Class 9 battery set up
y2kbaja
y2kbaja is offline
PostPosted: Wed Feb 12, 2020 7:31 am    Post subject: Class 9 battery set up Reply with quote
I just bought a used class 9 and the previous owner hacked in a battery plate for a large automotive battery to power his, of all things, large stereo he added to the car. I found a place where two Oddessy 680 batteries would sit, way down low in the car. I would like to run this battery as it is a clean place to put them. Question is: 1) is the 680 a good battery to run, 2) can I get away with just one for a while or does the system require two?
Thanks in advance.
[/img]
dirtkeeper
dirtkeeper is offline
PostPosted: Wed Feb 12, 2020 8:12 am    Post subject: Re: Class 9 battery set up Reply with quote
I think that is an undersized battery. I prefer to have closer to 800-1000 cranking amps, That one only has about 500.
JWHracing
JWHracing is offline
PostPosted: Wed Feb 12, 2020 8:17 am    Post subject: Re: Class 9 battery set up Reply with quote
Why run 2? Seems like more stuff to go wrong to me.
I run a single Odyssey 925 and it starts my 2180 just fine. I have had it over 2 years with zero issues.
65 Baja - Class 5 Unlimited Race Car
2021 STORR Pro Air Cooled Buggy Champion
2019 AZOP Unlimited Buggy Champion
2017 SADR 1300 Class Champion
2016 AZOP Limited Buggy Champion
Currently "retired" from racing
y2kbaja
y2kbaja is offline
Two in parallel as the car was designed would be best then.
y2kbaja
y2kbaja is offline
PostPosted: Wed Feb 12, 2020 8:19 am    Post subject: Re: Class 9 battery set up Reply with quote
Going on CCA the 925 has 900 and the 680 has 520. So I can see why not running just one 680 battery. One 925 would be sufficient.
Dale M.
Dale M. is offline
PostPosted: Wed Feb 12, 2020 10:14 am    Post subject: Re: Class 9 battery set up Reply with quote
If its just a play buggy the has good starting and good charging system, a 600 CCA plus battery will do just fine....
Dale
y2kbaja
y2kbaja is offline
PostPosted: Thu Oct 02, 2025 1:01 pm    Post subject: Re: Class 9 battery set up Reply with quote
Searching for another post I found this one I started way back when and thought I would give an update. The two batteries in the race car have performed flawless. Having the selectable switch for 1, 2 or both helps. We run on battery 1 99.9% of race miles while battery 2 powers the go-pros. We found that the go-pros would shut off when starting the car when on the main battery. Loading on the trailer, around the pits, basically anytime we're not racing we run the switch on both batteries to give them a charge.
When I built my 'manx' I used the same Odyssey 680 and it works great too. It's only gone low in the driveway when the car decided not to start which is another concern not battery related. When I bought the battery for the manx I bought an XS Power from Amazon in the same size. It works great too.
The only issue I had was when I put one of the Odysseys on a slow charger overnight before a race it expanded and was done for.
ORANGECRUSHer
ORANGECRUSHer is offline
PostPosted: Thu Oct 02, 2025 1:12 pm    Post subject: Re: Class 9 battery set up Reply with quote
I think next time lead with what you plan to need two batteries for instead of end.
Do the classes have a spec related to batteries? I don't race. Asking for a friend.
edit: oh I see this is an old thread. nevermind
Brian H.
OrangeCrushERBerrien Warrior-2.4L Quad4-2x3 arms-1.5Fox coilovers-094-930CVs
LAZY MARY1970 Baja 2110cc-82mm CB forged crank-AA pistons/cylinders-Grant rings-1.1 vw rockers-CB serpkit-CB chromoly PRs-CB maxiflow filter pump-wix51515 filter-Dual 44IDF-cut/turned front beam-AEM wideband-Auber CHT-Donaldson Dual PowerCore filters-custom AL air boxes
