UV-C Water Tank Sterilizer
Corwyn Premium Member
Corwyn is offline
PostPosted: Mon Oct 05, 2020 5:45 pm    Post subject: UV-C Water Tank Sterilizer Reply with quote
As if I had nothing better to do, I found this on AliBaba and plumbed it into my water tank. Bring on Giardia! Shocked
"Lumiwell UVC LED Module DC 12V sterilizer"
'90 White Westy ("White Lightning")
FAS Gen V 2.0
The Annual Baja Rally
~ Captain Ron ~
MarkWard
MarkWard is offline
PostPosted: Mon Oct 05, 2020 6:06 pm    Post subject: Re: UV-C Water Tank Sterilizer Reply with quote
How about a real world test for us? Maybe fill it from a river and see what happens. Thanks for sharing.
Corwyn is offline
PostPosted: Mon Oct 05, 2020 6:28 pm    Post subject: Re: UV-C Water Tank Sterilizer Reply with quote
Just downstream from the rotting deer carcass . . . Shocked
FAS Gen V 2.0
~ Captain Ron ~
alaskadan
alaskadan is offline
PostPosted: Mon Oct 05, 2020 7:27 pm    Post subject: Re: UV-C Water Tank Sterilizer Reply with quote
Ha! LOL, once when clam digging on Cook Inlet we forgot to grab the water bottle from the car. There was a small creek that ran down the beach. My wife was so thirsty she just had to take a drink. Walking further up the creek we found nasty half gone/rotten salmon carcasses. I LOLed back then too! She was ok.
I bought a Steripen for hiking, but never really used it much , as many of the bodies of water are glacial and murky making the pens use questionable. So how can you be sure? Get some pond water, test it to make sure it has plenty of swimmers. Then turn on the light.... I've had ghiardia or something like it once. Its bad. A buddy got it on a float hunt from drinking out of the river where the rest of us filtered our water. Boy did he pay for it, every 20 minutes or so Very Happy .
zimflux
zimflux is offline
PostPosted: Tue Oct 06, 2020 5:01 am    Post subject: Re: UV-C Water Tank Sterilizer Reply with quote
Unfortunately UVC is probably also breaking down your tank material now...
84 Westy w/ 2.1 MV
djkeev
djkeev is offline
PostPosted: Tue Oct 06, 2020 5:13 am    Post subject: Re: UV-C Water Tank Sterilizer Reply with quote
Yeah, back in the 70's I drank some water from a questionable source deep in the Kalmiopsis Wilderness on a backpacking trip.
Had to hike out up Sweaty Gulch sick as a dog!
It is something that I will NEVER forget. I never wish to feel like that again.
Ghia
Vanagon
Beetle
MarkWard
MarkWard is offline
PostPosted: Tue Oct 06, 2020 7:30 am    Post subject: Re: UV-C Water Tank Sterilizer Reply with quote
How about a link to the part?
vanis13
vanis13 is offline
PostPosted: Tue Oct 06, 2020 8:03 am    Post subject: Re: UV-C Water Tank Sterilizer Reply with quote
Corwyn wrote:
cool color effect. what is the black wire for?
Corwyn is offline
PostPosted: Tue Oct 06, 2020 8:47 am    Post subject: Re: UV-C Water Tank Sterilizer Reply with quote
The thick black wire bundle goes to the water level sensor. Alibaba now shows this item as "undeliverable to the USA" 😳, but the are alternatives on the site. A little more peace of mind . . .
FAS Gen V 2.0
~ Captain Ron ~
Corwyn is offline
PostPosted: Tue Oct 06, 2020 8:55 am    Post subject: Re: UV-C Water Tank Sterilizer Reply with quote
Here's a link to the specs:
https://www.solidrop.net/product/265nm-uv-led-lamp...lizer.html
FAS Gen V 2.0
~ Captain Ron ~
vanis13
vanis13 is offline
PostPosted: Tue Oct 06, 2020 9:01 am    Post subject: Re: UV-C Water Tank Sterilizer Reply with quote
Corwyn wrote:
The thick black wire bundle goes to the water level sensor. . . .
Interesting..h water level sensor is outside the tank on the side
Corwyn is offline
PostPosted: Tue Oct 06, 2020 9:11 am    Post subject: Re: UV-C Water Tank Sterilizer Reply with quote
Its wired from the galley light, so its only on for about 30 minutes in the evening. The tank is "milk-jug" plastic and almost as thick as a kayak. I'm not worried . . .
FAS Gen V 2.0
~ Captain Ron ~
Corwyn is offline
PostPosted: Tue Oct 06, 2020 9:13 am    Post subject: Re: UV-C Water Tank Sterilizer Reply with quote
I don't know what year van you have, but mine has a float on a rod inside the tank.
FAS Gen V 2.0
~ Captain Ron ~
vanis13
vanis13 is offline
PostPosted: Tue Oct 06, 2020 9:24 am    Post subject: Re: UV-C Water Tank Sterilizer Reply with quote
83.5 Westy...in signature. the float/rod idea is interesting. Am not familiar with your vintage. Thanks for the detail.
SyncroHead
SyncroHead is offline
PostPosted: Tue Oct 06, 2020 10:30 am    Post subject: Re: UV-C Water Tank Sterilizer Reply with quote
I find this a terrific idea!
I wonder if the intensity of this light is sufficient to be effective all the way to the bottom of the tank?
I wonder how long the light would need to be on to kill all the bacteria?
I think it's a valid concern about the UV deteriorating the plastic material, but depending on how often the light was on and the duration each time, it might take 5-10 years to be concerning or maybe 50 years.
Sounds like a great topic for a controlled science project. Anyone have a bacteria counting system?
Jim Davis
"A Vanagon? It's not a car or a van. It's a hobby!"
Check out:
www.VANAVATION.com
www.SyncroSafari.org and
www.Vanagons.org
sphet wrote:
I have *no* idea what the previous owner carried in his Westy... angry donkeys?
MarkWard
MarkWard is offline
PostPosted: Tue Oct 06, 2020 10:38 am    Post subject: Re: UV-C Water Tank Sterilizer Reply with quote
From the website. Unfortunately I only play a virologist on the internet.
UVC LED Testing 1.Turn on the UVC LED 2.Colon bacillus,The concentration of bacteria liquid is 3000cfu/mL, Pick 0.1mL bacteria(about 300pc bacteria)to a board. Use this UVC led, Shining 5min with distance 1cm,and then check. 3.Irradiated by a distance of 1 cm from the surface of the bacteria. 4.The shining time is 5 minutes. 5.Calculate the percentage of sterilization rate.
khughes
khughes is offline
PostPosted: Tue Oct 06, 2020 11:56 am    Post subject: Re: UV-C Water Tank Sterilizer Reply with quote
Well this really doesn't tell you anything about effectiveness, it's just a suggested method for measuring effectiveness. But, in the method the exposure is 5 minutes, so assuming you could get 100% reduction of E. Coli at 1 cm, just 5 inches away (12.7 cm) you'd need over 800 minutes exposure for the same effect (12.7 x 12.7 x 5min) due to the inverse square law - and that's not factoring in the absorption by the water. So even if the tank is only 10" deep, you'd need almost 54 Hours exposure at the bottom to equal 5 minutes at 1 cm.
I've tested a lot of UV disinfection/sterilization equipment, and my guess is this is virtually useless, but can't really tell without any actual output specifications.
'86 Westy FAS GenV Turbo (Marvin)
kourt
kourt is offline
PostPosted: Tue Oct 06, 2020 12:14 pm    Post subject: Re: UV-C Water Tank Sterilizer Reply with quote
The better way to do UV purification in the RV setting is to build an inline UV filter into the supply line from the tank to the sink. You set it to power on only when the pump is running.
There are a lot of good products that already do this. This site has a few, including a legitimate in-tank UV sanitizer.
https://ultraviolet.com/uv-water-purification/
I agree with the other poster who mentioned that UV light will degrade the plastic tank. It's better to build something into the sink supply line.
I thought of doing a project like this, but for now I'm just using a separate Pentek filter system that is switchable. Turn it off for washing dishes, turn it on for filling water bottles. This is very popular with my guests, and works well as long as you manage it properly. Photo below.
kourt
khughes
khughes is offline
PostPosted: Tue Oct 06, 2020 1:23 pm    Post subject: Re: UV-C Water Tank Sterilizer Reply with quote
kourt
Agreed on the UV systems quoted (e.g. they are looking at 30K uWs/cm2, likely >1000K times the energy of the LED). They are a tad pricey, but that's why.
As to a Pentech filter, I'd be cautious in what you expect it to do. To reduce or eliminate "typical" flora from a tank of potable water, great, you wouldn't want to rely on even a 5-micron filter to eliminate pathogens, especially Giardia and oocysts. And carbon filters are a food source for bacteria so their use has to be controlled if you don't want to create additional issues.
Corwyn is offline
PostPosted: Tue Oct 06, 2020 1:56 pm    Post subject: Re: UV-C Water Tank Sterilizer Reply with quote
Somebody had to get this conversation started. . . .😎
FAS Gen V 2.0
~ Captain Ron ~
