pkbghia  Samba Member
Joined: February 22, 2017 Posts: 64 Location: Wyomissing Pennsylvania
Posted: Mon May 04, 2020 5:53 am Post subject: Re: What's this Ghia part and Where does it go? |
Thanks for quick response! I plan to patch the "aftermarket" holes. Another question: Currently I have my engine mounted and running on the chassis. I would like to leave it on as I drop the body on. It seems to me that I should have the wire loom in place and the tarboard that is in front of the fan also in place because these would be a pain to position once body on with engine in place. Is there anything else that I should have in place so I don't end up saying "%&#@$, I should have done that prior to putting body on" Thanks! |
Posted: Mon May 04, 2020 5:54 am Post subject: Re: What's this Ghia part and Where does it go? |
Some pictures of my project
John Moxon  Samba Moderator
Joined: March 07, 2004 Posts: 14221 Location: Southampton U.K.
Posted: Mon May 04, 2020 7:03 am Post subject: Re: What's this Ghia part and Where does it go? |
Will do, thanks |
crocteau Samba Member
Joined: March 31, 2005 Posts: 1232 Location: Philaburbia
Posted: Mon May 04, 2020 9:05 am Post subject: Re: What's this Ghia part and Where does it go? |
pkbghia wrote: |
IMHO it's worthwhile having the body and pan mated before running the wiring, but it's probably moot. One aspect you may find in retrospect is that it's easy to adjust the rear hatch release without the engine installed; I found sitting on the garage floor, under the car, with my upper body in the empty engine compartment was one of the coolest experiences of the restoration, er, okay, it was more of a "rebuild" for any purists reading this Then again, you may be able to finagle adjusting the rear hatch release properly with the body in the air  |
rbsurfguy Samba Member
Joined: August 10, 2008 Posts: 1780 Location: Fairfax, Northern Virginia Formerly Huntington Beach, SoCal
Posted: Mon May 04, 2020 4:14 pm Post subject: Re: What's this Ghia part and Where does it go? |
crocteau wrote: |
I just tried playing with this exact thing yesterday, without the engine in place... yeah fun sitting in empty engine compartment, and making vroom vroom noises.....but hell trying to get that cable release adjusted in the mechanism, while trying to also adjust the pin to catch and release....popping it open multiple times from underneath is the real fun!!! still trying to get it right.
Jeff _________________ 1971 Ghia convertible (Body off rebuild)
2019 VW Atlas 4Motion
2012 Passat-Sold
See my build on The Samba at:
Jeff's 71 Vert Restoration/Reassembly http://www.thesamba.com/vw/forum/viewtopic.php?t=6...highlight= |
morgan8899 Samba Member
Joined: January 17, 2018 Posts: 33 Location: las vegas
Posted: Wed May 06, 2020 9:41 pm Post subject: Re: What's this Ghia part and Where does it go? |
jarnarcos Samba Member
Posted: Fri May 08, 2020 1:58 pm Post subject: Re: What's this Ghia part and Where does it go? |
Folks, on a 1971 Ghia...anybody happen to know what the metal line under the passenger rocker is supposed to carry? Previous owner appears to have cut it. Brakes and fuel work fine so I have no clue. |
Posted: Fri May 08, 2020 2:28 pm Post subject: Re: What's this Ghia part and Where does it go? |
jarnarcos wrote: |
Most likely part of the fuel vapor containment/capture system (you know, charcoal canisters, etc.) |
NoDents Samba Member
Posted: Fri May 08, 2020 2:30 pm Post subject: Re: What's this Ghia part and Where does it go? |
X2.
Fuel vapor system. _________________ No Dents
1963 Bug - Sold in 1980
1966 Karmann Ghia Convertible - Stolen in 1988
1971 Karmann Ghia Convertible, resto/mod COMPLETED 10/2020 |
Posted: Fri May 08, 2020 3:11 pm Post subject: Re: What's this Ghia part and Where does it go? |
rbsurfguy wrote: |
...but hell trying to get that cable release adjusted in the mechanism, while trying to also adjust the pin to catch and release....popping it open multiple times from underneath is the real fun!!! still trying to get it right. |
check page 2 of this post https://www.thesamba.com/vw/forum/viewtopic.php?t=...p;start=20, another Jeff (from revolks.com) has a good description of the process with the engine out of the way  |
fmallabykay Samba Member
Posted: Mon May 11, 2020 3:23 am Post subject: Re: What's this Ghia part and Where does it go? |
Hi folks! Can anybody point me to a part number/name for the clip that holds your distributor cap & rotor in place? It’s a low profile metal “ring” that tightens with a nut & bolt, right where the distributor rotor shaft goes into its “hole”. It’s the piece that you loosen & tighten during timing adjustment. Mine is bent and I want to replace it along with my distributor cap (Bosch 009) but can’t find the piece or a diagram that includes it online! |
iowegian  Samba Curmudgeon
Joined: February 16, 2005 Posts: 9954 Location: Somewhere between Dubuque and Keokuk
Posted: Mon May 11, 2020 5:48 am Post subject: Re: What's this Ghia part and Where does it go? |
fmallabykay wrote: |
Distributor hold down clamp:
https://www.thesamba.com/vw/classifieds/detail.php?id=2342056 |
Posted: Mon May 11, 2020 1:00 pm Post subject: Re: What's this Ghia part and Where does it go? |
iowegian wrote: |
Thank you kindly sir. You led me to VW Distributor Clamp - Empi 113905250
Do you think there are big advantages of a renewed original piece over a repop in this case? Seems like $20 vs $4 |
Posted: Mon May 11, 2020 3:28 pm Post subject: Re: What's this Ghia part and Where does it go? |
Yes, the $4 dollar one will eventually strip out or loosen up just when you need it and you're out on the road too far from any parts, and the original refurbished will probably last another 20-40 years. Just my opinion of course.
2012 Passat-Sold
EverettB  Administrator
Joined: April 11, 2000 Posts: 71633 Location: Phoenix 602
c21darrel Samba Member
Joined: January 22, 2009 Posts: 8237 Location: San Dimas
Posted: Wed May 20, 2020 1:15 pm Post subject: Re: What's this Ghia part and Where does it go? |
NoDents wrote: |
Any clues?
They are lined with a paper gasket.
Just a followup on this.
I figured out during assembly.... these hold the fresh air cable for passenger side. one at each end. Squeezed to hold cable cover. _________________ No Dents
drlocke Samba Member
Posted: Wed May 20, 2020 6:16 pm Post subject: Re: What's this Ghia part and Where does it go? |
Hi group - my first post! Got this 1970 Ghia for my wife last year and she's a very happy camper. I also got a couple boxes of spare parts for the factory installed AC that was removed by a PO and I'm trying to figure out if they are worth holding onto or selling. Please advise!
