Lowdown Dirty Rat Samba Member
Joined: June 25, 2005 Posts: 892 Location: Cornwall, UK
Posted: Tue Oct 08, 2019 1:30 pm Post subject: Suicide piano hinge quarterlights. |
I’m bored, so I thought I’d write this thread on what I know about suicide piano hinge quarters as I was talking about mine at benpon gathering and again it recently came up in the Barndoor vintage photo thread.
They seem to have definitely been a factory option
On microbuses and deluxes at least.
_________________ 1951 Samba 20-017894
1952 Samba 20-028952 |
Posted: Tue Oct 08, 2019 1:35 pm Post subject: Re: Suicide piano hinge quarterlights. |
But also most probably factory on panel vans too.
And ambulances.
Posted: Tue Oct 08, 2019 1:45 pm Post subject: Re: Suicide piano hinge quarterlights. |
Notice though that there are two different types.
1. Where just the hinge has been swapped but the catch point Remains in the same location as a non-suicide quarterlight. This results in the window opening much wider then usual.
2. The hinge has been swapped but the catch point is also different. Spaced from the hinge as it is for non-suicide quarterlights ensuring they window only opens to the same degree as a normal one would.
Standard quarter on an early microbus with a fully edited deluxe suicide Quarter pictured below.
Posted: Tue Oct 08, 2019 1:54 pm Post subject: Re: Suicide piano hinge quarterlights. |
Here’s a bunch more.
Are both styles factory?
Or only the fully edited (2) type?
Are type 1 edits just aftermarket/dealer changes?
Mr. OGPaint Samba Member
Joined: September 24, 2010 Posts: 844 Location: Oregon
Posted: Tue Oct 08, 2019 9:50 pm Post subject: Re: Suicide piano hinge quarterlights. |
Thank you for sharing. I was recently sharing that I would really like to make a set of these, at the time I had no idea it had been a factory offering. Then I heard about them in the other thread and have been intrigued since. _________________ https://instagram.com/mr.ogpaint
Patrick Hall |
Posted: Wed Oct 09, 2019 2:57 am Post subject: Re: Suicide piano hinge quarterlights. |
And of course my bus 😉
Posted: Wed Oct 09, 2019 11:01 pm Post subject: Re: Suicide piano hinge quarterlights. |
Did these suicide windows exist in the same time frame as Safari windows. Have factory offerings of both been seen on one bus? _________________ https://instagram.com/mr.ogpaint
Patrick Hall |
Posted: Thu Oct 10, 2019 9:03 am Post subject: Re: Suicide piano hinge quarterlights. |
As far as I’m aware there is only evidence of one original piano-hinge Barndoor with safaris. And that was in the First factory safari fitting guide so was almost certainly the prototype/demonstration vehicle.
When the piano hinge quarter was changed, so was the A-pillar. The old A-pillar was not very conducive with fitting safaris.
The piano hinge quarter pictured with the safaris appears to be a regular non-suicide type. _________________ 1951 Samba 20-017894
djfordmanjack Samba Member
Joined: June 15, 2009 Posts: 2368 Location: Graz, Austria, Europe
Posted: Fri Oct 11, 2019 11:55 am Post subject: Re: Suicide piano hinge quarterlights. |
another point. Does anyone else think there could be a connection between the early style high mounted outside rearview mirror and the (optional) suicide style quarterlights?
I believe that the later ('53up) lower mirror could have gotten in the way of the suicide vent wings both visible and physical. _________________ Hotrods, Fords, Veedubs and Triumph Twins !
54 Oval project
62 Dickholmer, Seeblau L360
67 1500 Käfer, og paint Lotus weiß L282 w/red interior |
Posted: Fri Oct 11, 2019 1:55 pm Post subject: Re: Suicide piano hinge quarterlights. |
The quarterlight changed to the swivel type before the mirror dropped down. Dec 52s have swivel quarters and upward mirrors. _________________ 1951 Samba 20-017894
Posted: Fri Oct 11, 2019 2:10 pm Post subject: Re: Suicide piano hinge quarterlights. |
On second thoughts
Well progressive refinements suggest they changed at the same time. 20-041712
But factory photos suggest a slight lag to the mirrors. Possibly using up old stock?
chthemonkey Samba Member
Joined: July 30, 2008 Posts: 105 Location: united kingdom
Posted: Sat Oct 12, 2019 5:49 am Post subject: Re: Suicide piano hinge quarterlights. |
there's a nos quarter with the piano hinge on in the for sale section custom and commercial are selling it Im not sure how to post a like but I typed in the search barndoor light scroll down bit and its there |
olebarndoor51 Samba Member
Joined: September 08, 2015 Posts: 16 Location: germany, north
Posted: Mon Oct 14, 2019 2:11 am Post subject: Re: Suicide piano hinge quarterlights. |
ooooh my eyes hurt....the typical SA import craze. 195k....yeah. Although it presents nicely and sure has suicide vents, but there is so much wrong on this one... can't believe they used later cargo floors...ouch!
Concerning the suicide vent discussion, this bus obviously came from hot climate out of South America. _________________ Hotrods, Fords, Veedubs and Triumph Twins !
54 Oval project
Posted: Mon Oct 14, 2019 11:06 am Post subject: Re: Suicide piano hinge quarterlights. |
Style 1 (non-moved pivot).
The hot climate link would make sense. Like they are just pre-safaris.
But all the brochure buses and all the style 2 suicide quarters were on cold climate buses. _________________ 1951 Samba 20-017894
