vwsplitvan Samba Member
Posted: Mon Jul 27, 2020 4:34 am Post subject: Rear Bumper splash pans fitting Something not right? |
Just building up the 63 bus and having a few probs with the rear bumper splash guards.
Something is not quite right.
The lower tab on splash guard does not line up with threaded side mounting in bumper.
And the cut outs just don't seem to let it sit right in bumper.
Looking for decent pics or advice.
The rear bumper is slash cut.
The splash pans are WW kit. Ordered for this year of bus. But maybe I have been sent wrong ones?
Or I am doing something wrong.
I have attached the curved piece of metal in the kit that attached on the top side of splash guard. And that takes bolt thru the Body of the bus in rear lower corner.
The lower tab lines up with nothing. I expected this to be where it bolts to the welded mounting in the side of bumper.
Am I getting something wrong?
Or is this wrong year of guard?
Dimensions to check it would help if anyone can check 👍
Added some photos below
_________________ SBS #20 UK
RHD 62 Ragtop Beetle Beryl Green
LHD 69 Squareback Peru Green
LHD 63 Splitscreen Highroof Pearl White |
Krustybus Samba Member
Joined: February 16, 2004 Posts: 442 Location: SE Michigan
Posted: Mon Jul 27, 2020 6:02 am Post subject: Re: Rear Bumper splash pans fitting Something not right? |
Thanks Krustybus
Yes I know they go on inside. Just bolted there loosely whilst I try and work out why the tab that bends downwards on that part is do far from the bumper side fixing. _________________ SBS #20 UK
busdaddy Samba Member
Joined: February 12, 2004 Posts: 52761 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Mon Jul 27, 2020 8:09 am Post subject: Re: Rear Bumper splash pans fitting Something not right? |
vwsplitvan wrote: |
The splash pans are WW kit. Ordered for this year of bus. But maybe I have been sent wrong ones? |
They look an awful lot like early bay pans. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
EverettB  Administrator
Joined: April 11, 2000 Posts: 71507 Location: Phoenix 602
Posted: Mon Jul 27, 2020 8:50 am Post subject: Re: Rear Bumper splash pans fitting Something not right? |
I don't think it's this simple but:
What doesn't line up here?
It looks like you need to raise the splash pan a little and then bolt it to the bumper from underneath
Your bumper bracket is not stock so maybe it's in the wrong place?
Stock parts:
_________________ How to Post Photos
Posted: Mon Jul 27, 2020 8:54 am Post subject: Re: Rear Bumper splash pans fitting Something not right? |
busdaddy wrote: |
vwsplitvan wrote: |
They look an awful lot like early bay pans. |
The shape looks Split Bus to me.
Early Bay are cut differently:
His Split Bus ones
Look at the shape around where the bumper bracket sits _________________ How to Post Photos
BarryL  Samba Member
Joined: November 01, 2004 Posts: 15217 Location: Casa de Oro, California
Posted: Mon Jul 27, 2020 12:01 pm Post subject: Re: Rear Bumper splash pans fitting Something not right? |
Drop in your part that bolts to the side first so the edge that holds the rubber seal is real close to the blade. Then see how the part that sits on top of the bumper-to-body bracket fits. You might have to slide the bracket inward. You might have to notch your splash pans more to fit your bumper type splash pan brackets. |
Posted: Mon Jul 27, 2020 12:07 pm Post subject: Re: Rear Bumper splash pans fitting Something not right? |
Hi EverettB
The issue is the tab that is bent downwards that is supposed to line up and bolt to the bumper tip mount is no where near it.
Maybe it is the bumper which I believe is repro WW.
The splash pan does not sit well on the rear bumper mount bracket either.
Looks like I would need to trim parts to get a good fit.
I have drawn where the tab is and where it should fix. It is way off.
I will get back to it in next couple days and see what needs doing.
But have a feeling I need to trim the cut outs.
BarryL  Samba Member
Posted: Mon Jul 27, 2020 1:57 pm Post subject: Re: Rear Bumper splash pans fitting Something not right? |
vwsplitvan wrote: |
But have a feeling I need to trim the cut outs. |
This ^^^ so it can nestle in close to the blade with the rubber seal on. |
Posted: Mon Jul 27, 2020 4:11 pm Post subject: Re: Rear Bumper splash pans fitting Something not right? |
Ok, I understand now.
I'm wondering if you are going to have to trim it too, especially since the outer mount on the bumper is so much wider than an original.
I went outside and measured the distance on my original bumper from the bolt hole to the edge.
This could at least verify for you that the bracket and bolt hole are in the right spot.
Distance = Approx. 3 1/4" from center of hole straight over to the edge
It looks like maybe they already trimmed it larger then originals, maybe to compensate for their brackets?
An NOS splash pan, the cut out for the side bracket is shorter
Upper left in this photo _________________ How to Post Photos
Clara  Samba Member
Posted: Mon Jul 27, 2020 5:12 pm Post subject: Re: Rear Bumper splash pans fitting Something not right? |
for some reason it's hard for me to see your splash pans clearly.
something is not right.
maybe this helps?
from the classifieds:
BTW, I assemble with bolts NOT snugged down, then install on bus, lastly snug down the bolts holding the pieces together. |
Posted: Tue Jul 28, 2020 7:14 am Post subject: Re: Rear Bumper splash pans fitting Something not right? |
I have 2 1/2 Inches from edge to threaded hole in Slash cut bumper.
It also looks like I need to make the cut out bigger to fit around the rear bumper support bracket mount.
Shame as I got these powder coated already 🙄
Thanks for checking measurement EverettB 👍
I also decided to order new repro bumper brackets. Without the bumper on the splash pans fit nice.
I will take another look tomorrow.
EverettB wrote: |
Upper left in this photo |
