Bay Window 2nd Gear Grind
RomStrom
RomStrom is offline
PostPosted: Tue Jan 07, 2020 12:59 pm    Post subject: Bay Window 2nd Gear Grind Reply with quote
Hello all, first-time post here at TheSamba and unfortunately under some quite frustrating circumstances. Please bare with me as there is a lot to explain and I am at a total loss for what could be causing this issue.
What: My 1978 Bay Window with a recently inspected/resealed 091 transaxle and rebuild Type 4.
Problem: Shifting up or down into 2nd gear (and only in 2nd gear) causes a non-stop grinding noise, even without the clutch engaged (clutch pedal down). This grinding occurs at the second I enter 2nd gear (once it begins I can release the clutch pedal and enter 2nd. If I am just short of the grinding "region", releasing the clutch pedal leaves me in neutral)
Brief History: Originally got the bus 2 years ago, where it was used very frequently before. No such shifting issues existed prior except for getting into 3rd, which required you to hit a certain spot (I called it the three-spot) which otherwise would result in grinding, and reverse gave grinding noise.
Pulled engine and trans, did a full engine rebuild and also took apart the trans with the help of (what I believe to be) one of the few VW Transaxle experts in the state of Texas*. According to him, gears and synchronizes looked in good shape. However, reverse gear teeth were heavily chewed on one side, see Figure 1. The shavings were present on the magnetic drain plug.
I replaced the reverse gear, gaskets, seals, lubricated everything properly, and put in new trans fluid (essentially a re-seal, proper reassembly of transaxle done with above mentioned expert). Also replaced clutch arm spring and all the bushings that arm shaft uses which are contained in the bell housing. Also replace all nosecone "shifting" components, including the hockey stick, the plastic ball with a steal alternative, etc. Essentially all the steps outline in Ratwell's 091 Transmission Refresh article here https://ratwell.com/technical/091Transmission.html.
Also rebuilt the entire linkage, put in new bushings all throughout, new boots, new coupling set, and lubricated the shaft. Also had the flywheel resurfaced, throw-out bearing replaced and pressed into the flywheel, adjusted flywheel endplay.
Upon first drive, no more issues with 3rd and reverse, but the grinding of the 2nd gear as described above had begun.
What I've Tried Since: - Adjust my clutch free-play. Got it between 1" - 1 1/2" when pushing with one finger, the pedal feels smooth and the clutch "catches" at an appropriate distance.
- Reinstalled my clutch stop plate properly as in Figure 2, shifting feels more correct now but same problem remains
- Adjusted shifter position on the front floor panel & tried several configurations, all with same 2nd gear grinding issue
- Approach 2nd gear from several different angles, all successful entries into 2nd result in grinding noise.
I have searched through several forums and posts here on thesamba but haven't had any luck. My thoughts lean towards the sychronizer, however it seems strange that this issue arose now where it was non-existent prior to the work mentioned above (at least I can't imagine the reseal would cause an issue like this). I was going to purchase a better shifter, though I feel like this stock one does the job well aside from 2nd.
Any insights would be greatly appreciated!
- Roman
* He has been working on VW Transaxles for over 40 years and supplies several bug/bus shops in Texas with rebuild transaxles. Also specializes in racing transaxles. He is a reputable source from what I've heard from several people.
Figure 1:
Figure 2:
1992 VW Mexican Combi Bus
1978 VW Transporter
SGKent Premium Member
SGKent is offline
PostPosted: Tue Jan 07, 2020 2:05 pm    Post subject: Re: Bay Window 2nd Gear Grind Reply with quote
if you used gl5 fluid and the 2nd gear synchro was moly coated you made it too slippery to grab and synchronize. If you had the gear carrier out then did you make any other changes to it, and did you use the shifter jig plate to check the alignment on all the shifter forks?
Did you lube the pilot bearing and make sure the clutch disk slides on the input shaft smoothly?
RomStrom
RomStrom is offline
PostPosted: Tue Jan 07, 2020 6:43 pm    Post subject: Re: Bay Window 2nd Gear Grind Reply with quote
Howdy, glad to pick you brain on this. I've gotten much needed information from your past postings sir.
- I did in fact use 80W90 gl5 gear fluid.
- No changes to gear carrier while out.
- Alignment of shifter forks not verified with jig plate. My transmission guy just gave an overview of everything on the gear carrier
- Pilot bearing was lubed before I connected the transmission to the engine
Would changing to a non-gl5 non-"slippery" oil do this situation any good? Or does the tranny likely need to be opened again?
1978 VW Transporter
Wildthings
Wildthings is online now
PostPosted: Tue Jan 07, 2020 8:16 pm    Post subject: Re: Bay Window 2nd Gear Grind Reply with quote
My experience says that once you use the wrong GL-5 oil in one of these gear boxes then the only real fix is to go back in and replace the damaged synchronizers. There is a lot of controversy over this, but I first recognized a problem with using GL-5 oil in these boxes 35ish years back. There are some GL-5 oils that are supposed to be okay, but switching to them after the synchros have been damaged doesn't fully fix the grinding problem in my experience. To try and fix the damage done to my own present 002 transmission by running the GL-5 the builder recommended I am running Castrol 5w50 in the box, the box now shifts "okay" but not as good as it did before it got doused with GL-5. Both the box in my Vanagon and the box in my T181 Thing which TTBOMK have had only GL-4 oils in them both shift just fine even though they are far from new. I regularly downshift the Vanagon into 3rd at 50-55 without a whimper from the box. My wife who will downshift at speeds well above what she would ever run an engine up to, will downshift either of these rigs into 2nd at 40-45 pretty much every time she slows down.
RomStrom
RomStrom is offline
PostPosted: Wed Jan 08, 2020 9:43 am    Post subject: Re: Bay Window 2nd Gear Grind Reply with quote
Understood, so the 2nd gear synchronizer is necessarily damaged, and GL-5 serves to make this damage noticeable when it comes to shifting.
In that case I will probably try what you did with Castrol 5w50 first before busting open the box again and having my guy replace the sychronizer. I'll take "okay" over the incessant grinding that I get right now Embarassed . Thanks for the insight.
1978 VW Transporter
SGKent is offline
PostPosted: Wed Jan 08, 2020 10:37 am    Post subject: Re: Bay Window 2nd Gear Grind Reply with quote
I have been told by several well known trans builders who said it has happened to them when one of their customers did it. You can put in a brand new moly coated synchro, run GL5 and trash it permanently instantly. The extra slippery fluids in the GL5 soak into the moly and make it too slippery to grab the gear to spin it up or down.
airschooled
Air-Schooled
airschooled is offline
PostPosted: Wed Jan 08, 2020 11:11 am    Post subject: Re: Bay Window 2nd Gear Grind Reply with quote
Devil's advocate here: Why is only the 2nd gear synchronizer affected by the gear oil?
Does your 091 still have the spring-loaded neutral gate?
Robbie
www.airschooled.com
SGKent is offline
PostPosted: Wed Jan 08, 2020 3:22 pm    Post subject: Re: Bay Window 2nd Gear Grind Reply with quote
Robbie
Robbie - IF that is the only moly coated synchro then it is the only one affected. VW used both moly coated and only brass in their gear boxes, one can have a trans with only brass, only moly-coated brass, or a combination of both. FWIW the synrcho rings that I pulled out of my 091 were all brass except for 2nd which was moly-coated brass. I used all moly coated when putting them back in. They last longer. BUT if GL5 soaks them then all bets are off.
airschooled
Air-Schooled
PostPosted: Wed Jan 08, 2020 3:43 pm    Post subject: Re: Bay Window 2nd Gear Grind Reply with quote
That seems odd to me, but I don't rebuild transaxles… I've driven a GL-5 disaster, and it sucks. I look forward to learning how to rebuild them when my current 002 gives up, though it seems to be aging like a fine whine. Wink
Robbie
www.airschooled.com
Wildthings
PostPosted: Wed Jan 08, 2020 4:10 pm    Post subject: Re: Bay Window 2nd Gear Grind Reply with quote
Robbie
I have wondered the same thing and can't give you a very good answer beyond what Steve is saying. Some trannies do end up with a sifting problems primarily in 2nd and some end up with a shifting problem primarily in 3rd. That people don't complain about a problem shifting into first at speed might be because their expectations are low for this shift, and the 3-4 shift might not give too much problem because the jump between gears isn't that far.
I wish I knew better what was happening for sure.
airschooled
Air-Schooled
PostPosted: Wed Jan 08, 2020 4:29 pm    Post subject: Re: Bay Window 2nd Gear Grind Reply with quote
Count me in to the 1st gear camp Smile
The 3-4 shift is usually good because 4th synchros aren't typically worn from downshifting like the 1-2-3 parts are. I tap 4th gear to act as my reverse synchronizer when the car is warm and likes to chirp into reverse.
Robbie
www.airschooled.com
SGKent is offline
PostPosted: Wed Jan 08, 2020 4:48 pm    Post subject: Re: Bay Window 2nd Gear Grind Reply with quote
FWIW - Rick Long told me about it, Erik in El Cajon told me about it, then Big Bore not only told me about it but he was in the process of rebuilding an 091 for a rail that the guy drained the GL4 and put in GL5. The trans shifted perfectly after the rebuild with GL4 but ground terribly with GL5. Mike (Big Bore) said they tried draining and filling several times, tried light weight engine oil etc., drain and fill. Nothing worked. When the additives in the GL5 got into the moly that was it.
I used to hone blocks for moly rings. Moly coated things are special. Moly is like a tiny graphite plate. When the plates lay down on top of one another it is slippery as walking across a pile of oiled plates on an ice skating rink. When the molecules are straight up it is an abrasive. It is brittle and breaks very easy, hence blocks bored for moly rings need an extra like mirror finish - a regular crosshatch will destroy a moly ring. Why in tranmissions some GL5 oils screw up moly synchros I don't know. I do know that several other trans builders also told me they had been burned with warranty work on trans someone put GL5 into, and that is why most VW bus trans builders only use brass synchros. The sulfur compounds in GL5 will eat away at the brass and mag in a bus trans but it is a very slow process. The moly thing is an instant failure thing. Does this fellow have that problem? I don't know. The gear carrier was out - maybe something else got whacked like a shifter dog or the spring that holds them in.
Abscate Premium Member
Abscate is offline
PostPosted: Wed Jan 08, 2020 8:06 pm    Post subject: Re: Bay Window 2nd Gear Grind Reply with quote
Robbie
Nice. Very Happy
RomStrom
RomStrom is offline
PostPosted: Thu Jan 09, 2020 10:51 am    Post subject: Re: Bay Window 2nd Gear Grind Reply with quote
I would say it is quite likely that I do. The symptoms seem to match up exactly. 2nd and only second gives me trouble with an unpleasant grind. I did take special care with the carrier while out, mainly due to how intimidating it looked.
That being said I got a final troubleshooting method (before pulling the box) that my trans guy suggested:
Swap trans fluid with
- Lucas Oil Stabilizer mixed w/
- 75-90w non synthetic
and to let it warm up from a longer drive and let sit & give it a test the next day. In his experience with 091's this may improve or resolve the issue. Idk, worth a try! Will report back.
1978 VW Transporter
TomWesty
TomWesty is offline
PostPosted: Fri Jan 10, 2020 9:39 pm    Post subject: Re: Bay Window 2nd Gear Grind Reply with quote
Abscate wrote:
Robbie
Nice. Very Happy
you WOULD appreciate that. Cool
RomStrom
RomStrom is offline
PostPosted: Sun Jan 17, 2021 5:40 pm    Post subject: Re: Bay Window 2nd Gear Grind Reply with quote
Reporting back, tried the gear oil swap to no avail although it did "dampen" the grinding noise. Had to send my transaxle in somewhere to get fixed to which I chose Mr. Gas in Canon City, Colorado.
Went out for a drive a few days ago and shifts like new. Greg at Mr. Gas mentioned the shifter forks looked worn down and a few other small things, so perhaps I wasn't landing all the way into 2nd gear.
Well this time, I ended up adding GL-4 gear oil just to be safe although Greg mentioned I could use GL-5 as well. We'll see how it goes in the long run.
1978 VW Transporter
