Official Type 34 thread
Page: Previous  1, 2, 3 ... 50, 51, 52 ... 58, 59, 60  Next
bullethead
bullethead is offline
PostPosted: Fri Feb 21, 2020 5:56 pm    Post subject: Re: Official Type 34 thread Reply with quote
Kharon8 wrote:
reay wrote:
The mesh is black, I have been painting them with POR 15 and that shean works fine.
Had an opportunity see all original T34 in the weekend and it had black or very dark grey plastic mesh in those holes. I have that somewhere, just need to find it.
Took dozens of pics for all details we didn't have pics for and specifically of the carpets we didn't have, so no idea where the pieces belong. Carpet should arrive early next week but we'll see. We don't have much surplus so careful cutting is needed.
Interesting almost rectangular pieces in the side wall in front of door and almost triangular pieces on top of rear wheel arches.
It was also a surprise that the luggage box behind rear seat has one huge piece of carpet and not much more.
Got a picture of the wiring too, it's just stuffed behind instrument panel, no cover or anything like it. Brutal.
It would be wonderful if you could post detail photos in the gallery, Kharon. And congrats on your steady progress, it's encouraging to watch.
After approaching a 3D printing shop AND a small machine shop without success, I decided to attempt repair of the sunroof slider. First with a nano-adhesive (UV cure) featuring metal dust as reinforcement... NFG. Tried soldering but the 60/40 zinc I have didn't hold either.
So I cleaned everything and drilled a bunch of tiny holes to form a matrix and applied the high PSI version of JB weld. After that set, a small plate of 22 ga. steel was drilled and bonded on as a gusset. Gonna let it cure over the weekend and try it Monday.
Maybe pull a silicone mold off of it first?
Russ
Vintage Driven... Oil Cooled
'59 Porsche 356A Convertible D
'62 Porsche 356S Notchback Hotrod
'63 VW Type 34 Karmann Ghia
'64 VW Bus 21 Deluxe Samba
'67 Porsche 911 S
'68 Porsche 911 T Targa
'68 Porsche 911 L Soft Window Targa
'70 Porsche 914/6 GT
Kharon8
Kharon8 is offline
PostPosted: Mon Feb 24, 2020 10:25 am    Post subject: Re: Official Type 34 thread Reply with quote
Thanks! Sometimes it doesn't feel progress at all, but every time one item less missing.
Rear pop-ups, door locks and many interior pieces are now installed back, it almost looks like a whole car now. I noticed also that I promised too much, had only 20 pictures, but I made a gallery of those:
http://kharon.suomiforum.com/www/ghia4/
Some specialities which were new/undocumented earlier (at least to me):
http://kharon.suomiforum.com/www/ghia4/P2152280.JPG
Carpet turned around the hood springs, nice detail.
http://kharon.suomiforum.com/www/ghia4/P2152296.JPG
Solid vinyl besides rear seat and bottom trim on the door.
I'm hoping to see this car/owner in late June again, so I can take more pictures then. Currently he's 230km/150miles away, so no quick visits to take some pics.
Kharon -- '62 typ1, '63 typ14, '61 typ21, '65 typ34, '74 412, '75 typ26
FVWA.fi support group.
Kharon8
Kharon8 is offline
PostPosted: Sat Feb 29, 2020 10:15 am    Post subject: Re: Official Type 34 thread Reply with quote
Major progress: Door locks and door windows assembled.
Took several days as it's not simple thing to do.
http://kharon.suomiforum.com/www/ghia3/P2292300.JPG
Installed last gauge back after managed to verify that fuel gauge works and shows something sensible. Warning lights and blinkers seem to still work, successful installation.
Also installed radio (Blaupunkt Frankfurt, not far from '65 either direction), not connected yet and we don't have a speaker either, but it's a serviced radio, should be OK.
Banana plug connectors for speaker and antenna, but 5-pin DIN for input/output(?) .. no idea if all pins are connected. Line in is very useful, just connect your phone to it and vĂ³ila: Instant internet radio (assuming unlimited data, of course).
Charging phone is a problem though, haven't seen any USB-chargers accepting 6V in. In the old times it was easy as phone accepted dumb charger as long as voltage was correct (for my phone then 3.7V) and that was easy with a single voltage regulator from 6V.
http://kharon.suomiforum.com/www/ghia3/P2292301.JPG
Dash looks so good now.
Small bits & pieces still missing, like engine and carpets, but some progress and almost all of the electrics (sans engine) is now connected and tested.
Tidying the tangle of wires probably will disconnect/break something but I try to worry it when/if it happens and not now.
bullethead
PostPosted: Sun Mar 08, 2020 6:34 am    Post subject: Re: Official Type 34 thread Reply with quote
You are making major progress! BTW, is that SP2 yours as well? Very Happy
Turns out that with a little patience, the right approach and JB Weld can fix nearly anything. It works! It's ridiculous but this small success felt like a major accomplishment.
Also replaced the door latch mechanisms with NOS units, corrected an oil leak on the new engine and put 100 miles on it this week. A few paint touch-ups and then it's back to work on my '64 Samba.
Russ
'67 Porsche 911 S
Kharon8
Kharon8 is offline
PostPosted: Sun Mar 08, 2020 7:01 am    Post subject: Re: Official Type 34 thread Reply with quote
Thanks!
SP2 isn't mine but I know the owner, he owns part of the garage where I'm working with a helper/body guy.
Or actually I'm the helper, he has as long experience on VWs as I do (Bought my first Beetle in 1984, that's 36 years ago. Damn. Who pushed fast-forward?), but he has been working with type 3 earlier and for me it is all new.
Neither of us have time to work on this full time, but it progresses much faster when there are two part-time guys doing something.
Kharon8
Kharon8 is offline
PostPosted: Sun Mar 08, 2020 7:13 am    Post subject: Re: Official Type 34 thread Reply with quote
Updating myself:
I got reports that most $9 12V USB chargers work like a charm despite battery voltage being only 6V. Haven't tried yet, but obviously on the list to test.
Packed wiring underneath the dash and while it compressed nicely it still needs some re-arranging so that the wires coming to fuse box are the bottommost ones and all the rest are above them, otherwise the latter are hanging too low.
Also connected speaker to the radio, but something is still wrong, it's very soft even with loudest setting. Could be missing ground, again.
Power light is on so at least it gets some power. No antenna so no stations either.
Bobnotch
Bobnotch is offline
PostPosted: Sun Mar 08, 2020 10:12 am    Post subject: Re: Official Type 34 thread Reply with quote
Kharon8 wrote:
Thanks!
You're making great progress though, even if it's just "part time".
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
Kharon8
Kharon8 is offline
PostPosted: Mon Mar 09, 2020 9:08 am    Post subject: Re: Official Type 34 thread Reply with quote
Working sunroof, when parts are "mission impossible", *isn't* a small success at all. Smile
Kharon8
Kharon8 is offline
PostPosted: Mon Mar 09, 2020 9:12 am    Post subject: Re: Official Type 34 thread Reply with quote
Thanks!
Sometimes months pass and nothing really happens and then moon is in a favourable position and a lot happens very fast.
There's no rational explanation to that, so moon is as good as any.
But winter finally being over, so we get sunny days, definitely helps.
Bobnotch
Bobnotch is offline
PostPosted: Mon Mar 09, 2020 1:44 pm    Post subject: Re: Official Type 34 thread Reply with quote
I'm glad the JB Weld finally worked out for you. While you might not like it, one thing I've learned about T-34s, is sometimes you have to improvise, adapt, and over come. These cars, while based on a type 3, are completely all their own.
Tram wrote:
Tram wrote:
Kharon8
Kharon8 is offline
PostPosted: Wed Mar 11, 2020 12:59 am    Post subject: Re: Official Type 34 thread Reply with quote
Forgot to comment this earlier: The aluminium piece on the outside of lock frame was loose, I'll guess? The piece which has latch axle inside?
Mine had that problem on the driver side door so I took the lock apart and the problem is basically a rivet failing and being loose. The aluminium part is just riveted to the lock frame with one aluminium rivet. No wonder it eventually fails.
Drilled and threaded a M3 hole to rivet, bolted it and now it's as good as new. Have some pics too, but those are poor so I didn't publish them on page. User error on focus as autofocus couldn't focus that near.
Here's partially disassembled lock and the end of the rivet with a already threaded hole can be seen in the middle.
http://kharon.suomiforum.com/www/ghia3/P1122252.JPG
Here's same thing with bolt and washer installed.
http://kharon.suomiforum.com/www/ghia3/P1122253.JPG
Hopefully you can see something as I had that thing on the desk, I know what it looks like so it's easy to imagine the rest even from poor pics.
Kharon8
Kharon8 is offline
PostPosted: Wed Mar 25, 2020 6:36 am    Post subject: Re: Official Type 34 thread Reply with quote
Semi-quarantine here in North so I'm just ordering remaining parts, but something still happens.
Engine jumped into engine bay and floor carpet materials came but only half of what we ordered.
Anyway, we cut that and send them forward to seamstress to have edges done and ordered more, no panic. Haven't yet seen it so can't comment
Most of the small carboard hoses (~1") were so bad that we aren't re-using them but replace with new ones and I ordered those, with speedometer cable as ours was a foot too short, i.e. broken.
Also small rubber triangles to lower edge of the door, hopefully the same as split window bus has. At least they look the same and no-one is selling those specifially for T34.
Front seats still need washing and some patches of paint but that's a minor task.
Work hours? No idea, haven't counted. But bodywork (i.e. rust hole & poor patch removal) and painting definitely the major parts, about 6 months full time work, >1000 hours.
I think we've (almost) all the parts now ... feels good and definitely helps the budget ... haven't dared to make a summary, but I do have all the receipts in a box.
But I'm sure it's in "too much" -class. Ugh. Well, my bank account survived it so no worries, eh?
bullethead
PostPosted: Thu Mar 26, 2020 9:30 am    Post subject: Re: Official Type 34 thread Reply with quote
Useful info for sure, but both of my latches were simply worn out: the lock pivots themselves were shot, and the lower face on the driver's side had a fair amount of it's face worn off. They weren't re-buildable.
And thanks for the encouragement Bob... yeah, sometime ya gotta make do. Sunroof works great, but with summer coming it's not gonna be used for awhile. Laughing
Russ
'67 Porsche 911 S
bullethead
PostPosted: Fri Mar 27, 2020 5:13 pm    Post subject: Re: Official Type 34 thread Reply with quote
Now that the paint touch-ups are done, the punch list of niggling issues is nearly complete. Replacing the antenna with a proper Hirschmann next week, and the clock will be serviced. Meanwhile, it's back home for regular daily use.
Parked next to our 280SL illustrates just how big der Grosser Ghia is! Nearly identical dimensions. Never woulda thought... EDIT: a better photo-
BTW, have been looking for any cover company that makes something for these cars. Anyone have a suggestion? Maybe a first-generation two-door Corvair would fit?
Russ
'67 Porsche 911 S
ozinbc
ozinbc is offline
PostPosted: Sat Mar 28, 2020 6:17 pm    Post subject: Re: Official Type 34 thread Reply with quote
Tip: for those home manufacturing the tool to remove the rear engine hatch lock - the same collar with the two detents is found on beetle glove box locks. You can test the fit before mangling the T34.
I used a 16 mm deep socket, cut the two teeth with a dremel and cutting disc, filed smooth by hand. THe socket needed some internal grinding (again with a stone on the dremel). The tangs are 3.5 mm wide, 2.5 mm deep
Now I need some tips on how to disassemble the lock.
Update - photos to show it can be done! One showing the threaded ring in the tool.
the invisible and the non existent look very much alike
sjbartnik
sjbartnik is offline
PostPosted: Sat Mar 28, 2020 6:45 pm    Post subject: Re: Official Type 34 thread Reply with quote
bullethead wrote:
That is a good lookin' car.
Love those pagoda 280SLs too
1965 Volkswagen 1500 Variant S
2000 Kawasaki W650
Bobnotch
Bobnotch is offline
PostPosted: Sun Mar 29, 2020 8:34 am    Post subject: Re: Official Type 34 thread Reply with quote
Beautiful looking car. You might try a Corvair cover, as it is a German Corvair you're trying to cover. Wink
Tram wrote:
Tram wrote:
PostPosted: Sun Mar 29, 2020 9:03 am    Post subject: Re: Official Type 34 thread Reply with quote
Thank you, I added a link to your post with information from the "info" links at the start of this thread.
chipmcluk
chipmcluk is offline
PostPosted: Sun Mar 29, 2020 12:20 pm    Post subject: Re: Official Type 34 thread Reply with quote
I ordered one made for a type 14 Ghia and it fits pretty well. A little short at the bumper ends but with given dimensions, I thought a Corvair cover would be a little too sloppy.
bullethead
PostPosted: Sun Mar 29, 2020 12:25 pm    Post subject: Re: Official Type 34 thread Reply with quote
Yeah, after checking the dimensions, surprisingly a Corvair is nearly 20 inches longer and also wider. Per your suggestion, how's the mirror location... close enough?
Russ
'67 Porsche 911 S
Page 51 of 60
