Weber window fans
tattooed_pariah
tattooed_pariah is offline
PostPosted: Mon Sep 07, 2020 2:09 pm    Post subject: Weber window fans Reply with quote
As I'm battling the radiator and it's electric fans on another project car, a thought occurred to me..
a lot of us have weber windows, and with the gentleman who recently designed a duct to ram air in that area, I was wondering about the benefit or downfalls of small, but high CFM fans, PULLING air out of weber windows?
Now, I don't want to start a damn war about "the germans designed the engine compartment exactly as it needed to be! stop messing with perfection!" I'm just posing an idea for CONSTRUCTIVE criticism..
My thinking (with a TOTAL lack of engineering background..) is a radiator fan works by pulling air through the radiator from the engine side, so would the same idea work to pull air away from the engine into the wheel well? you'd still have intake from the louvers on your hood and the louvers below the rear window, but now you'd have something pulling the extra hot air away from everything..
I know you'd have to protect them from road debris, but would it work in theory?
-pariah
'72 Volksrod
bsairhead
bsairhead is offline
PostPosted: Mon Sep 07, 2020 2:36 pm    Post subject: Re: Weber window fans Reply with quote
Pushing air into the the motor compartment might help, pulling air from the fan shroud would be a bad idea.
tattooed_pariah
PostPosted: Mon Sep 07, 2020 2:48 pm    Post subject: Re: Weber window fans Reply with quote
it was my understanding that the inbound air arrives from the top of the engine compartment whereas these exhaust fans would be located somewhere nearer to the bottom. so any air being pulled out should have already flowed past the fan shroud, but yes, i agree that would be a major concern
-pariah
'72 Volksrod
Floating VW
Floating VW is offline
PostPosted: Mon Sep 07, 2020 3:04 pm    Post subject: Re: Weber window fans Reply with quote
Hah! I don't think anyone's ever accused me of being a "gentleman" before, but I'm the guy with the air ducts.
Pulling air from the engine compartment is an interesting concept, but I think the biggest problem you'll run into is competition from the cooling fan in the fan shroud, and the intake manifold(s) on the engine. Those louvers only allow so much air into the engine bay, after all.
I've even heard of large displacement engines running out of air at high RPM, just from the amount of air the intakes were sucking in.
Plus, there is the added problem of creating a vacuum at the back the car, which is bad for aerodynamic drag.
"It's time you started treating people as individuals, rather than mathematically predictable members of an aggregate set, regardless of how well that works."
modok
modok is offline
PostPosted: Mon Sep 07, 2020 3:28 pm    Post subject: Re: Weber window fans Reply with quote
Even on your water cooled car..... you will find the shrouding around the radiator is crucial to making it work right, and the fans are only useful at low speeds.
tattooed_pariah
PostPosted: Mon Sep 07, 2020 7:14 pm    Post subject: Re: Weber window fans Reply with quote
so maybe low cfm fans that only kick on when temps reach a certain degree? so if you are stuck in SoCal traffic and idling a lot not going anywhere they can help pull some hot air away..
either way, from all points brought up, it sounds like this is in fact a stupid idea..
VERY MUCH appreciated from everyone for not turning this into the same old argument.. Smile
-pariah
'72 Volksrod
tattooed_pariah
PostPosted: Mon Sep 07, 2020 7:15 pm    Post subject: Re: Weber window fans Reply with quote
yeah, hadn't really thought about the fight between carb intakes trying to get air and fans pulling air away, good point.
I haven't chimed in on your thread, but your work there is incredible looking and your follow up on measurements is awesome! thanks for doing what you did! Smile
-pariah
'72 Volksrod
vwracerdave
vwracerdave is offline
PostPosted: Mon Sep 07, 2020 8:13 pm    Post subject: Re: Weber window fans Reply with quote
pariah I'm not trying to be mean. I don't see it working. People have been modifying and hot rodding VW's for over 60 years now. I promise if your idea had any merit somebody a long time ago would have already made it work. Sorry just my common sense opinion.
tattooed_pariah
PostPosted: Mon Sep 07, 2020 8:42 pm    Post subject: Re: Weber window fans Reply with quote
no harm felt Smile
I was telling my wife, I always see weber windows, but have never seen this discussion, and i felt like i was gonna start a shit post.. but I'm glad it stayed objective and civil.
everyone is right, i don't think it will work, but for a second it seemed like a feasible decent idea..
-pariah
'72 Volksrod
Chickensoup
Chickensoup is offline
PostPosted: Mon Sep 07, 2020 8:49 pm    Post subject: Re: Weber window fans Reply with quote
1 time i thot i culd restore a vw chassis for under $200 Shocked now im nearing 2k Laughing
next cooling attempt,
a cooler full of dry ice with a hose running from the intake to the chest Rolling Eyes Rolling Eyes
'65 Tourist Delivery Build
'66 RIP
Floating VW
PostPosted: Tue Sep 08, 2020 8:27 am    Post subject: Re: Weber window fans Reply with quote
No problem!
Chickensoup wrote:
. . . next cooling attempt,
It's sounds crazy, but I've actually seen something very similar to this at the drag strip. Several people were doing it, as a matter of fact.
I've also seen more than one Ford coyote engine gain 100+ bhp just from adding a simple cold-air intake and tweaking the tune on the ECU. Now that's crazy!
tattooed_pariah
PostPosted: Tue Sep 08, 2020 1:38 pm    Post subject: Re: Weber window fans Reply with quote
I coulda sworn the Roadkill guys did an episode calling back to the drag guys that would cover their intakes in ice cubes to cool it.. and if i remember right (I might not..) when they tested on a dyno, it actually DID raise HP but not enough for it to be worth the effort.. Laughing
-pariah
'72 Volksrod
txoval
txoval is offline
PostPosted: Tue Sep 08, 2020 6:09 pm    Post subject: Re: Weber window fans Reply with quote
Yes, pretty common practice on V8 cars...bags of ice on the intake manifold
vwracerdave
PostPosted: Tue Sep 08, 2020 6:35 pm    Post subject: Re: Weber window fans Reply with quote
BS. The Ricers do it too at the track.
Chickensoup
PostPosted: Tue Sep 08, 2020 6:40 pm    Post subject: Re: Weber window fans Reply with quote
lol it was a joke guys
'66 RIP
earthquake
earthquake is offline
PostPosted: Wed Sep 09, 2020 9:45 am    Post subject: Re: Weber window fans Reply with quote
Has any body ever mounted a Vacuum gauge on their deck lid and and done a high speed pass to see if there is a vacuum in the engine compartment, you could route the gauge to the dash with a long tube or mount a GoPo on the deck lid to watch the gauge.
eQ
74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison]
vwracerdave
PostPosted: Wed Sep 09, 2020 9:50 am    Post subject: Re: Weber window fans Reply with quote
Yes it has been done. It is amazing how much negative pressure is in the engine compartment of a Bug with factory louvers and a big stroker dual carb engine.
Lingwendil
Lingwendil is offline
PostPosted: Wed Sep 09, 2020 10:11 am    Post subject: Re: Weber window fans Reply with quote
I'm thinking cutting some holes under the liscense plate may be a better idea.
I do have spare decklid to clean up Think
73 super beetle thread http://www.thesamba.com/vw/forum/viewtopic.php?t=649622 Back on the Road!
Modify your Kadrons for SVDA http://www.thesamba.com/vw/forum/viewtopic.php?p=8115884#8115884
Cast iron VJU4BR8 SVDA reference thread- https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0
Need replacement filters for original Kadron aircleaners? WIX #42087 is a perfect fit, as is Napa Gold #2087!
tattooed_pariah
PostPosted: Wed Sep 09, 2020 1:18 pm    Post subject: Re: Weber window fans Reply with quote
that's actually fairly common too, just saw a guy locally who found some louvers somewhere and cut holes for em..
I wasn't at the meet so I don't have any details, just saw the pic from the uploads..
-pariah
'72 Volksrod
Lingwendil
PostPosted: Wed Sep 09, 2020 1:29 pm    Post subject: Re: Weber window fans Reply with quote
I think those are dryer vents? Aluminum and easy to fit. I've used them as vents for aquarium stands and light fixtures.
I walk by them every time I'm at the local Ace hardware on my way to the fasteners and paint sections Smile
