strange steering feel after new coupler
Page: 1, 2, 3  Next
Fairmounter
Fairmounter is offline
PostPosted: Sat May 30, 2020 11:26 am    Post subject: strange steering feel after new coupler Reply with quote
I had my steering coupler replaced and now when I turn left the steering is immediate and responsive, but when i turn right i have to turn the wheel almost half a turn before it starts to turn. Any ideas on what would cause it to be loose one way and not the other? Thanks much
1973 Westy Tintop
SGKent Premium Member
SGKent is offline
PostPosted: Sat May 30, 2020 11:30 am    Post subject: Re: strange steering feel after new coupler Reply with quote
sounds like someone screwed up the installation
Fairmounter
PostPosted: Sat May 30, 2020 11:32 am    Post subject: Re: strange steering feel after new coupler Reply with quote
How so?
1973 Westy Tintop
Wildthings
Wildthings is offline
PostPosted: Sat May 30, 2020 1:57 pm    Post subject: Re: strange steering feel after new coupler Reply with quote
Was anything else done, like a wheel alignment? Have you checked your tire pressures?
Jetfxr69
Jetfxr69 is offline
PostPosted: Sat May 30, 2020 3:20 pm    Post subject: Re: strange steering feel after new coupler Reply with quote
Whoever did it, got your gearbox off center. When they took everything apart, they allowed the steering wheel to rotate away from where it was, and then rebolted. I would imagine they got all the bolts back together, but either pull the dome cover from above ( 2 screws) and/or the splash pan below, and verify all 4 bolts are installed.
And then take it back to them
You can't be a real country unless you have a beer and an airline. It helps if you have some kind of a football team, or some nuclear weapons, but at the very least you need a beer. Zappa
‘77 westy Seamus
‘76 tintop Crusher
‘77 westy The Judge
‘72 tintop bastard westy Hudson
Fairmounter
PostPosted: Sat May 30, 2020 4:28 pm    Post subject: Re: strange steering feel after new coupler Reply with quote
Thanks, he also straightened the steering wheel. i checked underneath and the coupler looks fine, all four bolts tight. While under there i noticed that the steering arm that connects to the steering box looks to be traveling off of the splined shaft. The big nut is still attached but there it looks like the pin was not installed through the castle nut. The nut is still attached but the castled part is past the threads. It looks to me like the nut clearly needs to be tightened and pin installed through the castle nut, but would that cause more play to the right than the left?
1973 Westy Tintop
SGKent is offline
PostPosted: Sat May 30, 2020 5:16 pm    Post subject: Re: strange steering feel after new coupler Reply with quote
The steering box has a high spot dead center. The steering arm has a line on it that lines up with a line on the shaft. If he pulled that nut off to realign your steering run from this fellow. That nut has to be torqued to spec. Some refer to nuts like that as a "Jesus nut," because if it comes off only Jesus can save you.
Jetfxr69
Jetfxr69 is offline
PostPosted: Sat May 30, 2020 5:57 pm    Post subject: Re: strange steering feel after new coupler Reply with quote
If you found that arm backing off the gearbox spline shaft, then yes, thats a HUGE problem. So huge that your lucky your still alive. Guess what happens when that arm comes off? It doesnt even need to come completely off, just free from the splines.
If you had to have that coupler done by someone else, im not sure if you will be able to repair the problem, but here goes.
Pull the drag link off and manually straighten your wheels (by hand). Take the arm off the gearbox spline shaft ( the one thats almost falling off). Once the arm is free from gearbox, the coupler will rotate exactly 3 1/2 rotations from one direction to the other. Go all the way one way and note the position of any one of the four bolts on the coupler. Rotate the wheel so that that bolt goes 1 3/4 turns. At this point there is a small mark on the coupler shaft that will line up with a small arrow on the top aft portion of the gearbox (looking from inside cab down). This is center.
Reattach arm onto gearbox splined shaft. Choose the spline orientation that allows the drag link to slip back into the arm. Depending on how straight you set your wheels, you should be very close to center. Dont worry about where the steering wheel spokes are. That can be straightened by removing, reindexing, and reinstalling your steering wheel.
Again, this may be more than your willing, capable, or comfortable doing.
‘77 westy Seamus
‘76 tintop Crusher
‘77 westy The Judge
Fairmounter
PostPosted: Sat May 30, 2020 6:45 pm    Post subject: Re: strange steering feel after new coupler Reply with quote
Thanks much. What if I just tighten the nut with the current position on the spline?
1973 Westy Tintop
Fairmounter
PostPosted: Sat May 30, 2020 6:50 pm    Post subject: Re: strange steering feel after new coupler Reply with quote
Am I correct in assuming that there should be a cotter pin going through the castle nut?
1973 Westy Tintop
Wildthings
PostPosted: Sat May 30, 2020 6:53 pm    Post subject: Re: strange steering feel after new coupler Reply with quote
I have never heard of a Pitman arm coming loose, that nut should be bum f*ck tight, I am sure it can happen though if someone is delinquent.
Once you get the Pitman arm aligned and installed correctly you may have to adjust the length of the drag link. With the steering box centered and Pitman arm aligned with the arrow, you want the wheels to point straight ahead. Straightening the steering wheel is the last step.
Jetfxr69
Jetfxr69 is offline
PostPosted: Sun May 31, 2020 3:04 am    Post subject: Re: strange steering feel after new coupler Reply with quote
If that nut was loose, then his mechanic pulled that arm off to “align” the wheels. Whats unknown is if he pulled it off to reset it in proper mark position ( doubt it), or thought that it would straighten wheels instead of drag link adjustment.
Regardless, its a scary thing to find loose. Crank that nut down and maybe your all set. Good luck and dont go back to that guy.
‘77 westy Seamus
‘76 tintop Crusher
‘77 westy The Judge
babysnakes
babysnakes is online now
PostPosted: Sun May 31, 2020 5:03 am    Post subject: Re: strange steering feel after new coupler Reply with quote
No, the shaft and arm both have a small notch that have to align with each other to give you that 50/50 turning radius left and right.
You also need that cotter pin going through the castle nut. No ifs, ands or buts.
Wildthings
PostPosted: Sun May 31, 2020 7:03 am    Post subject: Re: strange steering feel after new coupler Reply with quote
Looking in the manual the nut requires 140 NM of torque or 101 Ft*Lbs of torque, this is the minimum torque, you may need to apply more to get the cotter pin in. You need a decent combo wrench or socket set to apply this much torque. Just don't tighten it down with a 12" adjustable wrench and think you have it.
Abscate Premium Member
Abscate is offline
PostPosted: Sun May 31, 2020 7:08 am    Post subject: Re: strange steering feel after new coupler Reply with quote
You need to fix this first. This is a non-drivable car until this is fixed
Fairmounter
PostPosted: Sun May 31, 2020 12:54 pm    Post subject: Re: strange steering feel after new coupler Reply with quote
Thanks, much appreciated.
1973 Westy Tintop
SGKent is offline
PostPosted: Sun May 31, 2020 1:04 pm    Post subject: Re: strange steering feel after new coupler Reply with quote
you will need to look carefully at the arm and the shaft. There are small stamped marks that align. The mark on top of the gearbox and the rubber puck with a raised area are not the marks being referred to on the drop arm and the shaft. It may take a very strong puller to pull the arm off. The nut torques to 101 ft lbs. You will need a torque wrench and a really big socket that fits to do this. You leave the nut loose but on when you go to pull the arm because it will sound like a small rifle shot when it pops loose. Then you align the marks and put it back on. If the steering isn't centered then you use the drag link to center it.
Fairmounter
PostPosted: Sun May 31, 2020 3:26 pm    Post subject: Re: strange steering feel after new coupler Reply with quote
I am not seeing the marks stamped on the shaft and arm. is it on the end of the shaft? The nut is bigger than my biggest 1/2" socket. I will need to get a socket tomorrow. Does anyone know what size the bolt is?
1973 Westy Tintop
Zed999
Zed999 is offline
PostPosted: Mon Jun 01, 2020 1:34 am    Post subject: Re: strange steering feel after new coupler Reply with quote
When you do tighten it, do not simply allow the arm/box to run to the end of it's travel and heave against that or you could/will damage the box. Get a piece of pipe to slide over the arm and hold it tight or arrange such that the pipe jams against the floor or other convenient stop.
Wildthings
PostPosted: Mon Jun 01, 2020 6:45 am    Post subject: Re: strange steering feel after new coupler Reply with quote
Remove the arm and take some pictures of the box.
Page: 1, 2, 3  Next
