you care for a thing long enough, it takes on a life of its own, doesn't it? Mending old things, preserving them, looking after them – on some level there's no rational grounds for it.”
– D. Tartt, 'The Goldfinch' |
Cusser Samba Member
Posted: Fri Oct 04, 2019 4:17 pm Post subject: Re: Drilling into fan shroud ok? |
| scottyrocks wrote: |
| Please ignore the tin. Not my engine. |
And weird because such "cool tins" are typically on the bottom of the cylinders ! _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
VW_Jimbo  Samba Member
Joined: May 22, 2016 Posts: 11432 Location: Huntington Beach, CA
Posted: Fri Oct 04, 2019 4:58 pm Post subject: Re: Drilling into fan shroud ok? |
| Cusser wrote: |
And weird because such "cool tins" are typically on the bottom of the cylinders ! |
See the crate in the back ground. GEX! _________________ Jimbo
| TDCTDI wrote: |
| Basically, a whole bunch of fuckery to achieve a look. |
| 67rustavenger wrote: |
GFY's Xevin and VW_Jimbo!  |
raydog Samba Member
Joined: February 09, 2006 Posts: 1207 Location: Cape Cod
Posted: Sat Oct 05, 2019 4:50 am Post subject: Re: Drilling into fan shroud ok? |
| VW_Jimbo wrote: |
| Cusser wrote: |
See the crate in the back ground. GEX! |
Are you talking about the pallet? Why is that GEX?
Just came across another unique way of installing tin
Cusser Samba Member
Posted: Sat Oct 05, 2019 8:48 am Post subject: Re: Drilling into fan shroud ok? |
Actually, that's NOT the correct way to measure 9 or 10 ft lbs of torque !!!
Your photo shows 9 lbs 13 oz of force applied at a force arm the length of the combination wrench, technically where the hook is positioned inside the box end. If we assume that your combination wrench is 4 inches long, or 1/3 of a foot, then you are actually applying 9.8 lbs of force at 1/3 of a foot, or about 3.27 ft lbs to the nut.
