Foam filter sputter
busey
busey is offline
PostPosted: Sat Dec 28, 2019 7:15 pm    Post subject: Foam filter sputter Reply with quote
Finally had my 48 IDA powered 2275 running smooth until i decided to add Jaycee foam stack filters today. Idle is smooth, BUT sputters upon acceleration on thru the mid-range, and will smooth out again when i pedal to the metal it. I take the filters off and it runs smooth again Dancing
H - E_ L - P !
I could just run without air filters but Phoenix Arizona is so damn dusty and rocky that i worry some crap will make its way in the motor thru the stacks. Crying or Very sad
No turning back now, "Its Blow thru or No thru" baby!
sled
sled is offline
PostPosted: Sat Dec 28, 2019 7:39 pm    Post subject: Re: Foam filter sputter Reply with quote
stack filters are known to be quite restrictive, which is probably changing your jetting. The best situation is to run full size filter elements around the velocity stacks.
drive your split.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Sat Dec 28, 2019 7:42 pm    Post subject: Re: Foam filter sputter Reply with quote
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
busey
busey is offline
PostPosted: Sat Dec 28, 2019 7:51 pm    Post subject: Re: Foam filter sputter Reply with quote
That does remind me that a few years ago there were some air filters on the market that were not of the foam variety but more like regular air filters that ran individually off the stacks at abit of an angle. Think
busey
busey is offline
PostPosted: Sat Dec 28, 2019 7:54 pm    Post subject: Re: Foam filter sputter Reply with quote
Glenn wrote:
Those look like foam as well. Are those restrictive to the point that they throw off your jetting?
Mr. 010
Glenn is offline
PostPosted: Sat Dec 28, 2019 7:59 pm    Post subject: Re: Foam filter sputter Reply with quote
https://www.thesamba.com/vw/classifieds/detail.php?id=675767
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
busey
busey is offline
PostPosted: Sat Dec 28, 2019 8:24 pm    Post subject: Re: Foam filter sputter Reply with quote
That might just be the fix! Thanks
oprn
oprn is offline
PostPosted: Sat Dec 28, 2019 9:16 pm    Post subject: Re: Foam filter sputter Reply with quote
Perhaps not all Webers are like this but my Webers take air in for the idle circuit from between the stacks. The idle jets would quickly plug with road dust using those filters.
HBRag
HBRag is offline
PostPosted: Sat Dec 28, 2019 10:00 pm    Post subject: Re: Foam filter sputter Reply with quote
Restrictive or not, the AFR will change with and without filters. I have the traditional CB style filters, and the AFR goes lean without them. I’d expect to have to re-jet with them on. Do you have an AFR meter?
busey
busey is offline
PostPosted: Sun Dec 29, 2019 8:43 am    Post subject: Re: Foam filter sputter Reply with quote
I Don't, but i have read that Aircooled.net rents them out. So that will be the next tweak to make with filters On, since the motor is just about broken-in and got her to run consistently smooth thruout the power band w/filters Off AND even without a 3rd progression hole Shocked Shocked Shocked
67rustavenger
67rustavenger is offline
PostPosted: Sun Dec 29, 2019 9:03 am    Post subject: Re: Foam filter sputter Reply with quote
ACN does not rent that tool any longer.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
busey
busey is offline
PostPosted: Sun Dec 29, 2019 9:57 am    Post subject: Re: Foam filter sputter Reply with quote
Sad Ah Damn! Thanks for the heads up.
jeffrey8164
jeffrey8164 is offline
PostPosted: Sun Dec 29, 2019 10:41 am    Post subject: Re: Foam filter sputter Reply with quote
They don’t rent them anymore because they are relatively inexpensive now.
Sub $200.00
Volkswagen!
(Compression 8.7:1)
RailBoy
RailBoy is offline
PostPosted: Sun Dec 29, 2019 2:47 pm    Post subject: Re: Foam filter sputter Reply with quote
None Oiling and Synthetic I do Believe, R2C's..... Been running mine now for 4,250 Miles......
http://www.r2cperformance.com
RB
[quote="smitty24"]"HELP, I ported my own heads and now have fire coming out my ass" .[/quote]
Shocked
UK Luke 72
UK Luke 72 is offline
PostPosted: Sun Dec 29, 2019 3:40 pm    Post subject: Re: Foam filter sputter Reply with quote
They look good railboy.
2276 Beetle build https://www.thesamba.com/vw/forum/viewtopic.php?t=670744&highlight=2276+beetle+daily
2276 EFI Conversion https://www.thesamba.com/vw/forum/viewtopic.php?t=689172
RailBoy
RailBoy is offline
PostPosted: Sun Dec 29, 2019 3:43 pm    Post subject: Re: Foam filter sputter Reply with quote
Yea, I think so as well.... It is a street car so can't be so bad with dust and all...
If I do blow them out, it would be from the inside out of course with just lightly canned air...
But they have not come off and cleaned yet, knock on wood, lol..
Kinda a test... RB
Shocked
busey
busey is offline
PostPosted: Sun Dec 29, 2019 5:51 pm    Post subject: Re: Foam filter sputter Reply with quote
Question, rarely are 48 IDAs equipped with any kind of filtering even on the street. Can't be that bad to run them as they have been for many many decades, ie w/OUT filters???
66brm
66brm is offline
PostPosted: Sun Dec 29, 2019 5:54 pm    Post subject: Re: Foam filter sputter Reply with quote
I would never run an engine on the street without filters, track and dyno are different
Aust. RHD 66 Type 1
Aust. RHD 57 Type 1 Oval
modok wrote:
I am an expert at fitting things in holes, been doing it a long time
67 Sunroof
67 Sunroof is offline
PostPosted: Sun Dec 29, 2019 7:43 pm    Post subject: Re: Foam filter sputter Reply with quote
Man, GREAT idea with the springs holding the wingnuts on the air filters! I’m gonna do that to mine as well. Motor looks great man! Glad it is still running great for ya!
Kinda a test... RB
1776cc, CB crank, CB 2241 cam, CB light lifters, CB H-beam rods, CB light flywheel, Mahle forged pistons, A1 Sidewinder exhaust, Dellorto drla 40’s, Hoover modded case, fully balanced, fully flowed, heads by www.type-emotorsports.com, Air ride suspension by https://www.airkewld.com/?Click=3989
RailBoy
RailBoy is offline
PostPosted: Mon Dec 30, 2019 5:02 am    Post subject: Re: Foam filter sputter Reply with quote
Thanks Roof, yea be careful drilling, I used both a hand held drill for two of the holes before I remembered I had a drill press at the location I was at doing it, both ways you could see the bit flexing, but did not break it during the drilling, vey small bit.. lol... RB
Shocked
