alaskadan Samba Member
Joined: January 09, 2013 Posts: 1949 Location: anchor pt. alaska
Posted: Fri Nov 15, 2019 8:48 pm Post subject: Re: Post Your Roof Rack Setup |
Assuming you knew the people with the twin westy at the front of ferry? |
SyncroHead Samba Member
Joined: May 23, 2005 Posts: 1160 Location: Northern Nevada
robcass Samba Member
Posted: Mon May 11, 2020 3:30 pm Post subject: Re: Post Your Roof Rack Setup |
Anyone know what the suggested max weight on a rack would be for a set up with gutter mounts drilled directly into the Westy Fiberglass Pop top? Mine are the 2 hole Thule kind. I was wanting to transport 110 lbs. Worried that I may crack the poptop. Thoughts? |
vanis13 Samba Member
Joined: August 15, 2010 Posts: 4531 Location: ABQ NM USA.... Except when not
Posted: Mon May 11, 2020 3:53 pm Post subject: Re: Post Your Roof Rack Setup |
robcass wrote: |
you should be fine. I've had HUNDREDS of pounds up there though I have the Yakima with 4 holes. the load is vertical so it should be strong enough in either case _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
www.SuperVanagon.com - some stuff I make |
Thor-bob  Samba Member
Posted: Thu May 21, 2020 12:50 pm Post subject: Re: Post Your Roof Rack Setup |
I found these pix in an album....... been meaning to share.
We used to hang glide in the Owens Valley in the '80's, and I made a box to carry the glider on the Vanagon. The gutter brackets were Quik N Easy brand.
Big thing: The front bracket had horrible wind roar from the 2" square cross tube, so I cut a piece of cardboard shipping tube in half and taped it to the front - the roar disappeared!
The nose cone was just for grins - it was cheapy plywood cut and curved, attached to internal ribs, then glassed and painted. Amazingly, the mileage dip was barely noticeable, maybe 1 MPG or so.
Also - The large overhang at the back end made the van immune to crosswinds, and it was very pleasant to drive.
Good times.
Thor-bob
Posted: Thu May 21, 2020 1:28 pm Post subject: Re: Post Your Roof Rack Setup |
Love it! Looks like you're on you way to install an alien space beacon somewhere!
Jim _________________ "A Vanagon? It's not a car or a van. It's a hobby!"
Check out:
www.VANAVATION.com
www.SyncroSafari.org and
www.Vanagons.org
sphet wrote: |
I have *no* idea what the previous owner carried in his Westy... angry donkeys? |
Posted: Thu May 21, 2020 1:31 pm Post subject: Re: Post Your Roof Rack Setup |
Here's a look at my next rack setup I've been working on. Almost ready for debut. Hopefully details in a couple weeks.
Jim Davis
PS: Eric - I need a new TerraWagen sticker  _________________ "A Vanagon? It's not a car or a van. It's a hobby!"
Check out:
www.VANAVATION.com
www.Vanagons.org
sphet wrote: |
jimf909 Samba Member
Posted: Thu May 21, 2020 1:35 pm Post subject: Re: Post Your Roof Rack Setup |
^^^ That looks like a sweet rack. Is this a custom build or a modular rack system from a vendor? Which vendor? Thanks. _________________ - Jim
Butcher wrote: |
This is the main fault with DIY'ers, they get together on these forums and pat themselves on their backs spreading bad information. |
Guilty as charged.
Posted: Thu May 21, 2020 6:00 pm Post subject: Re: Post Your Roof Rack Setup |
Neither exactly. It's a rack made specific for a Vanagon. The fabricator makes other racks, each with dimensions (height, length, width) and specifics (mounting supports, Etc.) for a particular rig. Specs for this one are all tailored for a Vanagon hard-top and Doka. One half-length rack can be used perhaps if you have something else to place on part of the roof, or for a DoKa. Or, if you want to maximize rack space, two are joined together to cover the entire roof area. We're working out the details on this installation before it will be offered for general sale. Stay tuned...
Jim Davis _________________ "A Vanagon? It's not a car or a van. It's a hobby!"
Check out:
www.VANAVATION.com
www.Vanagons.org
sphet wrote: |
moodgenic Samba Member
Posted: Sun Feb 06, 2022 7:31 am Post subject: Re: Post Your Roof Rack Setup |
Hi!
Can you help me and give me the reference for this roof rack was please? From front runner or other?
Thanks in advance
Best |
1988M5 Samba Member
Joined: January 23, 2016 Posts: 848 Location: Tucson, AZ
Posted: Sun Feb 06, 2022 7:57 am Post subject: Re: Post Your Roof Rack Setup |
Thor-bob wrote: |
Good times.
Thor-bob
" The gutter brackets were Quik N Easy brand" Sweet, I still have a new set of 4 in a box..
To all the Vanagon folks on the fence about adding a roof rack...the job of washing your truck will forever be changed.
BK _________________ 1991 tin top GL
Some BMWs. |
