Pbotsonis Samba Member
Joined: January 09, 2008 Posts: 506 Location: Parker, Colorado
Posted: Mon Feb 21, 2011 8:04 pm Post subject: Reverse lights |
So a couple of years ago my car was acting up. When I took it to my buddy to have him look at it he reached behind the motor and pulled out a completely bare wire. Anyways from then on my reverse lights have not worked. Anyone know where that wire starts and ends so I can replace it?
Thanks, _________________ Price does not include PayPal fees. Text is the fastest way to reach me |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 80546 Location: Sneaking up behind you
Posted: Mon Feb 21, 2011 8:05 pm Post subject: |
It runs from the positive side of the coil to the tranny switch. then from the switch to a Tee connector in the engine compartment and then to each tail light.
_________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
Posted: Mon Feb 21, 2011 8:07 pm Post subject: |
Is the Tranny switch behind the motor? Thanks for the quick reply _________________ Price does not include PayPal fees. Text is the fastest way to reach me |
Glenn  Mr. 010
Posted: Mon Feb 21, 2011 8:08 pm Post subject: |
Its on the passenger side of the nose cone.... on the tranny. _________________ Glenn
Member #1009
#BlueSquare
Semper_Dad Samba Member
Glenn  Mr. 010
Posted: Mon Feb 21, 2011 8:16 pm Post subject: |
| Semper_Dad wrote: |
| Excellent diagram Glenn |
Not mine, it's from Speedy Jim's website. _________________ Glenn
Member #1009
#BlueSquare
Posted: Wed Feb 23, 2011 9:23 pm Post subject: |
So I just put it in reverse with the key on (motor not started) got underneith it and hit the switch with a test light. it said it wasn't getting power. Does the car have to be started in order to give the switch power? Also I found 2 wires connected to it, so I'm sure I'll have to chase the ends down.
Thanks _________________ Price does not include PayPal fees. Text is the fastest way to reach me |
Posted: Wed Feb 23, 2011 9:30 pm Post subject: |
| Pbotsonis wrote: |
Thanks |
Just need to have the key in the "on" position. One of the wires on the transmission is coming from the coil (via the bakelite fuse). Other wire is going to the backup lights (via a t-connector).
Turn the key to the "on" position (not start). Check for 12VDC at the following locations.
1) Bakelite fuse (both ends)
2) Transmission switch (both contacts) Make sure shifter is in reverse
3) Either one of the blue wires in the T4 connector
You can also remove both wires on the transmission switch and check for continuity on the switch (between contacts) with shifter in and out of reverse. Should be 0 ohms (short) when in reverse, Infinity (open) out of reverse. Do not have to have car on or start. In fact, keep key in pocket  _________________ Walküre Restoration Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=737492 |
Thing68 Samba Member
Joined: December 14, 2019 Posts: 71 Location: California
Posted: Sat May 23, 2020 11:56 am Post subject: Re: Reverse lights |
| Reviving an old thread here. Has anyone been able to replace the BU switch without removing the tranny? |
BJT Samba Member
Posted: Sat May 23, 2020 5:58 pm Post subject: Re: Reverse lights |
| I personally did not do it, but a guy that I had working on my Thing replaced it without taking out the trans. It should be very reachable. |
Posted: Sat May 23, 2020 6:20 pm Post subject: Re: Reverse lights |
| Thanks, if finally found where it is but it looks really tight quarters. |
FJBLF Samba Member
Posted: Thu May 28, 2020 5:13 pm Post subject: Re: Reverse lights |
Maybe this helps...
_________________ 1972 VW 181 SAFARI 1500 cc GRB Trans-axle |
