Possible short when putting steering column clam shell on
4mymalamute
4mymalamute is offline
PostPosted: Sun Apr 26, 2020 6:45 am    Post subject: Possible short when putting steering column clam shell on Reply with quote
This is something weird happening with my 89 syncro. Months back I would jump in to go and turn the key and nothing....just lights on dash. Changed out ignition and still was happening randomly. Then, one day I took off the plastic clam shell that wraps around the steering column (it was cracked) and the issue went away. Coincidence? Not sure.
Well yesterday, Months later and after having the 1.8 swap put in..I decided to fix the plastic shell and put it back on....and wouldn't you know it, Sally the Syncro left me stranded with the same issue. No clicking, no nothing. I took the shell off (while sitting in the store parking lot boiling) and wala, turned the key and it started.
Soooo, has anyone ever heard of something weird like this? Do you think the metal screws are grounding out the ignition when the column is put on? I cant seem to trace exactly what is taking place. Suggestions?
1989 Sally the Syncro.....she is a work in progress. 1.8T and tuned...she scoots up the hills...watch for flying dog drool out the windows.
1969 Bucky the Bug Convertible...red, rusted, work in progress....LOTS of work.
dobryan Premium Member
dobryan is offline
PostPosted: Sun Apr 26, 2020 6:50 am    Post subject: Re: Possible short when putting steering column clam shell on Reply with quote
If you cannot see any broken insulation on a wire I would try to wiggle the wires while you try the ignition and see if there is a change. My guess is you have a wire broken inside the insulation and if pushed into the wrong position it loses contact.
Could also be bad at the connector.
Dave O
The Western Syncro build
MarkWard
MarkWard is offline
PostPosted: Sun Apr 26, 2020 7:34 am    Post subject: Re: Possible short when putting steering column clam shell on Reply with quote
It should be held on with 2 screws that screw into the plastic top cover. The bottom section should have a spring clip that snaps over the column. Is this what you have? If so, really no way for a screw to cause the problem. How about a picture of the ignition harness?
4mymalamute
PostPosted: Sun Apr 26, 2020 12:04 pm    Post subject: Re: Possible short when putting steering column clam shell on Reply with quote
Yep thats exactly what I have. I am having issues uploading pics (even though I have uploaded a bunch prior...need to figure out how to delete some so maybe it will allow me to upload more?)
dhaavers
dhaavers is offline
PostPosted: Sun Apr 26, 2020 9:02 pm    Post subject: Re: Possible short when putting steering column clam shell on Reply with quote
I'll second the motion for bad wiring or connection to ignition switch; added pressure
from column cover installed causes broken connection. Check it out & report back...
Cool
- Dave
"The WonderVan"
dobryan is offline
PostPosted: Mon Apr 27, 2020 6:28 am    Post subject: Re: Possible short when putting steering column clam shell on Reply with quote
I do not think there is a pic limit so likely no need to delete.
Dave O
