Could it be something other than the rear main seal?
ddye
ddye is offline
PostPosted: Fri Nov 13, 2020 3:46 pm    Post subject: Could it be something other than the rear main seal? Reply with quote
OK, long story short. I just finished replacing the rear main seal on Nelly-kiki and it is still leaking.
I replaced:
- Rear main seal
- felt washer
- fly wheel
- fly wheel o-ring
- clutch
- pressure plate
- Thrust bearing
- Pilot bearing
- dipstick o-ring
- Everything torqued to spec
Made sure all surfaces were clean and undamaged prior to reinstallation. One exception. The shims were worn. However, I checked the end play with them in place and it was within spec so I went ahead and used them.
Is there any place else the oil could be coming from? I checked the oil cooler and it seems to be fine. The pictures, and my eyes, are telling me it is the rear main seal still leaking.
HELP!
1988 Westy
2.1 Boston Bob Rebuild
"Nelly"
DanHoug
DanHoug is offline
PostPosted: Fri Nov 13, 2020 4:21 pm    Post subject: Re: Could it be something other than the rear main seal? Reply with quote
on the engine case behind the flywheel are several oil galley plugs that are notorious for leaking. the permanent fix is remove them, tap the hole, and install a loctited threaded plug. on my rebuild, those plugs were not leaking but i cleaned them up and JB Welded over them. not sure if that does anything other than make me feel better. the smallest oil leak would provide 50 psi oil pressure against a roughly 1" diameter plug which is a fair bit of hydraulic pressure.
you mentioned you replaced the flywheel... was it a reconditioned one, new, good used, etc? i've found the flywheel seal surface to be quite finicky in terms of not leaking. some have gotten away with chucking the FW up in a lathe or drill and sanding down the grooves. i like the Speedi-Sleeve repair myself as it actually slightly INCREASES seal tension.
what brand seal did you install? Sabo seems to be the consensus of the best available and comparing the Victor/Elring seal supplied in gasket kits to the Sabo, it is certainly more robust.
one Samba poster found he had oil leaks through the FW bolts themselves as reportedly the bolt holes enter an area with oil splash or pressure. he'd taken to using loctite on the threads to seal oil seepage. your drip looks more substantial than what could seem to seep thru.
consider your blowby too. had an '85 with an auto and hence flex plate but couldn't get that bugger to stop dripping despite new seal and flexplate. too much crankcase pressure was forcing the oil out.
-dan
www.thefixitworkshop.com
Wildthings
Wildthings is offline
PostPosted: Fri Nov 13, 2020 5:20 pm    Post subject: Re: Could it be something other than the rear main seal? Reply with quote
You did remove the old flywheel o-ring before installing the new one didn't you?
I don't think it is possible for oil to leak around the bolt threads. I think that would require a cracked crankshaft for that to happen.
I would certainly be looking at the oil galley plugs as I have lost two of them on Type 4 engines.
Type 1 engines were known for cracking and thus leaking oil in weird places, but I haven't heard of this on a WBXer engine.
Is it just a lighting trick or do you actually have a gap between the engine and bellhousing?
halfassleatherworks
PostPosted: Fri Nov 13, 2020 5:31 pm    Post subject: Re: Could it be something other than the rear main seal? Reply with quote
maybe the cam plug. it does happen.
DanHoug
DanHoug is offline
PostPosted: Fri Nov 13, 2020 5:33 pm    Post subject: Re: Could it be something other than the rear main seal? Reply with quote
Waldo? is a pretty sharp guy.. here's one reference. i have no first hand knowledge of this other than i blue loctited my bolts <grin>. bottom post on page.
https://www.thesamba.com/vw/forum/viewtopic.php?p=9048517#9048517
-dan
ddye
ddye is offline
PostPosted: Fri Nov 13, 2020 6:05 pm    Post subject: Re: Could it be something other than the rear main seal? Reply with quote
OK, to answer a couple questions from above and ask another while adding more information. Smile
The gasket I used was the Sabo
New flywheel from GoWesty
Yes, I removed the old flywheel o-ring when I trashed the old flywheel Smile
I think I have a couple things going on. First, when I removed the transmission and looked through the pressure plate hole, I noticed that the metal washer that holds the little felt washer in place had dislodged itself and I can't see the felt washer. Note: once I get the pressure plate and clutch off I find the felt washer just sort of floating around in the clutch area.
Question: the felt washer looks kinda shot. How necessary is this little guy? And, is that the direction the metal washer should be facing? (see pic below).
Now that I have the pressure plate and flywheel off, I see that the rear seal is leaking badly. I really thought I had put it in correctly but if you look at the pictures below, it seems like there is space between the shims and the rear seal. I can stick my finger in there.
Questions: as you can see, I countersunk the rear seal, as Boston Bob says to do. Did I not sink it enough? If I have not counter sunk it enough, can I just sink this one further in or do I need to replace it? (I have another Sabo that I bought in case I messed this up).
Wait, now that I looked at the pics closely, I see what you guys are talking about with the plug leaking. I just ran outside and cleaned off the black plug in the pic above and sure and this thing is dripping, it is dripping from the middle of the black plug!!! Wooppii!
Note: I could have just posted the last sentence but I spent so long on the post, I wanted to post it. Maybe the next human will learn from it.
Smile
Thanks everyone for the help!
1988 Westy
"Nelly"
Wildthings
PostPosted: Fri Nov 13, 2020 6:19 pm    Post subject: Re: Could it be something other than the rear main seal? Reply with quote
There is supposed to be a space between the shims and the seal. You drive the seal in until it bottoms against a shoulder in the bore, that's it, you can't drive it any further. It is hard to look at a seal and tell if it has been leaking out not, especially just looking at pictures. I like to use a dab of sealant at the case parting line before installing the seal, as that is the most likely place for the seal to leak on its exterior.
Where are you finding oil within the bellhousing? Oil leaking from the sealing surface would travel down the back of the flywheel from centrifugal force, while oil leaking from elsewhere would likely just run down the face of the crankcase. Check that none of the galley plugs look to have been pushed out at all.
Wildthings
PostPosted: Fri Nov 13, 2020 6:24 pm    Post subject: Re: Could it be something other than the rear main seal? Reply with quote
That situation does not apply to a WBXer, as I said you would have to have a cracked crankshaft for WBXer to leak there.
halfassleatherworks
PostPosted: Fri Nov 13, 2020 6:25 pm    Post subject: Re: Could it be something other than the rear main seal? Reply with quote
if you are referring to the cam plug. your Wooppii just turned to O shit I have to split the case
ddye
ddye is offline
PostPosted: Fri Nov 13, 2020 6:33 pm    Post subject: Re: Could it be something other than the rear main seal? Reply with quote
I thought I posted this pic. But yea, I hope you are wrong. Are you? It is that black plug towards the bottom. The one with all the oil LOL
1988 Westy
"Nelly"
halfassleatherworks
PostPosted: Fri Nov 13, 2020 6:38 pm    Post subject: Re: Could it be something other than the rear main seal? Reply with quote
I am not joking. the cam plug is leaking. that means at least a tear down and reseal of the case " better know as a Overhaul "
unless someone has a expansion plug that will fit.
Wildthings
PostPosted: Fri Nov 13, 2020 6:51 pm    Post subject: Re: Could it be something other than the rear main seal? Reply with quote
How about supporting the case so the cam plug is pointing to the ceiling and then spraying the heck out of the plug with brake cleaner. Then use some low viscosity sealant that will wick into any gaps and seal them up.
halfassleatherworks
PostPosted: Fri Nov 13, 2020 6:55 pm    Post subject: Re: Could it be something other than the rear main seal? Reply with quote
that may work for a while but it is under oil pressure from the cam.
Wildthings
PostPosted: Fri Nov 13, 2020 7:10 pm    Post subject: Re: Could it be something other than the rear main seal? Reply with quote
There is a drain to the sump, so the pressure is only slightly above case pressure, you can see the drain in this photo.
Zeitgeist 13
Zeitgeist 13 is offline
PostPosted: Fri Nov 13, 2020 7:15 pm    Post subject: Re: Could it be something other than the rear main seal? Reply with quote
Machine a steel plate with five or six perimeter holes, and then carefully drill and tap the shoulder around the plug with the same schedule as the plate. Fashion a gasket and Reinzosil, screw in the bevel head screws and then feel like a smug genius who cheated fate.
Casey--
'01 Weekender --> full camper
y u rune klassik?
AndyBees
AndyBees is offline
PostPosted: Fri Nov 13, 2020 7:25 pm    Post subject: Re: Could it be something other than the rear main seal? Reply with quote
WildThings, you beat me to it .. so, I deleted my post.
Yep, virtually zero oil pressure at the end of the Cam.
'84 Vanagon Tin-top, ALH TDI, two trips to Alaska, 2014 & 16. 1989 Tin-top unmolested.
1983 Air-cool, 225k miles, 180k miles mine, seven trips to Alaska from 1986 thru 2003. 1975 Bay hopeful.
halfassleatherworks
PostPosted: Fri Nov 13, 2020 7:35 pm    Post subject: Re: Could it be something other than the rear main seal? Reply with quote
Ok I stand corrected, not full oil pressure, but flow / spray pressure from the cam bearing. there are always ways to temporary fix it. but to do it right, there can only be 1.
ddye
ddye is offline
PostPosted: Fri Nov 13, 2020 7:52 pm    Post subject: Re: Could it be something other than the rear main seal? Reply with quote
I don't know if I'll do it but I can sure appreciate the effort it took to think of it!
Very Happy
1988 Westy
"Nelly"
ddye
ddye is offline
PostPosted: Fri Nov 13, 2020 7:55 pm    Post subject: Re: Could it be something other than the rear main seal? Reply with quote
I can appreciate this for sure. I am normally a do it right the first time sorta person. This is definitely opening my eyes. I got some serious research and thinking to do.
1988 Westy
"Nelly"
borninabus Premium Member
Samba R&D Dept.
borninabus is offline
PostPosted: Fri Nov 13, 2020 8:33 pm    Post subject: Re: Could it be something other than the rear main seal? Reply with quote
that doesn't look like engine oil from here.
is your van an automatic?
the bellhousing looks like it is.
you say you replaced the thrust bearing. meaning you split the case and replaced the #1 crankshaft bearing? or you replaced the "big" thrust washer?
i went through this recently on my 88 auto.
it leaked quite a bit of ATF upon initial start up and has settled down to a minuscule drip since then.
88 Van WBX, A/T - 13 JSW TDI 6M/T - 2012 Touareg TDI Sport
