CanadianVWboy Samba Member
Posted: Tue Nov 12, 2019 6:42 pm Post subject: 1960 15 W Found and now in a new home after 40 yrs "Jackie" |
She is now home a 1960 15W that was left on the owner's property.
I was told it was on the road last in the 1970s. The grandfather owned it sold to a guy who sold it to the person I bought it from.
We have been looking for a bullet nose 15W and now we have one.STOKED.
Happy that we now again have a bus after selling our 55 semaphore kombi in 2007.
This will also be our built thread for "Jackie" named after my wife's mom who recently passed away.
She has all the seats and interior panels, coat hooks, jail bars and glass but needs extensive chassis work.
_________________ Certified vw nut
Cars I have owned
-55 kombi -71 Super beetle sold
-69 Brasilia -63 ghia
-69 beetle
Current vws
-54 oval semaphore
-58 lowlight ghia
-60 15w deluxe bus |
Dustin B Samba Member
Joined: March 29, 2007 Posts: 1017 Location: hesperia, Ca USA
Posted: Tue Nov 12, 2019 8:51 pm Post subject: Re: 1960 15 W Found and now in a new home after 40 yrs "Jackie" |
Nice bus. Congratulations _________________ Wanted Victoria motors licence plate frame.
62 og paint L469 type 1
61 og paint L31 DD panel type 2
64 heilite viscount tent trailer
71 sears clamshell trailer
I <3 Brazilian busses
Original paint and patina extravaganza http://www.thesamba.com/vw/forum/viewtopic.php?t=187156 |
vwuberalles Samba Member
Joined: October 18, 2003 Posts: 1519 Location: Richmond, VA
Posted: Wed Nov 13, 2019 4:09 pm Post subject: Re: 1960 15 W Found and now in a new home after 40 yrs "Jackie" |
Dustin & vwuberalles
Thank you
So we mentioned this will be the build thread. Its -13c currently outside
I decided to bring parts from the bus that it came with
This is the headlights( before photos)
Here are some detail #s says made in Germany I think these are original from factory
the top of the lens says "Hella"
The chrome bezel can be clean up
and the housing I can blast as I owned a mobile blasting company
Can anybody shed light on this?
Thanks
Cars I have owned
-69 beetle
Current vws
-54 oval semaphore
-58 lowlight ghia
EverettB  Administrator
Joined: April 11, 2000 Posts: 71957 Location: Phoenix 602
Posted: Wed Nov 13, 2019 4:21 pm Post subject: Re: 1960 15 W Found and now in a new home after 40 yrs "Jackie" |
Yes, those headlights look like correct 1960 Bus headlights.
The "E1" glass lenses are correct for 56-63.
There should be a little drain hole on each of the chrome headlight rings.
This drain hole faces downward when they are installed.
Example
_________________ How to Post Photos
Posted: Wed Nov 13, 2019 4:42 pm Post subject: Re: 1960 15 W Found and now in a new home after 40 yrs "Jackie" |
Thanks, Everett
I just went and checked one has the hole as you stated the other has none.
Weird...
Also upon closer inspection, all the glass has markings "Sigla" glass on top right corners except for the front two windshields. Do the windshields have markings too? I will look closer when the weather is better. _________________ Certified vw nut
Cars I have owned
-69 beetle
Current vws
-54 oval semaphore
-58 lowlight ghia
Riff Raff Shivering Sambian
Joined: October 25, 2004 Posts: 3097 Location: Alberta
Posted: Wed Nov 13, 2019 8:06 pm Post subject: Re: 1960 15 W Found and now in a new home after 40 yrs "Jackie" |
| CanadianVWboy wrote: |
Thanks, Everett
Weird... |
Here is a link to an incredible wealth of headlight lens and bucket minutia (both 356 and VW)
http://forum.porsche356registry.org/viewtopic.php?...b3457b4268
| Also upon closer inspection, all the glass has markings "Sigla" glass on top right corners except for the front two windshields. Do the windshields have markings too? I will look closer when the weather is better. |
The windshields would have had logos on the upper, inner corners. Different ones were used in Canada. Could have been SIGLA or DELOG. As windshields get broken more often than other glass, they have likely been changed out with generic glass.
More info:
https://www.thesamba.com/vw/forum/viewtopic.php?t=168467&highlight=durvit _________________ The greatest obstacle to discovery is not ignorance, but the illusion of knowledge
- Daniel Boorstin |
62DoKaGuy Samba Member
Joined: May 22, 2011 Posts: 1293 Location: Surprise, AZ
Posted: Wed Nov 13, 2019 8:20 pm Post subject: Re: 1960 15 W Found and now in a new home after 40 yrs "Jackie" |
This too can be helpful and delves into other brands and code deciphering: https://www.thesamba.com/vw/forum/viewtopic.php?t=279505 _________________ ,,Wenige Menschen denken, und doch wollen alle entscheiden.'' -der Alte Fritz
| EverettB wrote: |
| ...I went at it from both ends but going from the rear didn't seem to do anything, although I did spray some rust breaker in there... |
4/62 Double Cab
5/61 Panel (sold)
4/59 Single Cab (sold) |
Posted: Wed Nov 13, 2019 9:58 pm Post subject: Re: 1960 15 W Found and now in a new home after 40 yrs "Jackie" |
| Riff Raff wrote: |
The windshields would have had logos on the upper, inner corners. Different ones were used in Canada. Could have been SIGLA or DELOG. As windshields get broken more often than other glass, they have likely been changed out with generic glass. |
Agree with this 100%.
I believe a '60 15-Window would have SIGLA windshields for a N. American Bus but they could have replaced over time.
The SIGLA logos are hard to see sometimes, clean the glass if it's dirty and shine a flashlight from different angles and see if that helps the logo show up. _________________ How to Post Photos
Posted: Fri Nov 22, 2019 6:45 pm Post subject: Re: 1960 15 W Found and now in a new home after 40 yrs "Jackie" |
Its the weekend and had a chance to get some shots of Jackie before we tuck her away for winter.
Perfect time to gather metal parts
Here she is..
Cars I have owned
-69 beetle
Current vws
-54 oval semaphore
-58 lowlight ghia
Posted: Fri Nov 22, 2019 6:47 pm Post subject: Re: 1960 15 W Found and now in a new home after 40 yrs "Jackie" |
and the seats all complete
Cars I have owned
-69 beetle
Current vws
-54 oval semaphore
-58 lowlight ghia
Posted: Mon Jan 13, 2020 4:30 pm Post subject: Re: 1960 15 W Found and now in a new home after 40 yrs "Jackie" |
Can I ask members photos of the hinge carrier that is correct for 1960 deluxe
The one for the decklid seems like WW is the only one who currently carries it.
Need some reference photos
Thanks
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=211813227 _________________ Certified vw nut
Cars I have owned
-69 beetle
Current vws
-54 oval semaphore
-58 lowlight ghia
Posted: Mon Jan 13, 2020 6:20 pm Post subject: Re: 1960 15 W Found and now in a new home after 40 yrs "Jackie" |
| EverettB wrote: |
Cool, middle seat too!
It must be a '61 since it has the 3-position front seat catches.
Maybe a '61 built in late 1960 and registered as a '60? |
Yep, a 61 produced in calendar year 60. It’s a high-hinge with humpback seats, so somewhere between 27 Oct 1960 (chassis # 673 616) and 29 Dec 1960 (chassis #705 619). Two months only with those overlapping. _________________ ,,Wenige Menschen denken, und doch wollen alle entscheiden.'' -der Alte Fritz
| EverettB wrote: |
4/62 Double Cab
5/61 Panel (sold)
cru62 Samba Member
Joined: December 31, 2002 Posts: 4121 Location: Margaritaville.....24/7
Posted: Thu Jan 16, 2020 10:31 am Post subject: Re: 1960 15 W Found and now in a new home after 40 yrs "Jackie" |
Don’t forget to turn the headlight bulb 90*. The way they are now is for a bug. _________________ "My biggest worry is that when I die, my wife will sell all my parts for what I told her I paid for them"-Jon
Jokes about German sausage are the wurst.
cru62 Samba Member
Posted: Thu Jan 16, 2020 4:22 pm Post subject: Re: 1960 15 W Found and now in a new home after 40 yrs "Jackie" |
I like how the awning matches the bus! _________________ "My biggest worry is that when I die, my wife will sell all my parts for what I told her I paid for them"-Jon
velvetgreen Samba Member
Posted: Sun Dec 12, 2021 1:37 pm Post subject: Re: 1960 15 W Found and now in a new home after 40 yrs "Jackie" |
| Any updates?? |
ZENVWDRIVER Samba Member
Joined: November 07, 2008 Posts: 3338 Location: N.E. Oklahoma
Posted: Sun Dec 12, 2021 2:07 pm Post subject: Re: 1960 15 W Found and now in a new home after 40 yrs "Jackie" |
My dad bought a new 1960, semi-deluxe, 15 window bus in SWR also - he wanted me to take that thing to my prom and I wanted the Desoto - z
_________________ 5/50, pastel green 11G - SOLD
8/50, gray 11A Beetle
6/52, pastel green 11C - SOLD
1960 single cab
9/63 Pacific blue, Ghia
'87 Toyota MR2
All super-heroes, wear a MASK |
Posted: Sun Dec 12, 2021 2:57 pm Post subject: Re: 1960 15 W Found and now in a new home after 40 yrs "Jackie" |
| 62DoKaGuy wrote: |
| EverettB wrote: |
Yep, a 61 produced in calendar year 60. It’s a high-hinge with humpback seats, so somewhere between 27 Oct 1960 (chassis # 673 616) and 29 Dec 1960 (chassis #705 619). Two months only with those overlapping. |
62DokaGuy
Your statement is partially correct. The vw certificate attached says was manufactured Aug 11,1960.
You mentioned from Oct 27,1960 (chassis#673616- to Dec 29,1960 chassis number # 705619)
Our chassis number is 679XXX but VW Germany states its Aug 1960
So is it a 1960 or a 1961?
Cars I have owned
-69 beetle
Current vws
-54 oval semaphore
-58 lowlight ghia
