sharkskinman Lateral Lunatic
Joined: April 26, 2006 Posts: 4053 Location: Deep In My Own Psyche
Posted: Tue Oct 22, 2019 12:20 pm Post subject: has anyone done Dual 32/36 progressives?? |
I have two of them I'm wondering if someone has a setup of them dual on a T1 upright _________________ 74 Mexi Swamp Thing. 70 square volksrod (Swamp Rat)..65 C10
| Me of Course wrote: |
| Extremity is relative to how far your willing to jump |
| Ward Cleaver wrote: |
| You ever try a pink golf ball, Wally? Why, the wind shear alone on a pink golf ball can take the head off a 90-pound midget at over 300 yards |
PS4 "NKOGNEATO" |
Lo Cash John Samba Member
Joined: February 06, 2004 Posts: 2290 Location: Jacksonville, FL
Posted: Tue Oct 22, 2019 1:33 pm Post subject: Re: has anyone done Dual 32/36 progressives?? |
Back when CB Performance was known as Claude's Buggies, they sold a dual progressive kit. I think those were slightly smaller carbs though. Anyway, that stuff pops up in the classifieds every now and then.
Search the gallery and you may find pics. _________________ www.LoCashRacing.org
Lo' Cash Racing Team on Facebook
More brains than bucks...Believe it or not!!
My boss told me I need to work on my mutli-tasking. So now when I use the bathroom at work I surf The Samba on my iPhone. |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13592 Location: Tejas!
Posted: Tue Oct 22, 2019 2:13 pm Post subject: Re: has anyone done Dual 32/36 progressives?? |
interesting, I had thought about using dual 38/38 "outlaw" DGES but never had the motor to support it. I figured the linkage would be an absolute pain _________________ Stop dead photo links! Post your photos to The Samba Gallery! |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15605 Location: Deep in the 405
Posted: Tue Oct 22, 2019 3:10 pm Post subject: Re: has anyone done Dual 32/36 progressives?? |
Waste of time. As pointed out CB made a dual progressive kit many years ago and they didn't work out very well. There just isn't any advantage over running dual IDF's. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
BFB Samba Member
Posted: Tue Oct 22, 2019 4:04 pm Post subject: Re: has anyone done Dual 32/36 progressives?? |
i asked about the same thing 6 months ago, got a couple responses about how it sucked and then mod closed the thread so no one else could reply. but before he closed it he posted an almost irrelevant link to another post a guy had who was building a dual progressive set up but it was way old and either he never finished the build or just didnt post results.
so having said that dont expect much OP, you'll most likely hear how bad the set up sucked from people who never ran it.
build it and let us know how it works! |
oprn Samba Member
Joined: November 13, 2016 Posts: 15293 Location: Western Canada
Posted: Tue Oct 22, 2019 5:28 pm Post subject: Re: has anyone done Dual 32/36 progressives?? |
Why not give it a go?
There are two things that spring to mind that it could solve. First off is it could solve the issue of poor vacuum signal for the stock vacuum pot on the distributor. The second is that it could give a much more linear throttle response than conventional dual Webers do.
It may not give you quite as much high end HP as conventional dual Webers but not everyone drives flat out 100% of the time. |
earthquake Samba Member
Joined: January 10, 2008 Posts: 4007 Location: SANDY VALLEY, NEVADA
Posted: Wed Oct 23, 2019 1:41 am Post subject: Re: has anyone done Dual 32/36 progressives?? |
What about duel Bugsprays?
eQ _________________ 74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison] |
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7976 Location: Videbaek Denmark
Posted: Wed Oct 23, 2019 2:03 am Post subject: Re: has anyone done Dual 32/36 progressives?? |
Hello.
The dual progressive set up can work well,,,,,, IF THEY ARE PROPERLY TUNED, and IF THEY ARE 100% IN SYNC! The latter is a larger problem than it sounds to be, because most linkage systems are not 100% equal all the way through the swipe. That means that especially in the area where you begin to pull from the second barrel you soon run into the fact that the engine will pull on one side but not the other.
Rewaco did some trikes with that set up years ago, and they were fine as long as they were new. As soon as the engines got a few miles under their belt and the linkage was broken in, and the carbs maybe needed just a little bit of tune up the problems began. I don´t know how many of these (awfull) trikes are in this country and northern Germany, but I have personally converted 5 of these to dual 36 IDF´s or Kadrons instead.
Bottom line is, the dual progressive set up is not recommendable. |
oprn Samba Member
Posted: Thu Oct 24, 2019 4:31 am Post subject: Re: has anyone done Dual 32/36 progressives?? |
| earthquake wrote: |
| What about duel Bugsprays?eQ |
It's been done. I had a "How to hotrod VWs" book with them on the cover, I don't recall the details though. |
H2OSB Samba Member
Joined: April 14, 2013 Posts: 1563 Location: Modesto, CA
Posted: Thu Oct 24, 2019 5:55 am Post subject: Re: has anyone done Dual 32/36 progressives?? |
| Alstrup wrote: |
Hello.
What about a cable linkage? They're pretty easy to sync.
H2OSB _________________ (o\_i_/o) Funny thing about pigs, they're cleaner than you and me. Well....you. |
sled Samba Member
Posted: Thu Oct 24, 2019 7:57 am Post subject: Re: has anyone done Dual 32/36 progressives?? |
| oprn wrote: |
| earthquake wrote: |
is this the cover you are referring to? If so, they are Weber DCN carbs...completely different and superior animal.
_________________ drive your split. |
oprn Samba Member
Posted: Thu Oct 24, 2019 4:54 pm Post subject: Re: has anyone done Dual 32/36 progressives?? |
| Right! That is the book and I recalled it wrong but I'm sure there was mention of it and pictures too. But maybe it was a different book. |
modok Samba Member
Joined: October 30, 2009 Posts: 27757 Location: Colorado Springs
Posted: Thu Oct 24, 2019 5:00 pm Post subject: Re: has anyone done Dual 32/36 progressives?? |
The manifold volume is not large enough to benefit from a progressive carburetor.
As far as the sizing and orientation of the carburetor is reasonable.
Cb made a kit.
Almost noboy running them, although the question gets asked about twice per year. Always the same answer, nothing new this year, try next year  |
oprn Samba Member
Posted: Thu Oct 24, 2019 5:22 pm Post subject: Re: has anyone done Dual 32/36 progressives?? |
| modok wrote: |
Cb made a kit.
It seems very few fellows have the patience/know how to tune a single progressive properly, can't imagine many want to tackle a pair! That could turn into a career but the results would be interesting. |
modok Samba Member
Posted: Thu Oct 24, 2019 5:48 pm Post subject: Re: has anyone done Dual 32/36 progressives?? |
| oprn wrote: |
| modok wrote: |
Cb made a kit.
by properly you mean on a pinto.
I have almost never seen one mounted "properly" on a vw.
At best it's half assed, aka, better than junk.
Glass is half full, but also half empty. I've got plenty of patience, but I can't perform miracles. |
oprn Samba Member
Posted: Thu Oct 24, 2019 6:38 pm Post subject: Re: has anyone done Dual 32/36 progressives?? |
It only took me two years to get the solex/zenith that came on my Rabbit it work properly and it did work pretty well but by then the throttle shaft bushings were getting sloppy and the idle sent south.
That said progressives were the only way to go on American iron for many decades so they do work. |
modok Samba Member
Posted: Thu Oct 24, 2019 7:38 pm Post subject: Re: has anyone done Dual 32/36 progressives?? |
when installed correctly, on a pinto
You know the reason they have so many different carburetors.....they aren't one size fits all. |
Posted: Thu Oct 24, 2019 7:58 pm Post subject: Re: has anyone done Dual 32/36 progressives?? |
| oprn wrote: |
Yes they work well on a water cooled inline 4. My brother has a Weber 32/36 on his Datsun pick up and it runs great.
They do not belong on a VW. The end castings can not flow enough to ever use the potential of the carb. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
oprn Samba Member
Posted: Thu Oct 24, 2019 8:57 pm Post subject: Re: has anyone done Dual 32/36 progressives?? |
| vwracerdave wrote: |
| oprn wrote: |
They do not belong on a VW. The end castings can not flow enough to ever use the potential of the carb. |
I will have to think about that... work on an inline 4 but not an opposed 4... hmmm...
They all fire one cylinder at a time... charge changing direction? Nope, they both do that. Displacement? Rabbit was 1600 just like the Beetle...
Is it the size of the plenum on the inline? |
modok Samba Member
Posted: Thu Oct 24, 2019 9:21 pm Post subject: Re: has anyone done Dual 32/36 progressives?? |
Float bowl forward,
Throttle blade opens in a direction so it "points" towards downstream as it's opening.
32/36 DGEV is primarily for longitudinal straight four
38 DGAS is for longitudinal v6
There is a different model of weber made for transverse straight fours. It has the float bowl theother way. Last time we discussed this i added a link to one for sale. Repeat, repeat, repeat.
I'm as INTERESTED as anybody, but.....don't have the time and motivation to r&d every possibility.
If a guy tries every kind of progressive carburtetor on every kind of manifold for it, will some work better than others?......OH YES, but, evidently nobody is INTERESTED in doing that.
Adopt a carburetor! if you don't, maybe nobody will. |
