New bus muffler
splitpile
Samba's Worst Speller
splitpile is offline
PostPosted: Wed Jul 27, 2005 12:10 pm    Post subject: New bus muffler Reply with quote
I have been working on a new muffler/header for a split or up to 71 bus with a 1600 or larger engine.
We will be testing it on a dyno on some bigger then stock engines to see how it works. It did make a noticeable difference on the stock 1600 SP in the test/fit bus and will be testing on a 1776 and 1800 this weekend.
A few more tweeks and they will be ready for sale.
tailpipe comes out in stock position
pic of exhuast
"no more hacking my sig line"
brewerjas
brewerjas is offline
PostPosted: Wed Jul 27, 2005 12:45 pm    Post subject: Reply with quote
That looks really good Ronnie. How much is the estimated damage($) gonna be?
'67 Kombi/EZ Camper
-OGST-
"from man's sweat and God's love, beer came into the world."
Saint Arnold 612 AD
Bishop of Metz, France
Andrew
Andrew is offline
You're my hero.
-Andrew
Andrew
Andrew is offline
PostPosted: Wed Jul 27, 2005 1:03 pm    Post subject: Reply with quote
How long until these are available to be purchased?
-Andrew
splitpile
PostPosted: Wed Jul 27, 2005 1:15 pm    Post subject: Reply with quote
I have 2 more prototypes that will be here Friday (for dyno work) and the final version will be here next week for final fit. If everything works out they will be available in approx 2 to 3 weeks, raw or ceramic coated.
Andrew
Andrew is offline
PostPosted: Wed Jul 27, 2005 1:19 pm    Post subject: Reply with quote
How does it sound? And what's the estimated cost?
-Andrew
P-Dub
P-Dub is offline
PostPosted: Wed Jul 27, 2005 1:20 pm    Post subject: Reply with quote
By the looks of this muffler, I am assuming it's less restrictive than stock. If so, how "big" could you go with this muffler?
splitpile
PostPosted: Wed Jul 27, 2005 1:55 pm    Post subject: Reply with quote
It's quieter than a header with a single quiet pak
The whole purpose is to make something for bigger then stock engines and retain a somewhat stock appearance.
We will be testing them on a
1776 with heater boxes
1800 stroker with heater boxes
and for shits and giggles a 2087 (welded flanges and J tubes)
RobzKombi
RobzKombi is offline
PostPosted: Wed Jul 27, 2005 2:09 pm    Post subject: Reply with quote
Definitely keep us posted on price and dyno results. Is the 1776 DP with D/carbs?
iveedubbin
iveedubbin is offline
PostPosted: Wed Jul 27, 2005 2:35 pm    Post subject: Reply with quote
This will definitely Fix my fit issues with my bumper and current header
Kaput
Kaput is offline
PostPosted: Thu Jul 28, 2005 9:47 pm    Post subject: Reply with quote
will that work with a non bent rear apron?
splitpile
PostPosted: Thu Jul 28, 2005 9:58 pm    Post subject: Reply with quote
The apron is not bent (only one little spot on the right in the pic), it only appears to be because of the angle I took the pic.
One of the mods is the muffler is being moved closer to the engine and also up a little more to hide it a little better and to get some more clearance between the apron and the muffler.
This is the fist one that was test fit and the mods are now being made for the production versions
pyrOman
Fire Master
pyrOman is offline
PostPosted: Fri Jul 29, 2005 6:57 am    Post subject: Reply with quote
In the "raw" version, are you using stainless or plain steel? Confused
Ragman
The Sambinator
Ragman is offline
PostPosted: Fri Jul 29, 2005 7:18 am    Post subject: Reply with quote
what a great idea! I've been messing with crappy fitting aftermarket header/single pack combos for too long on my 66 w/ a 1776. None of them have fit correctly under the bumper.
RobzKombi
PostPosted: Fri Jul 29, 2005 8:01 am    Post subject: Reply with quote
any updates with the set up?
splitpile
PostPosted: Fri Jul 29, 2005 8:06 am    Post subject: Reply with quote
There are no plans for stainless. They will be available raw (not painted) or ceramic coated
ronnie
Location: lost somewhere between the earth and my home.
ronnie is offline
PostPosted: Fri Jul 29, 2005 8:45 am    Post subject: Reply with quote
Will a CB performance pump mount oil filter fit?
Clara Premium Member
Clara is offline
PostPosted: Fri Jul 29, 2005 8:45 am    Post subject: Re: New bus muffler Reply with quote
splitpile wrote:
I haven't seen a bumper like that for a while. I had those peashooter holes on my first splitty, a 59, and it had the bug tail pipes sticking out the holes a la Muir.
Damn, I miss that bus. It was aqua too. with a SWR dash
splitpile
PostPosted: Fri Jul 29, 2005 8:58 am    Post subject: Reply with quote
I haven't checked that yet but I am pitting one on my 1800 stroker tomorrow and it has the CB pump so we'll know tomorrow
pyrOman
Fire Master
pyrOman is offline
PostPosted: Sun Jul 31, 2005 4:04 pm    Post subject: Reply with quote
Great! I am aiming to do away with all the full flow hosing and all that jazz and go with the pump/filter combo also! Very Happy
This topic is locked: you cannot edit posts or make replies.    Forum Index -> Split Bus All times are Mountain Standard Time/Pacific Daylight Savings Time
Page 1 of 8
