85 Weekender AC overhaul
Page: Previous  1, 2, 3  Next
Abscate
Abscate is offline
PostPosted: Sat May 30, 2020 7:23 pm    Post subject: Re: 85 Weekender AC overhaul Reply with quote
AZ Landshaper wrote:
Ok got the system back together after replacing some hose, adding oil, pulling a vac for four hours charging with red tek. I also replaced the drier and installed an updated condenser.
Ive got 30/200 for pressures and still have 77 degree air coming through the vents. The compressor runs as it should and the rad fan is on as soon as the switch goes on.
Any suggestions?
Expansion valve problem. With those pressure deltasyou should have a good 35F delta at the vent
AZ Landshaper
AZ Landshaper is offline
PostPosted: Sat May 30, 2020 8:07 pm    Post subject: Re: 85 Weekender AC overhaul Reply with quote
ambient temp was 98 degrees.
Support Small Business.
85 Weekender w/ EJ22
Previously
64, 71, 72, 73, 76, 81, 84, 85 & 87 Campmobiles and Westfalias
and a 67 bug.
Farf
Farf is offline
PostPosted: Sat May 30, 2020 8:13 pm    Post subject: Re: 85 Weekender AC overhaul Reply with quote
How much refrigerant did you put in? What did you use for supplemental cooling of the condenser? Does your R/D have a sight glass on it?
AZ Landshaper
PostPosted: Sat May 30, 2020 8:17 pm    Post subject: Re: 85 Weekender AC overhaul Reply with quote
I used about three cans of red tek refrigerant.
My fan was running, did I still need the box fan? Theres one over site if so.
Gonna look at the site glass. There's def one there.
Previously
and a 67 bug.
Farf
Farf is offline
PostPosted: Sat May 30, 2020 8:43 pm    Post subject: Re: 85 Weekender AC overhaul Reply with quote
200 psig @ 98F without a box fan is seems low. I'd try adding a bit more refrigerant along with using a box fan or water (very fine) mist on the condenser, allow the condenser fan to suck the mist in, don't spray it directly on the condenser. Take a look at your sight glass, ideally you want a solid liquid going into your TXV. At the ambient temp you are working with and using a blended refrigerant you will see bubbles, they should collapse by the time they hit the TXV. The bubbles should not be excessive. Be slow and careful. Watch your pressures.
MarkWard
MarkWard is offline
PostPosted: Sun May 31, 2020 4:54 am    Post subject: Re: 85 Weekender AC overhaul Reply with quote
What are the pressures at 2500 rpm?
Abscate
Abscate is offline
PostPosted: Sun May 31, 2020 5:20 am    Post subject: Re: 85 Weekender AC overhaul Reply with quote
Try taking it for a spin to see if the delta goes up with the car moving. At 98F, condesor will need flow
AZ Landshaper
PostPosted: Sun May 31, 2020 9:57 am    Post subject: Re: 85 Weekender AC overhaul Reply with quote
1500 rpm
900 RPM
2500 RPM
2500 RPM after 3 mins
Site glass looks cloudy and quite difficult to see.
As a side note the overhead cabinet is a real biotch to put back in place w/o help.
*Correction. Vent temp 79.8 And rising
Ambient is around 90.
Previously
and a 67 bug.
dhaavers
dhaavers is online now
PostPosted: Sun May 31, 2020 10:07 am    Post subject: Re: 85 Weekender AC overhaul Reply with quote
This ^^^ indeed. Also:
If you're doing all this work with the hatch & engine bay open, you're working against yourself
by consistently pulling in hot air (ambient) & even hotter air (from over the engine).
When charging &/or any time checking pressures, run hoses outside the van, hang manifold from
the rain gutter, put cover loosely over engine bay & drop the back hatch as far as possible... Cool
Try it, should help...
- Dave
PS... regarding cabinet:
"The WonderVan"
AZ Landshaper
PostPosted: Sun May 31, 2020 10:22 am    Post subject: Re: 85 Weekender AC overhaul Reply with quote
Did that. Idle at 900
Pressures are. 40/195
Hanging in the gutter. Hatch as closed as possible w cover loosely fitted.
Friggin 91.2 at vent. Confused
Iโ€™m thinking thereโ€™s air in there or some other contaminant. Would that account for decent pressures and ZERO frikkin cooling?
Re cabinet. Nice setup. If the cabinet comes down again Iโ€™ll be the new owner of those deals
Previously
and a 67 bug.
AZ Landshaper
PostPosted: Sun May 31, 2020 10:25 am    Post subject: Re: 85 Weekender AC overhaul Reply with quote
If I need to reduce on the low side do I just open the valve on the low side of the manifold and let some of this gas go or how is that exactly done?? Iโ€™ll be sure to have a smoke going while that goes down.
Previously
and a 67 bug.
Abscate
Abscate is offline
PostPosted: Sun May 31, 2020 11:35 am    Post subject: Re: 85 Weekender AC overhaul Reply with quote
Cycle the co press or off and see if the low side pressure climbs fairly quickly or if it stays stuck at 25-30 psi
Iโ€™m smelling the scent of plugged something on the low side, but my internet AC diagnostic Fu isnโ€™t great
AZ Landshaper
PostPosted: Sun May 31, 2020 11:45 am    Post subject: Re: 85 Weekender AC overhaul Reply with quote
When I turn everything off the pressure jumps to 80 on the low side and drops to 100 on the high.
Honestly itโ€™s gone from bad to worse. The pipe was getting cold and other getting real hot. Now. Just hot. Donโ€™t feel but a whee bit of cooling at the low pressure side plumbing.
Previously
and a 67 bug.
khughes
khughes is offline
PostPosted: Sun May 31, 2020 1:07 pm    Post subject: Re: 85 Weekender AC overhaul Reply with quote
When I turn everything off the pressure jumps to 100 or so on the low side.
OK, what do you mean by "everything off"? All the fans, or compressor as well?
When the compressor is not running, the pressure should equalize (high and low sides) at around 100psi. With the compressor running (it's really just a pump, pumping against restrictions in the system) the high side line will get very hot. The higher the pressure the higher the temperature; this goes back to the basic PV=nrT gas equation. You can ignore the "nr" in this case because the volume of the system is constant (the 'n' basically) and we're not interested in calculating the actual pressure, for understanding the system, so r can go away. So pressure (P) x volume (V) is proportional to the temperature (T). System volume can't change, so if pressure goes up, temperature goes up and vice versa. Ignore that there's liquid in the system - in *some* areas, because there's just gas going at the compressor. So high side line HOT, and the Suction line should be COLD.
The expansion valve at the evaporator provides the pressure drop in the system. Liquid refrigerant bleeds through the expansion valve into evaporator where it evaporates into gas, pulling out the heat. So the pressure at the outlet of the evaporator (i.e. the Low side pressure) corresponds to the temperature at that point. The air temp coming out of the evaporator is proportional to the average of the refrigerant temperature across the evaporator.
So when everything is off, the refrigerant bleeds through the expansion valve, and across the compressor valves, until the pressure in the system equalizes. So High and Low sides only exist during operation when you're pumping liquid through a restrictive orifice, i.e. the expansion valve. The valve modulates based on evaporator temperature, but is always a significant restriction.
What you're seeing is normal operation, pretty much. I've never used Redtek before, so I don't know what the pressure split should be, but based on your symptoms, I would say you're undercharged, or the expansion valve is having issues. Overcharge can mean gas/liquid mixture coming from the condenser (bubbles/foam in sightglass) due to more much gas heat than the condenser can handle, which then results in gas/refrigerant mixture going through the expansion valve, and less liquid to evaporate = higher evap temp and pressure. The expansion valve can also be allowing too much liquid into the evap, exceeding the evaps ability to evaporate all the liquid, so higher temp and higher low side pressure.
'86 Westy FAS GenV Turbo (Marvin)
MarkWard
MarkWard is offline
PostPosted: Sun May 31, 2020 1:25 pm    Post subject: Re: 85 Weekender AC overhaul Reply with quote
In all of the pictures, the high side pressures look a little low for a hot day, but If I had those pressures, I would expect the AC to be working better. I also don't have experience with Red Tek.
If you look at your gauges, the scales towards the center are temps. There is a correlation especially on the low side between the pressure and evap temp. I'm too lazy to read back. Did you put in a new expansion valve? To a point the early style is adjustable, but the system has to be open.
I'm resurrecting my AC and the replacement expansion valve is suited to 134. Its the H type though. Red Tek is supposed to be a magical gas that out performs everything. Problem is if you have to service your system, no one is going to have a recovery machine for Red Tek. So, I'd start with adding a little more before you let some out. You can always let it out.
high-speed wobble
high-speed wobble is offline
PostPosted: Sun May 31, 2020 1:36 pm    Post subject: Re: 85 Weekender AC overhaul Reply with quote
Are you seeing low side 'hunting?' My system is entirely rebuilt and recharged with Red Tek also, but my low side fluctuates between say 22 and 30 PSI so I am thinking I may be undercharged. I've read that hunting can be caused by undercharge.
I like your setup dhaavers. I did a similar thing with a boat stand. That thing was the only reason I was able to do this on my own I think:
Anyway I'm with you in your troubles right now, AZ Landshaper. I get about a 22-25 degree temp drop from ambient with pressures around 27(~22-30)/225, charging at about 72F and testing between 65 and 75F. I'd like to see my vent temps lower than ~50F at 75F ambient for sure with hopes for keeping the kid cool when temps are in the 90s.
1990 Westfalia, GW2.2, Peloquins TBD
Farf
Farf is offline
PostPosted: Sun May 31, 2020 2:17 pm    Post subject: Re: 85 Weekender AC overhaul Reply with quote
Your hunting is probably not caused by being undercharged, your TXV bulb could be loose or the TXV is not adjusted well enough to handle the high temperature glide of RedTek. The quote below is from the link. You might get better performance switching to 134A (PAG Oil needed in system). I believe several here have had to do this. RedTek has a glide of 14* just like the example below. The good thing about your TXV hunting is that it shows your TXV is working.
https://secureservercdn.net/198.71.233.179/m9v.7b6...-Mar06.pdf
"This system is retrofit to a high-glide blend that has 14ยบ F of temperature glide, as shown in the second diagram. In this case, the average evapora-tor temperature would be the same as the original boiling point. However,the blend would enter the evaporator about 7ยบ F lower than the original temperature and the saturated vapor at the end of the evaporator would be about 7ยบ F warmer than the original temperature.If no changes were made to the TXV bulb setting, then, given our first example, the superheat setting would be reduced from 10ยบ F to 3ยบ F. This would be an unacceptably low value for super heat and the valve would probably hunt or have trouble maintaining proper operation."
AZ Landshaper
PostPosted: Sun May 31, 2020 2:18 pm    Post subject: Re: 85 Weekender AC overhaul Reply with quote
Theres no hunting. Its pretty solid. Not one lick of cooling occurring.
Pipe from the compressor is cool to touch but not cold.
The TXV seems to be working. The low is around 30-40 and the high 200-225 when the engine and compressor are off the system equalizes near 100.
TXV is not new and its not the H type. it was replaced by a PO who converted to 134.
Frustrating to say the least.
Unfortunately more than one person has contacted me to say I should ditch the red tek. One said he was never able to get temps below 65 and the other is a naysayer that thinks Ill be at an AC tech before the weekend and they wont touch it. Both have working AC in vanagons.
My concern is every time I need to recharge Ive got to send money to Tennessee and wait for a delivery. Ive used 4 cans of the stuff so far. Only one left.
Previously
and a 67 bug.
high-speed wobble
PostPosted: Sun May 31, 2020 3:10 pm    Post subject: Re: 85 Weekender AC overhaul Reply with quote
Farf, I've read a lot of your comments in the Red Tek thread. You seem knowledgeable about A/C systems like this, do you know whether the TEV hunting can cause damage elsewhere in the system? My compressor (and everything else) is brand new, and this seems like the sort of thing that could dump liquid into the suction. I'd like to do some higher-temperature testing but I don't want to cause damage.
I have the late model "H" type expansion valve, and no idea how begin with adjusting it. I hate giving my van over to shops but maybe this is one to consider hiring out. When I rebuilt my hoses, I moved both my service ports to the compressor fittings. Very glad I did that if I am looking at getting a tech to look at it.
AZ Landshaper, sorry to hear about your troubles. That seems like a difficult to diagnose problem since your pressures seem good. Very frustrating. If you end up at a shop, I wouldn't mind hearing what kind of performance you end up with.
Howesight
Howesight is offline
PostPosted: Sun May 31, 2020 3:21 pm    Post subject: Re: 85 Weekender AC overhaul Reply with quote
Hi Landshaper:
1. Can you post some pics of your whole evaporator box assembly? It's hard to tell from your other pics (including your gallery) what your evaporator setup is. Mainly, I question whether your AC evaporator plenum is forcing all air through the evaporator or whether some ambient air is permitted to flow around the evaporator instead of through it.
2. Looking at the gauge pressures your posted in pics and the 90F degree ambient temps you mention, I think that your refrigerant fill is on the low side and you could usefully add some, provided that your AC compressor is not a variable-displacement design. If it is a variable-displacement design, (see below) then you might already have enough refrigerant in your system.
3. Also, could you post some pics, including the part numbers on your compressor? I think that you might have a variable-displacement compressor on your EJ-22 which would explain the relatively small changes in low-side pressure. If the variable-displacement control system is malfunctioning, that could explain why your system yields low-side pressures in a range that should yield a lot lower evaporator vert temps, but still fails to do so. Essentially, the low pressures at the low side, when the variable-displacement system is operating correctly (there are electronically-modulated versions and purely-pressure modulated systems) are the signal to the compressor, in the pressure-modulated versions) to increase the compressor's output
4. After the variable-displacement system reduces compressor flow, as described above, your TXV is only spitting out a tiny bit of liquid refrigerant into evaporator which instantly evaporates (you should feel a cold portion of the plumbing right after the TXV) and this is not sufficient to adequately cool the remainder of the evaporator. In essence, you might just have a malfunctioning TXV which malfunction is being hidden by the combination of the variable-displacement compressor and its operation. I say this because the pressures you show would, if there were no variable-displacement compressor, likely cause low-side pressures to be much lower than indicated as your compressor would suck the gaseous refrigerant and the high-side pressures would rise, as the compressor would be running at "maximum" displacement. Compressors without this feature run at maximum displacement at all times and address high-side over-pressure and low-side under-pressure by cycling the compressor clutch on and off.
Here is a link to an article on general diagnosis of problems in variable-displacement compressors: https://www.motor.com/magazine-summary/diagnosing-variable-displacement-compressors
Remember that the Vanagon evaporator is HUGE compared to modern vehicles and even compared to 1980's vehicles. It needs a large flow of refrigerant, especially when the evaporator is initially being chilled, to start to extract heat from the air flowing through it.
'86 Syncro Westy SVX
Page 2 of 3
