epowell Samba Member
Joined: September 23, 2015 Posts: 4733 Location: Czech (mostly) Vancouver (sometimes)
Posted: Sun Oct 11, 2020 6:00 pm Post subject: fixing starter solenoid cable (1,6 D NA) |
Hi Diesel Folks
I'm trying to get my Vancouver Diesel started, and think that I have isolated the problem.... Or at the very least, THIS is part of the problem and I don't know what to do about it.
The cable from the solenoid to the starter is toast. Any suggestions on what to do? I still seems to be well attached to the starter, but that cable came unattached to that "L" shaped connector piece which attaches it to the solenoid.
Thanks
Ed
_________________ www.edwardpowell.com |
Gnarlodious Samba Member
Joined: September 28, 2013 Posts: 2404 Location: Bonners Ferry Idaho
Posted: Sun Oct 11, 2020 7:55 pm Post subject: Re: fixing starter solenoid cable (1,6 D NA) |
Are you talking about the plastic covered female spade connector that fires the solenoid? Yeah that pops off if its not secured. I have a spring that applies tension and keeps it on. For me it has popped of at the most inopportune times and then you can’t crank.
Oh now I see what you mean, the braided copper cable into the motor. Did it break off? _________________ Vanagon ’83 diesel AAZ w/Giles injection, 5spd 4.57R&P+TBD and a '78 diesel Rabbit |
Posted: Sun Oct 11, 2020 8:06 pm Post subject: Re: fixing starter solenoid cable (1,6 D NA) |
Gnarlodious wrote: |
Oh now I see what you mean, the braided copper cable into the motor. Did it break off? |
Yeah... that one. It was just hanging by a thread, and when I went to remove it it broke off.... so I guess the only way to fix it is to remove the starter, and then solder that braded cable back to it's "L"-shaped connector... and bolt it back on?
Could be quite a trick to solder that big cable..... anyone have any tricks? _________________ www.edwardpowell.com |
Posted: Sun Oct 11, 2020 8:41 pm Post subject: Re: fixing starter solenoid cable (1,6 D NA) |
I hate to say it but it seems likely you will need a new starter sometime soon anyway. I recommend scrapping that big old thing and installing the new improved model SR28X starter featuring gear reduction. It will spin faster, pull less power and be easier on your flywheel. Plus, because it is smaller and lighter, it will be way easier to install and remove.
Chances are that copper braid is corroded away and I don’t know what it attaches onto but you could be wasting your time. Sure you could take it out and go to all the trouble but I wouldn’t bother with that old boat anchor. _________________ Vanagon ’83 diesel AAZ w/Giles injection, 5spd 4.57R&P+TBD and a '78 diesel Rabbit |
Posted: Sun Oct 11, 2020 11:21 pm Post subject: Re: fixing starter solenoid cable (1,6 D NA) |
I hear ya... Thanks for the recommendation (SR28X starter)... looking for one, but can't seem to locate here in Canada. Amazon out of stock.
The braded wire looks OK, but zooming in on the fotos looks like it is also starting to pull off slightly from it's connection to the motor... ...if I attempt a solder repair perhaps I will need to solder a little bit on that end too.
I am only here in Vancouver for another 10 days so there is no hurry to locate a new starter since I won't be back again until next year... HOWEVER, my goal right now is at least to START UP the van at least once while I am here. I have not started her up since last year, and seems not a good idea to leave it ANOTHER year without starting up.
So I will keep looking for a new starter, but also attempt a ghetto-fix on this one at least in the hopes of starting up the van.
I am aware that this is a HIGH VOLTAGE un-fused wire that must be heavily shielded against contact with anything else.
MarkWard Samba Member
Joined: February 09, 2005 Posts: 18699 Location: Retired South Florida
Posted: Mon Oct 12, 2020 8:46 am Post subject: Re: fixing starter solenoid cable (1,6 D NA) |
Looks like you could crimp a heavy duty eyelet on the solenoid end and reattach for now. Would be easier with the starter on the bench. |
Posted: Mon Oct 12, 2020 10:15 am Post subject: Re: fixing starter solenoid cable (1,6 D NA) |
MarkWard wrote: |
Thanks for the inspiration Mark... I think I'll give that a try. Part of the problem is that I don't have so many tools here in Vancouver --- I'll attempt to remove the starter with what I have here - and probably have to buy some more tools... _________________ www.edwardpowell.com |
old_man Samba Member
Joined: June 19, 2018 Posts: 1414 Location: Newfoundland
Posted: Mon Oct 12, 2020 1:23 pm Post subject: Re: fixing starter solenoid cable (1,6 D NA) |
Alternative idea: Buy a TDI adapter from T3Technique and then get a TDI starter from the junk yard. |
Posted: Mon Oct 12, 2020 2:49 pm Post subject: Re: fixing starter solenoid cable (1,6 D NA) |
...so as I said, I really wanted to get Toni running a bit before I head back to Europe.
So I managed to pull the starter and do the ghetto fix with some hardware things I found in my mom's basement here.... and.... it worked!!!!
I think this starter itself is still pretty OK, but that braided cable will not last so much longer... it is very compromised where it attaches to the motor. I would ultimately just like to completely REPLACE that braided cable > I wonder how that could be done.
T3messie Samba Member
Joined: October 03, 2017 Posts: 214 Location: Germany
Posted: Mon Oct 12, 2020 9:17 pm Post subject: Re: fixing starter solenoid cable (1,6 D NA) |
Well done Ed,
look for Bosch 1 004 336 621. I never had luck trying to solder that corroded cable.
The brushes may be replaced anyway. |
Posted: Tue Oct 13, 2020 12:25 am Post subject: Re: fixing starter solenoid cable (1,6 D NA) |
T3messie wrote: |
Well done Ed,
Thanks Max
I'm quite surprised myself that it works.... now sure for how long however. I'll definitely be on the look out for a new starter... but might also attempt to completely replace that corroded cable. Maybe it is possible to open it all up and replace the cable completely from the inside? _________________ www.edwardpowell.com |
Igeo Samba Member
Joined: September 25, 2018 Posts: 898 Location: Oakland, CA
Posted: Tue Oct 13, 2020 8:09 am Post subject: Re: fixing starter solenoid cable (1,6 D NA) |
It seems a bit of a weird design to have that uninsulated conductor exposed like that in the first place. _________________ 1987 Westfalia 2.1 WBX Manual |
Posted: Tue Oct 13, 2020 9:06 am Post subject: Re: fixing starter solenoid cable (1,6 D NA) |
Aha Max!
Great! ...sorry I didn't looke up Bosch 1 004 336 621... I was assuming this would be a complete starter.
But this bushing holder look like the most reliable and affordable way to cure this problem. Also it is something small and light enough I could take with handluggage with me from Europe next time.
Thanks for the tip! _________________ www.edwardpowell.com |
