nbturbo Samba Member
Joined: August 26, 2004 Posts: 184 Location: Australia
Posted: Fri Aug 02, 2019 6:50 pm Post subject: Re: Hot Rod Beetle Ute |
I bought a universal power window kit for this a couple of years ago.Wasn't really keen on the fitting set up.The window crank has the splined drive on it which sticks out about 40mm.Recently thought I may be able to make an ally cover which would hold the tweeter speaker for the sound system and hide the window crank.Decided that's the go.Started to fit up the winder motor.Really works well and is very smooth and quick to operate.I had already fitted the one piece window regulator.I have found some door jamb spring loaded contacts to transfer the power across.Don't know yet,because nothing will work with the door open. I bought another temp gauge with a chrome bezel to match the VW gauges.Might see if I can get the cover off and paint the needle white.
Posted: Mon Aug 12, 2019 1:18 am Post subject: Re: Hot Rod Beetle Ute |
Bent the new panel on the corners to sit tight against the dash.Painted with the hammertone finish.Another job done.
vaughn bros. Samba Member
Joined: October 13, 2003 Posts: 2395 Location: Hickory, NC
Posted: Mon Aug 12, 2019 3:17 am Post subject: Re: Hot Rod Beetle Ute |
Looks super nice.😀 |
Posted: Sun Aug 18, 2019 7:03 am Post subject: Re: Hot Rod Beetle Ute |
Update us!😀 |
Posted: Mon Aug 19, 2019 8:02 pm Post subject: Re: Hot Rod Beetle Ute |
Posted: Tue Aug 20, 2019 7:57 pm Post subject: Re: Hot Rod Beetle Ute |
I restored an Oval fuel tank for this-new 10mm supply and 8mm return and fuel guage sender for my 68 Speedo.Have now decided that it's too crowded under the hood with the air con etc, and the tank holds only about 8 gallons.Will make a new ally unit to hold maybe 15 gallons and fit it in the tray behind the cab.Cut the filler from a wreck I have.Will graft that into the driver's side of the tray.Painted the shifter cover to match all the other grey stuff.Have finished the installation of all the power window stuff to one door.Was going to make new door cards and cover with the left over stuff from the seats.Made a trial trim from aluminium and will paint it body colour.Will use some stainless body mouldings from a 1303 I have plenty off. |
Posted: Tue Aug 20, 2019 9:18 pm Post subject: Re: Hot Rod Beetle Ute |
How much fuel pressure going back to tank? 😀 |
Posted: Wed Aug 21, 2019 1:21 am Post subject: Re: Hot Rod Beetle Ute |
I have never put a guage on it.It's all standard Subaru stuff.I have made it all with the fittings used for normal air line pressure to take 150 PSI. |
rayjay Samba Member
Joined: March 26, 2008 Posts: 1507 Location: Buford GA
Posted: Tue Oct 15, 2019 10:49 am Post subject: Re: Hot Rod Beetle Ute |
Irrc that is a GM turbo hydro 180 and in Oz they use them behind v8s so there should be info around about beefing them up.
Earlier today I was looking at a t3 'ute' aka pick up. I will see if I can screen grab the pic. Super rusty unfortunately.
Posted: Mon Oct 21, 2019 8:08 pm Post subject: Re: Hot Rod Beetle Ute |
I have finished fitting the one piece glass regulator and the power window motors to the doors.Thought I might try making some polycarbonate/stainless wind deflectors like the 40's era soft top cars had.I then had some reverse pattern decals done of the early 60's VW Service Logo man .Stuck them on and grit blasted .Really pleased with it.Decided to make the door panels from 1mm aluminium and paint them.Will be the same grey I painted the arm rests.Finished the small speaker enclosures that hide the power window cranks
Posted: Sat Oct 26, 2019 2:32 am Post subject: Re: Hot Rod Beetle Ute |
I went to check on this today.It's a half hour drive.He has a bit of heat shrinking left on the back panel,a bit on the bonnet and it's not long before it comes home.He was going to finish the back of the roof today and get it in primer.I had the aluminium door panels painted this week to match the dark grey in the seats.The dash is finished other than the 2 holes I need to cut for the air gauges.
Posted: Sat Oct 26, 2019 4:52 am Post subject: Re: Hot Rod Beetle Ute |
Very nice. Door panels look perfect. 👍👍👍👍👍 |
Posted: Sun Nov 10, 2019 1:42 am Post subject: Re: Hot Rod Beetle Ute |
Got a few more jobs done on it today. All welding is finished on the cab.Need to rub the etch primer,fix any small faults the hit it with 2pac primer.I fitted a mesh Aussie sunvisor I restored a long time ago.Needed to drill the holes,sand back the swarf and then prime it all.Should have it home in a couple of weeks.Then the fun begins - building the tray.I was going to fit the 2 air guages for the suspension in the dash by the glovebox,but decided today to fit my Bud Vase there.Will make a new ally console in front of the auto shifter for the guages and the 4 air bag switches.
Posted: Sun Nov 10, 2019 2:31 am Post subject: Re: Hot Rod Beetle Ute |
Looks factory. Very nice.. |
Posted: Sun Nov 10, 2019 3:22 am Post subject: Re: Hot Rod Beetle Ute |
Thanks. That’s was the plan and hoped when finished it would look factory.It has turned out pretty good. |
EverettB Administrator
Joined: April 11, 2000 Posts: 69837 Location: Phoenix Metro
Posted: Sun Nov 10, 2019 2:03 pm Post subject: Re: Hot Rod Beetle Ute |
I cut the rear roof section from a Bay window to graft in.Just couldn't get it to look OK.I had several attempts to roll material,but couldn't get it either.Had a brainwave-close the rollers up real tight at one end.Worked.So did 2 pieces and joined in the middle.My number one request-it had to have a drip gutter along the back.Box ticked. |
Posted: Sun Nov 10, 2019 2:04 pm Post subject: Re: Hot Rod Beetle Ute |
EverettB wrote: |
Roof looks clean!
It looks very similar to my Double Cab rear cab roof |
Where will I go to see pics of it? |
Posted: Sun Nov 10, 2019 11:29 pm Post subject: Re: Hot Rod Beetle Ute |
Thanks for the pic.I found a couple of good shots of the back of the roof on your Bus.I only had VW Bus roofs to use as examples.I have a Splitty and Bay Window here to check on.The dual cabs pics are of standards roofs-correct.If I could have found a Splitty Dual Cab,I would never have started this project.It would have got the same treatment though-Suby engine,Bus auto trans,air bag suspension etc,etc.I am doing an auto trans conversion in a 63 Bus at the moment.IRS conversion done.Using all Type 3 suspension arms,but I used the Bus spring plates and torsion bars.Made a jig from a Type 3 spring plate.Just tak weld it to the bus one to drill the holes and cut the length with a 5inch.Fitted a 69 Bay front beam.Going to fit dropped spindles and put later disc brakes on.Will keep the rear drum brakes,but get some new drums with 5X112 pattern. |
