Terry Gaudet Samba Member
Joined: March 11, 2004 Posts: 400 Location: New Brunswick, Canada
Posted: Wed Dec 25, 2019 12:18 pm Post subject: 356 brakes - 52 Barndoor |
Hey there,
Looking to put either A or B brakes on my ride. I have both in stock and ready to go.
My bus has a later style custom narrowed 55-63 front beam which is ok.
The rear trans is a T-1 62-65 style with short axles and bolts right in. I was going to use later model T-3 backing plates and early T-3 drums with 5/8" machined off the snout, but 356 brakes will be the goal.
I know the rear will be easy bolt on, but can I get some sort of bearing or sleeve to mount up the drums? _________________ Terry Gaudet
1950 Beetle Standard
1955 Canadian Custom
1956 Kombi w/SO23 kit
1965 Kombi walkthrough
1965 Double Cab |
western auto Samba Member
Posted: Wed Dec 25, 2019 12:58 pm Post subject: Re: 356 brakes - 52 Barndoor |
10 foot doug has the answers you seek.... |
Mr. OGPaint Samba Member
Joined: September 24, 2010 Posts: 844 Location: Oregon
Posted: Thu Dec 26, 2019 12:11 am Post subject: Re: 356 brakes - 52 Barndoor |
I have 356B brakes front and rear on my 53 Kombi with T-1 shortaxles. What wheels are you planning to run? These huge brakes together with flat rear wheel wells have made installing rear tires/wheels more difficult than on any lowered bus I’ve ever had. _________________ https://instagram.com/mr.ogpaint
Patrick Hall |
Posted: Thu Dec 26, 2019 10:02 am Post subject: Re: 356 brakes - 52 Barndoor |
I will be running original 356 steel wheels as well as a 356 S-90 motor.
Guess i'll contact 10-foot Doug....;0) _________________ Terry Gaudet
1965 Double Cab |
Posted: Thu Dec 26, 2019 10:08 am Post subject: Re: 356 brakes - 52 Barndoor |
Tried searching for contact info on 10 ft Doug and wasn't able to. Anyone out there who has this, please message me details. Thank you so much. _________________ Terry Gaudet
1965 Double Cab |
PeteSC Samba Member
Posted: Thu Dec 26, 2019 8:41 pm Post subject: Re: 356 brakes - 52 Barndoor |
Should work easily well with your stock wheels. Doug did an article in Hot VWs regarding his brake install on stock BD running gear _________________ https://instagram.com/mr.ogpaint
Patrick Hall |
Posted: Fri Dec 27, 2019 4:37 pm Post subject: Re: 356 brakes - 52 Barndoor |
I have read the article, but it seems that my later split bus front beam might cause some issues. The backing plate won't bolt on and the bearings are not compatible.
Sent a message to Doug, waiting for a reply. _________________ Terry Gaudet
1965 Double Cab |
EmpiGT Samba Member
Posted: Fri Dec 27, 2019 5:02 pm Post subject: Re: 356 brakes - 52 Barndoor |
The split bus spindles make it harder. I tried. You have to find just the right bearings and races to do it. I have them in my garage somewhere from the attempt. And then you have to run a spacer/ adapter between the backing plate and spindle surface for the backing plate to mount. The far easiest way is to build a barndoor beam and run kingpin beetle spindles(they fit with machine work or spacers made). Then the front brakes and stock beetle bearings are a direct bolt on. |
Posted: Sun Dec 29, 2019 5:17 am Post subject: Re: 356 brakes - 52 Barndoor |
Thanks EmpiGT. I will give that a try. _________________ Terry Gaudet
1965 Double Cab |
djfordmanjack Samba Member
Joined: June 15, 2009 Posts: 2368 Location: Graz, Austria, Europe
EmpiGT Samba Member
Big_E_Deluxe Samba Member
Joined: September 23, 2013 Posts: 286 Location: Charlotte, NC
Lind Samba Member
Joined: November 06, 2000 Posts: 10227 Location: idaho
Posted: Mon Feb 03, 2020 7:34 am Post subject: Re: 356 brakes - 52 Barndoor |
Big_E_Deluxe wrote: |
Mr. OGPaint wrote: |
Should work easily well with your stock wheels. Doug did an article in Hot VWs regarding his brake install on stock BD running gear |
Any idea what HotVW's issue this article was in? Thanks! |
It is in one of the previous issues that you get access to with a digital subscription.
https://hotvws.com/ _________________ .
Wanted:
