DanHoug Samba Member
Joined: December 05, 2016 Posts: 5773 Location: Bemidji, MN
Posted: Thu Aug 27, 2020 4:34 pm Post subject: Dometic RM182B exhaust mod |
there's probably a thread this should be tagged onto, Mods, feel free to move....
added insulation to the exhaust pipe on the fridge. this accomplished 3 things, all good:
- greatly reduced heat released to interior and specifically to the area around the fridge, increasing the Delta T between the heat sink fins and the ambient air.
- increased the stack temp of the exhaust and eliminated 'the drip' from condensing acidic water vapor from the flue vent. this, IMHO is why there is seam rust on the kitchen side. it is not from the water connection, it is from the acid rain that falls between the aluminum intake/outlet piece and the rubber gasket and dribbles inside the body panel.
- increased the flue temp differential which results in greater draft between the exhaust and intake lines. results in a better burn. just like hot rodders wrap headers to conserve the energy of the exhaust cooling and creating slower boundary layer, the insulation keeps the pipe temp up for better flow.
i started with a wrap of quality header wrap. while the temps are low, the cheap offshore stuff actually burns up on the manifold. pretty crucial application on the interior so spending an extra bit to get the good stuff is wise. used Design Engineering header wrap, serving the hot rodders for generations.
then, because it is so dang fast and cheap to do, made a wrap of aluminum foil to add an IR reflective layer.
the results are great. NO vent drip, yes the vent cover is hot now, no the rubber isn't melting. reduced interior temps behind fridge, the fan cycles less. i'm happy. _________________ -dan
www.thefixitworkshop.com |
Yellow Rabbit Samba Member
Posted: Thu Aug 27, 2020 6:47 pm Post subject: Re: Dometic RM182B exhaust mod |
I like it. I’m surprised the factory didn’t do something like this. What was the change in interior temp? |
SSWesty Samba Member
Joined: August 20, 2008 Posts: 735 Location: Bellevue
Posted: Thu Aug 27, 2020 8:04 pm Post subject: Re: Dometic RM182B exhaust mod |
Looks like a good mod. How many feet of tape did you need, I see it comes in 15' rolls. Also do you recommend 1" or 2" wide wrap? |
Posted: Fri Aug 28, 2020 5:19 am Post subject: Re: Dometic RM182B exhaust mod |
i'd bought a 25' roll of 2" and have at least 1/2 left over. you need to do a 50% overlap so 2" gives more to land on. some brands suggest soaking the stuff in water first to mold easier and quite frankly, i forgot. it puckered a bit on the sharp curves but nothing terrible, soaking would have reduced the pucker but be messier to work with. you'll need steel ty-wraps or use wire.
whatever you buy, wear gloves. it's nasty stuff that releases glass hairs like crazy.
with regard to the quantitative interior temp difference... it's 'better'. the passive heat flow out of the side vent is less and when the fan i have mounted in the vent kicks on, wired to the main fan, the air is cooler. _________________ -dan
spitsnrovers Samba Member
Joined: December 17, 2005 Posts: 940 Location: Calgary, Canada
Posted: Fri Aug 28, 2020 6:49 am Post subject: Re: Dometic RM182B exhaust mod |
DanHoug - great mod and writeup!
In my mod to extract heat from the fridge flu to keep shower water warm overnight, I added fibreglass and aluminum foil. Wish I had known about the wrap you used.
My results are shown herehttp://www.griffco.ca/VW/fridgeheat.htm
Its a long story, but the last frames show the final results. _________________ '88 VW Westfalia
'75 Triumph Spitfire 1500 |
Posted: Fri Aug 28, 2020 9:25 am Post subject: Re: Dometic RM182B exhaust mod |
spitsnrovers wrote: |
Its a long story, but the last frames show the final results. |
that was an impressive bit of experimentation! yeah, i think a longer heat exchanger on the upper part of the exhaust tube would give you all the heat you want if it was wrapped. interesting how the HX drew too much heat away from the ammonia pipe when it was closer. anything above that is 'free' as long as draft is maintained. _________________ -dan
jlrftype7 Samba Member
Posted: Fri Aug 28, 2020 10:09 am Post subject: Re: Dometic RM182B exhaust mod |
Wow, you were DEDICATED to getting this right.... More patience than I could muster....  _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
‘84 Tin Top - Hilga....Auto |
Posted: Fri Aug 28, 2020 5:03 pm Post subject: Re: Dometic RM182B exhaust mod |
DanHoug wrote: |
with regard to the quantitative interior temp difference... it's 'better'. the passive heat flow out of the side vent is less and when the fan i have mounted in the vent kicks on, wired to the main fan, the air is cooler. |
Excellent thanks for the additional info, I've never worked with the stuff so this is helpful. |
