solex overhaul
sinclair
sinclair is offline
PostPosted: Thu Jan 02, 2020 11:50 am    Post subject: solex overhaul Reply with quote
I thought I'd overhaul a 26 VFIS.The home zinc plating kit was a gem.
T2_681
T2_681 is offline
PostPosted: Thu Jan 02, 2020 12:30 pm    Post subject: Re: solex overhaul Reply with quote
Home zinc plating kit?
sinclair
sinclair is offline
PostPosted: Thu Jan 02, 2020 12:34 pm    Post subject: Re: solex overhaul Reply with quote
A bit amateur but yes, and fantastic results. https://classic-plating.co.uk/product/zinc-plating-kit/
T2_681
T2_681 is offline
PostPosted: Thu Jan 02, 2020 12:48 pm    Post subject: Re: solex overhaul Reply with quote
I would never think of doing this at home.
How did you enhance the carburetor body?
sinclair
sinclair is offline
PostPosted: Thu Jan 02, 2020 2:52 pm    Post subject: Re: solex overhaul Reply with quote
Luckily I have access to an industrial bead blaster.
T2_681
T2_681 is offline
PostPosted: Thu Jan 02, 2020 2:59 pm    Post subject: Re: solex overhaul Reply with quote
I used the same proces with less good results - the zinc alloy is still relatively dark.
rod_vw
rod_vw is offline
PostPosted: Thu Jan 02, 2020 4:13 pm    Post subject: Re: solex overhaul Reply with quote
It looks superb, a credit to you.
Did the plating have any effect on the threaded parts / clearances?
Rod,
Please visit http://www.historicvws.org.uk
https://www.facebook.com/historicvwclub/
1946 Beetle (Back on the road after over 50 years! Last major outing - Hessisch Oldendorf 2022)
LWB MAN TGE Camper.
sinclair
sinclair is offline
PostPosted: Fri Jan 03, 2020 2:33 am    Post subject: Re: solex overhaul Reply with quote
Thanks. No dimentional change, all fitted beautifully.
sinclair
sinclair is offline
PostPosted: Fri Jan 10, 2020 1:55 pm    Post subject: Re: solex overhaul Reply with quote
In my experience you might have the amps too high.
T2_681
T2_681 is offline
PostPosted: Fri Jan 10, 2020 2:39 pm    Post subject: Re: solex overhaul Reply with quote
I mean blasting.
[email protected]
JERRY63VW@YAHOO.COM is offline
PostPosted: Mon May 18, 2020 8:55 pm    Post subject: Re: solex overhaul Reply with quote
Can anyone help im looking to buy some vfis 26 and 28 carbs but the seller took them apart for some reason years ago and found most of the parts but he lost the floats...are the solex 28 pci floats the same i know they make repops of those ????
