Westy Sink / Stove Dimensions
tjet
tjet is offline
PostPosted: Thu Apr 09, 2020 5:28 pm    Post subject: Westy Sink / Stove Dimensions Reply with quote
Does someone have the dims of an original Westfalia sink stove unit (height x width x depth)? I'm thinking about building a custom sink & stove cabinet for my tintop, and I'd like to keep it about the same size.
Thanks
kamzcab86
kamzcab86 is offline
PostPosted: Thu Apr 09, 2020 5:51 pm    Post subject: Re: Westy Sink / Stove Dimensions Reply with quote
https://www.thesamba.com/vw/forum/viewtopic.php?t=414383 🍺
2016 Golf GTI S
tjet
tjet is offline
PostPosted: Thu Apr 09, 2020 5:57 pm    Post subject: Re: Westy Sink / Stove Dimensions Reply with quote
That's perfect Kam.
Question: on the width, is the 35.5" the max you can have it before it hits the deployed bed?
Also, for folks who own a Westy, what would you change on the stove/sink cabinet? Height, depth, move space for a different fridge, etc?
kamzcab86
PostPosted: Thu Apr 09, 2020 6:35 pm    Post subject: Re: Westy Sink / Stove Dimensions Reply with quote
Pretty much.
The Westy kitchen is fine for me. But if I were starting from scratch I'd make the sink a little larger and have a corner drain to allow for a proper-size drawer, change the stove grate style, and put an adjustable shelf in the cabinet. As for the fridge, for me, I'd put a drawer above a Truckfridge.
2016 Golf GTI S
tjet
tjet is offline
PostPosted: Thu Apr 09, 2020 6:47 pm    Post subject: Re: Westy Sink / Stove Dimensions Reply with quote
So a sink like this one vs the Westy round one?
dobryan Premium Member
dobryan is offline
PostPosted: Thu Apr 09, 2020 6:51 pm    Post subject: Re: Westy Sink / Stove Dimensions Reply with quote
I’d put a drawer below a truckfridge. btdt. If you put a tf65 up high it will fit flush to the cabinet since it is above the ridge on the floor.
Dave O
The Western Syncro build
Jeffrey Lee
Jeffrey Lee is offline
PostPosted: Thu Apr 09, 2020 7:06 pm    Post subject: Re: Westy Sink / Stove Dimensions Reply with quote
Technically, the deployed bed and the fridge cabinet don't interfere with one another, so the cabinet could be longer. But if the bed were any longer, or the fridge located further rearward, the bed would prevent the fridge door from opening/closing.
Which really complicates drinking beer in bed ...
Camp Westfalia
Camping Tips • Newsletter • Cool Campervan Apparel
www.CampWestfalia.com
maco70
maco70 is offline
PostPosted: Fri Apr 10, 2020 8:20 am    Post subject: Re: Westy Sink / Stove Dimensions Reply with quote
I’d would like a higher than 2.75 inches for the top, then I would have ease to put a soap dispenser.
The soap dispenser reservoir then would be under the sink, and the arm would goes in the sink, as we see often in a house kitchen.
An idea - hope it helps.
Martin from Montréal
1986 Vanagon GL full camper westfalia
(brown/tan interior)
Timwhy
Timwhy is offline
PostPosted: Fri Apr 10, 2020 9:38 am    Post subject: Re: Westy Sink / Stove Dimensions Reply with quote
Here's one.
Member 1621 his install.
https://www.thesamba.com/vw/forum/viewtopic.php?t=...=soap+1621
'15 Audi A3 Quattro
'09 VW Tiguan (dead)
'87 VW Westy
'91 Tin Top
'90 Cabby
izzydog
izzydog is offline
PostPosted: Fri Apr 10, 2020 11:16 am    Post subject: Re: Westy Sink / Stove Dimensions Reply with quote
Ever tried to wash your face in that sink? It's like camping out in the Barbie Camper. Who's head can actually fit in there? LOL
Part of that problem is the stove/sink lid - it's in the way. If I were rebuilding the stove/sink, I think would have a lid that could work with a hinge and also be detachable. Maybe even use the detached lid as a table.
A larger sink would be nice. You could fit one in by only using one larger burner for the stove. I rarely ever use two burners at once and a larger burner would get the job done faster and take up half the space.
There are some really nice sink/burner combos out there. Some also have lids that are much less bulky than the Westy one.
I put a drawer underneath my TF49 mostly because it's rectangular shaped and not oval shaped like the sink drawer. I thought that if those two shapes were side by side (drawer at the top of fridge) it would look odd.
[/img]
tjet
tjet is offline
PostPosted: Fri Apr 10, 2020 1:56 pm    Post subject: Re: Westy Sink / Stove Dimensions Reply with quote
Good info. I'm going to put that into consideration. Thanks
Good point. I just bought this sink in the classifieds. It's out of a Country Homes van. Measures 11-3/4 x 12-3/4. 5" deep.
Thanks for the input on the Truckfridge and cooking burner use. Those two subjects will be on another post.
kamzcab86
PostPosted: Fri Apr 10, 2020 4:07 pm    Post subject: Re: Westy Sink / Stove Dimensions Reply with quote
For me, it's plates. Just barely smaller than the sink; if one is set in the sink by itself, let an hour of cussing begin.😂
That looks really nice.👍
2016 Golf GTI S
jimf909
jimf909 is offline
PostPosted: Fri Apr 10, 2020 7:23 pm    Post subject: Re: Westy Sink / Stove Dimensions Reply with quote
On the Westy kitchen I'd probably make it 6" taller for a better working heiht and to provide more storage.
I'd make much better use of the storage space using drawers and pullouts that allow for more use of the space. There are too many vacant spaces in a Westy cabinet.
I really like having front-loading fridge v. a top-loader.
The square sink makes sense.
I like the cover over the sink/stove but also see great designs that make a flat workspace with covers that remove from the stove and sink.
There are some great ideas floating around in the kitchen threads.
Nacho has awesome cabinets. Superb design and execution and three(!) burner stove.
http://www.drivenachodrive.com/about-nacho/virtual-cabinets-for-a-real-world-nacho-bus/
http://www.drivenachodrive.com/about-nacho/installing-custom-cabinets-in-nacho-vanagon/
I'm looking forward to seeing what you build!
- Jim
Butcher wrote:
Guilty as charged.
tjet
tjet is offline
PostPosted: Fri Apr 10, 2020 7:44 pm    Post subject: Re: Westy Sink / Stove Dimensions Reply with quote
Dang, that's really nice...
This is more my speed
Timwhy
Timwhy is offline
PostPosted: Sat Apr 11, 2020 2:20 am    Post subject: Re: Westy Sink / Stove Dimensions Reply with quote
I would love to have one of these in my Tintop as well
'15 Audi A3 Quattro
'87 VW Westy
'91 Tin Top
'90 Cabby
tjet
tjet is offline
PostPosted: Sat Apr 18, 2020 2:15 am    Post subject: Re: Westy Sink / Stove Dimensions Reply with quote
So I've been pondering over the overall size of my custom sink / stove cabinet for my tintop passenger van. I've been scratching my head on the stove height because of my current "low" ceiling. I came up with the idea to make it adjustable from aprox 28" to 36" by sliding out the counter top & putting it in lower grooves.
The unit itself will be 34" high by 36" wide. Eventually, after I install a poptop or highroof, I can raise the unit 2 more inches with blocks to a total height of 36", which incidentally, is the most common stove height in the US. The 34 & 36" heights would be flush with the counter. The width measurement is approximate, dependent on z-bed clearance.
I'm still working on the details for the Truckfridge placement, drawers, and a recessed folding leaf on the aft side.
The side panel facing the sliding door will have a removable screen to fill in the adjustable height gap.
I will make a mock up first to see if I like or hate it.
https://www.dometic.com/en-us/us/products/food-and...ifications
