73 bug adjustment
bavareze
bavareze is offline
PostPosted: Wed Feb 05, 2020 7:18 pm    Post subject: 73 bug adjustment Reply with quote
Hello.
I have 1973 vw bug. The engine is stock with the exception of twin port heads. Now I think it is not running ok. The spark advance seems not to vary with RPM, vacuum is very low on the gauge. It could be something between the carburetor and the distributor or something else.
Where can I go in LA to get some help on this subject but without costing me an arm and a leg?
Thanks
- www.b66ama.com - 29.000 miles in South America -
vwoldbug
vwoldbug is offline
PostPosted: Wed Feb 05, 2020 10:04 pm    Post subject: Re: 73 bug adjustment Reply with quote
Isn't that one of the most expensive areas in the country . Do you belong to a vw club.
VW_Jimbo Premium Member
VW_Jimbo is offline
PostPosted: Wed Feb 05, 2020 10:09 pm    Post subject: Re: 73 bug adjustment Reply with quote
It varies by load, not rpm. The weights advance the timing off of rpm. The vacuum signal is for load.
Remove the cap and try to twist the rotor. The mechanism should allow you to rotate it one direction and the springs will make it return.
Vacuum can, can be checked with a vacuum pump. Watch the points plate as you pump the pump. Should move smoothly and return when vacuum is released.
Jimbo
TDCTDI wrote:
67rustavenger wrote:
KTPhil Premium Member
KTPhil is offline
PostPosted: Wed Feb 05, 2020 10:59 pm    Post subject: Re: 73 bug adjustment Reply with quote
LA is pretty big. Where in LA are you?
bavareze
bavareze is offline
PostPosted: Fri Feb 07, 2020 1:33 pm    Post subject: Re: 73 bug adjustment Reply with quote
90018
I don't belong to any vw club.
