VEGDRABBITS Samba Member
Joined: February 07, 2006 Posts: 56 Location: Saint Paul, MN
Posted: Sun Dec 16, 2012 8:07 pm Post subject: |
Sorry Don, I threw it! I kept it for a while and thought about selling it, but wasn't sure it should be reused. I feel bad for breaking the rule of never throwing a VW part, but with only a one car garage I have to purge every year or so. _________________ 70 Convertible
73 RD350 |
Cusser Samba Member
Joined: October 02, 2006 Posts: 33510 Location: Hot Arizona
DStar Samba Member
Posted: Mon Dec 17, 2012 5:55 am Post subject: |
That's OK, I understand. I had to give away thousands of VW parts when I moved back home from Germany last yr. Sold some but gave away most to keep from chunking them in the recycle bins.
And yes, a tacking strip can be purchased but I just don't know about nailing into rubber, doesn't seem like rubber and longevity go together on our VWs!
I'll probably end up buying a wood one.
Don |
brotherbob Samba Member
Joined: July 10, 2004 Posts: 367 Location: millsap texas
Posted: Sat Jan 12, 2013 7:40 am Post subject: |
I just want to thank you for this series of posts. I just got my 70 top put on last night and this post was my "go to" reference.
THANK YOU.
BB _________________ In wine there is wisdom , in beer there is freedom , in water there is bacteria ! |
Marleybus Samba Member
Joined: January 05, 2013 Posts: 314 Location: Oro Station, Ontario, Canada
Posted: Fri Jan 19, 2018 6:58 am Post subject: Re: 1970 Convertible top rebuild |
This thread is saving my ass. I am in the final phases of installing my new top on my 1969 Vert. I have been thinking and over analysing this install for 6 months. I will post when done. thanks _________________ 1972 VW Westy (Hit by dumptruck)
1963 VW Beetle (RIP)
1974 VW Beetle (RIP)
1981 Vanagon Westfalia (Sold)
1969 VW Beetle Convertible (Wifes)
1977 VW Westy 2.0L FI Chrome Yellow
1978 VW Westy 2.0L FI (Under Restoration)
1973 VW Westy 1.7L Tourist Delivery Orange
Check out my thread!!http://www.thesamba.com/vw/forum/viewtopic.php?t=556709 |
pgtips Samba Member
Brewsbrother Samba Member
Joined: November 09, 2019 Posts: 4 Location: Chapel Hill, NC
Posted: Sun Dec 15, 2019 11:59 am Post subject: Re: 1970 Convertible top rebuild |
I've really enjoyed going through the series of posts and have a question that will probably require a more complicated answer than I'm hoping for. I acquired a 1972 European Beetle convertible and the front of the top doesn't reach over the windshield frame sufficiently to seal. I don't know where to start on readjusting or replacing parts to solve the issue and could use some seasoned expertise.
Boble Samba Member
Joined: November 13, 2005 Posts: 744 Location: Oslo, Norway
Posted: Sun Dec 15, 2019 12:28 pm Post subject: Re: 1970 Convertible top rebuild |
Hi. A little difficult to diagnose the case from the pictures. Is it the frame that is not 'pulled down' properly?
Maybe this good page may help to explain how it's supposed to be:
http://vwlinkan.se/cab/cabrio/newtop/newtop1.html |
Cusser Samba Member
Posted: Sun Dec 15, 2019 2:19 pm Post subject: Re: 1970 Convertible top rebuild |
Not sure how to "pull down" more than it already is, but I will study the link you posted and see what I can learn.
Eric
Posted: Sun Dec 15, 2019 2:21 pm Post subject: Re: 1970 Convertible top rebuild |
| Cusser wrote: |
| Is this a new top or old top? Because a top can shrink. |
The top seems immaculate, but I was told the car had undergone a restoration 15 yeas ago. Is there a solution for a shrunken top, short of replacement?
Thanks,
Eric |
CarlIseminger Samba Member
Joined: May 12, 2008 Posts: 842 Location: Grand Forks, ND
Posted: Fri Dec 20, 2019 12:23 pm Post subject: Re: 1970 Convertible top rebuild |
Even just putting the top down can cause it to "shrink" a bit. If I leave mine down for over a day, it is hard to latch. So I make sure to put the top up at the end of every drive.
But when it seems to be a bit too much, I leave it out in the sun, up but not latched, until it is nice and warm, then slowly pull it down until I can get the hooks into the notches. Then I let it sit some more before I fully latch down. _________________ 1969 VW Beetle Convertible |
Cusser Samba Member
Posted: Fri Dec 20, 2019 1:52 pm Post subject: Re: 1970 Convertible top rebuild |
| CarlIseminger wrote: |
| I leave it out in the sun, up but not latched, until it is nice and warm, then slowly pull it down until I can get the hooks into the notches. |
That's what I do if it's cooler than 80F. Doesn't take too long to warm a top in Arizona !! _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
ncpi Samba Member
Posted: Fri May 15, 2020 4:31 pm Post subject: Re: 1970 Convertible top rebuild |
Fantastic Thread!!! Thanks for posting. I'm sure I am going to be referencing this a lot!
I just bought a '74 Super Beetle Convertible that needs a top. I have never seen a worse top on anything Even the frame has corrosion perforations. The car looks good at 10', there's a decent boot covering the top. Of course I want to tackle the top...after reading this I am starting to think that boot looks just fine! I have done few tops on British sports cars, they are easy peasy compared to this job. |
ImaBugNut Samba Member
Joined: November 25, 2019 Posts: 7 Location: Old Hickory TN
Posted: Tue May 26, 2020 1:28 pm Post subject: Re: 1970 Convertible top rebuild |
I want to echo the positive sentiments expressed by other readers. I am an old man but relatively new to the Bug Life and I enjoy it immensely. We have two 71 Supers. I began in this hobby years ago with a 1931 Model A ford that needed everything. 3 1/2 years and lots of late nights later it ran great. That car was completed in 1987 and I still drive it (though not as much as we used to)
I am one of those guys that likes to do it all myself if at all possible. I am blessed to have a fine shop with exhaustive tooling for wood and metal work.
Now to my questions?
We just bought a 1971 Super Vert with a bad top. The top frame is frozen but that is the least of my issues. I know the wood parts are available from Chuck and I will probably go to him for most of the top materials. I have the tools and possess the ability to make almost anything from wood if I have a drawing or pattern. I am inspired by "Cusser's" pictures of his self made parts.
I know the wood parts are expensive and I would like to make them myself. I have large wood working machinery including planers, bandsaws and large CNC machines. I also have a steam bender if needed. If I had a 3d scan it would be a simple process. If I had a pattern, I could reproduce it, but I do not.
Does anyone have a pattern for the wood parts in a convertible top? Mine are quite far gone and any measurements would be appreciated. I will gladly share any information I can glean with any interested bug owner. Perhaps we could share information and I could build an extra set as I go. I have all the proper hardwoods I just need information. |
Cusser Samba Member
Posted: Mon Jun 01, 2020 4:59 pm Post subject: Re: 1970 Convertible top rebuild |
Thanks Cusser. I studied your pictures carefully and I do not think I will have a problem making the rear window wood. I have enough of it left in pieces to use as a pattern. My real concern is the two pieces on the sides where the hinges meet the frame. hopefully some of these really VW smart folks can give me some ideas.
I have plenty to do in the meantime because I have discovered a bunch of electrical issues I am working my way through. 50 years of shade tree mechanics can really mess with a good wiring harness!
7/21/2020 update:
I have decided to make all of the wood parts myself. I will make detailed drawings and measurements of the parts and create a set of templates and patterns. This will take awhile but I am quite confident that I can make it happen. I have a lot of experience in making things like this. Perhaps someday when I am finished I will post the pictures and drawings of the parts to this forum.
If anyone else is interested in helping, we could split up the tasks to speed the process of producing the patterns. I own large CNC machines and lost of drawing software. What I need is a wood parts set in better condition than the one I have to take measurements from. I can do it with what I have but it will be more tedious. |
Posted: Fri Oct 30, 2020 10:28 am Post subject: Re: 1970 Convertible top rebuild |
An update on self building the wood parts for the convertible top.
It is turning out not to be as difficult as I thought it might be. I glued up some oversized blanks of oak (I planed some flooring until it was uniformly flat) I then cut cardboard as a patttern that I fit to the car until I was satisfied with the curveture of the pattern. Transfered the pattern to the wood and cut it on a bandsaw. I was able to shape the wood on a belt sander until the fit was virtually perfect. On one piece I shaved off too much. I just shaved a flat spot with a hand plane and I glued on another chunk of wood then repeated the forming process until I was happy with the fit.
I will tackle the bows next but I am confident this task is easly within the capability of anyone that has a bandsaw and good bottle of Titebond 3 glue. I will post pictures when I get further along. My total cost of the wood bows will be less than $30 counting wood and glue.
Our hobby has its rewards and I am glad that I decided to build them and not just buy the parts. It is less about the money, though over $1000 for a set of bows seems excessive, For me it is about the pride we take in our craft
Cusser Samba Member
llamadaddy Samba Member
Joined: January 08, 2015 Posts: 3 Location: United States
Posted: Thu Mar 18, 2021 4:11 pm Post subject: Re: 1970 Convertible top rebuild |
I am looking for some help with a 1969 Convertible top install. Can anyone tell me the specifications for the six bolts (3 each side) used to attach the convertible frame to the body?
The long version of this story is that I took the car to be professionally painted. Half way through the job, the fellow doing the work had a heart attack. He had taken the top off the body and the body off the frame in order to paint it. About two years later I got the car back nicely painted but in pieces. I spent the last several years putting it all back together, replacing the engine, rewiring the whole thing - with lots of help from this forum. The painter did a pretty good job bagging and labeling all of the parts he took off. But, the convertible frame to body bolts are no where to be found. I am in the home stretch, but none of my old parts catalogs tells me the size of the bolts. They are not even depicted on the parts diagrams.
To be fair, I have found a couple of places on line that sell them for about $3.00 per bolt (plus shipping). There is a fastener specialty shop in town that generally has anything I want. My experience has been I'll get all six plus the lock washers for less than a single on-line bolt. I am definitely nuts about this car, but that kind of mark up is enough to bring even me back to my senses!
thanks, |
