Rocker Arm Geometry Bad...Do I have a Head/Rocker Mismatch?
bthompson
bthompson is offline
PostPosted: Sun Jul 24, 2005 4:41 pm    Post subject: Rocker Arm Geometry Bad...Do I have a Head/Rocker Mismatch? Reply with quote
Trying to bring an old 1600 DP buggy to life. When I adjust the valves, the valve adjusting screws dont quite align on cylinders 2 & 4... WTF?
I have no history on the motor, but it looks to have been rebuilt...
Do rocker arms need to match the type of head ? any other ideas?
tcrdn
tcrdn is offline
PostPosted: Sun Jul 24, 2005 5:02 pm    Post subject: Reply with quote
The rocker arms should be ambidextrious (sp)
Are there washers installed under the rockers by any chance? That would screw up the geometry. There should be a very thin wavy washer under there and thats all.
If I remember correctly, the rockers are the same for all the engines but I could be mistaken on that. Can you post pictures?
TC
GjMan
GjMan is offline
PostPosted: Sun Jul 24, 2005 6:55 pm    Post subject: Reply with quote
By "don't quite align" do you mean the tip of the adjuster is not on the center of the valve stem but a little off to one side or the other?
As for valve train geometry, it is correct if the centerline of the valve is parallel to the centerline of the adjustingh screw at half-lift. I've never tried checking geometry with the engine installed, but I suppose it could be done.
BTW, chances of your valve train geometry being correct are slim, since most engine rebuild shops have no clue about this.
bthompson
PostPosted: Mon Jul 25, 2005 3:59 pm    Post subject: Thanks for the info Reply with quote
Thanks for confirmimg that it's not something stupid like I have the Rocker Arms switched... I'll need to dig in deeper to figure out what's happening....
Engine won't start, it's getting spark and gives me the occassional "pop" when I spray engine starting fluid down the carb.
I'm off to check the compression....
Junkyard Buggy Builder bringing 70's sand rails rails back to life for my kids to thrash.
towd
towd is offline
PostPosted: Mon Jul 25, 2005 11:43 pm    Post subject: Reply with quote
There is no washer that goes under the rockers. only in the case of storker, longer rods or hi lift arms. The wavy washer is a stock lock washer for the bolt (spring washer)
temurphy3
temurphy3 is offline
PostPosted: Tue Nov 25, 2008 6:26 pm    Post subject: What is a sticky?? Reply with quote
Hi,
I'm new to this forum thing and I think its wonderful!! I'm planning on building a 1644 motor and using 1.25 or maybe 1.40 rockers with a stock cam. So I've been reading up on installation of the rocker arms but I cannot find the "rocker arm geometry" "Sticky" that everyone is talking about. Can someone explain what a sticky is? Maybe the path to get to this reading item??
Thanks a million!!
Viande
Viande is offline
PostPosted: Tue Nov 25, 2008 10:34 pm    Post subject: Re: What is a sticky?? Reply with quote
temurphy3 wrote:
Hi,
Thanks a million!!
http://www.thesamba.com/vw/forum/viewtopic.php?t=167378
Bobby
New Items In Stock, NOS & OEM Seals,Parts and Terminals
My Feedback Here
The bitter taste of poor quality lingers long after the joy of the cheap price fades away.
gerg
a.k.a. 6volt65
gerg is offline
PostPosted: Wed Nov 26, 2008 12:54 am    Post subject: Reply with quote
You can check it in the car but it is a B*TCH.
I did mine when I added 1.25s to my 1914.
Then when I built the 2276 I did it on the stand and it was Soooooo much easier!
This is what you should be aiming for - at least I think it is (at half lift):
This shows a little off:
The setup I used:
You'll also need to know your cam's lift and the ratio of the rocker so you know what half lift actually is.
If you are not cutting push rods or adding shims under the rocker bases I am not sure there is anything for you to do other than verify how close it is.
My assumption is that with stock parts (All stock) the alignment is close enough per VW.
Most people doing this have an adjustable push rod tool and cut specific length push rods when they figure out what works best.
Gerg
. . . I got 99 problems and my bus ain't one . . .
'65 Sunroof Beetle
'65 Vert
'60 Singlecab
View user's profile Send private message Send e-mail Visit poster's website Yahoo Messenger Gallery Classifieds Feedback
