Bobnotch Samba Member
Joined: July 06, 2003 Posts: 23579 Location: Kimball, Mi
Posted: Sun Aug 30, 2020 8:39 pm Post subject: Re: 1970 Fasty Danish barn find |
| Clatter wrote: |
Heat!
Get that thing glowing red hot and it will come free..  |
Yup. _________________ Bob 65 Notch S with Sunroof
| Tram wrote: |
| "Friends are God's way of apologizing for relatives." |
| Tram wrote: |
| People keep confusing "restored" and "restroyed". |
Dlglobal1 Samba Member
Posted: Mon Aug 31, 2020 2:25 pm Post subject: Re: 1970 Fasty Danish barn find |
Thanks guys! Allot of heat did the trick. Now, the bolt that holds the pitman arm to the steering box...there is a seal in there right? That big bolt has been there for 50 years so I guess heat is needed there too. Is that seal available in case I goof and melt it? Steering box is in good shape so only plan to open the top, clean it out fill with corn head grease and be done.
_________________ Cheers, David
1969 Bug
1972 Bug
1968 Mercedes 230 "Heckflosse"
1970 Type 3 Fastback 1600 TA L60D |
Tram Samba Socialist
Joined: May 02, 2003 Posts: 23022 Location: Northwest of Normal
Posted: Tue Sep 01, 2020 3:50 pm Post subject: Re: 1970 Fasty Danish barn find |
| Dlglobal1 wrote: |
Get some Sili Kroil. Soak it for a few days. Remove the nut. Get the right buller and crank it tight. Walk away for awhile. Come back, knock the side of the pitman arm with a BFH. More Sili Kroil, crank the puller tighter, walk away.
Repeat as necessary. It'll come. _________________ Немає виправдання для війни! Я з Україною.
| Bryan67 wrote: |
| Just my hands. And a little lube. No tools. |
Those who can- do.
Those who can't? Subaru. |
Posted: Wed Sep 02, 2020 8:08 am Post subject: Re: 1970 Fasty Danish barn find |
Thanks Tram. I assume no heat on the bolt then. _________________ Cheers, David
1969 Bug
1972 Bug
Posted: Sun Nov 15, 2020 2:57 pm Post subject: Re: 1970 Fasty Danish barn find |
Managed to get all the steering components disassembled, cleaned and back together. Tore down the steering box and rebuilt it (thanks for the awesome tutorial OKType3Tim).
1969 Bug
1972 Bug
