Norma Samba Member
Joined: September 26, 2020 Posts: 217 Location: Nor Cal
Posted: Sat Sep 26, 2020 11:15 am Post subject: EGR rod. Ideas |
Okay, I know I need all around tune up. I will get on that now.
See how it goes.
My Question, why will it run when I have the rod fastened and not without it?
My injected 2.0 Will not fully start. It fires and then puffs out.
I looked around and found the codder pin gone and the plastic sleeve broken, old age. I had no luck so fashion a new one from an interior door clip, it worked and I drove her a couple of miles and realized my sleeve wasn’t good enough.
But she truly ran.
I spoke to a pro yesterday and he said. I am wondering what the opinion is from anyone out there.
Thank you for your time.
wThat is for your EGR Valve (Exhaust Gas Recirculation) which is part of your Smog system, under certain conditions it will open to bring a small amount of exhaust into the intake rather than outside air. That “Rod” connects between the Throttle Body and the EGR This is unlikely to be the cause of your issue?
tommu  Samba Member
Posted: Sat Sep 26, 2020 11:59 am Post subject: Re: EGR rod. Ideas |
An operational valve is not required for your engine to run. Unless you are trying to pass smog, you can leave it disconnected and continue troubleshooting. _________________
SGKent  Samba Member
Joined: October 30, 2007 Posts: 42740 Location: at the beach
Posted: Sat Sep 26, 2020 12:03 pm Post subject: Re: EGR rod. Ideas |
Quote: |
My injected 2.0 Will not fully start. It fires and then puffs out. |
I don't understand your problem. If the rod is disconnected then the EGR doesn't affect your engine unless it is leaking gasses or has a bad diaphragm. If your bus suddenly started dying it is unlikely to be the EGR. You have some troubleshooting ahead.
What part of NorCal are you in? _________________ "Most people don't know what they're doing, and a lot of them are really good at it." - George Carlin |
Norma Samba Member
Posted: Sat Oct 17, 2020 5:57 pm Post subject: Re: EGR rod. Ideas |
Lake county.
What part of NorCal are you in?[/quote] |
SGKent  Samba Member
Posted: Sat Oct 17, 2020 6:07 pm Post subject: Re: EGR rod. Ideas |
A good Ace Hardware will have a selection if they have a hardware room. They are called R Cotter Pins, R-Clip, or R-Clip Springs. https://en.wikipedia.org/wiki/R-clip . Your egr not opening will not cause the bus to die. A leaking one might whether it is connected or not. Most likely you need to look for a vacuum leak or ignition problem.
example:
Norma Samba Member
Posted: Thu Nov 12, 2020 3:16 pm Post subject: Re: EGR rod. Ideas |
Well I finally got around to working on my tune-up.
I found a wire broken.
I think it goes to the temp regulator/fuel thingy.
Charging now.
Fingers crossed! |
Abscate  Samba Member
Joined: October 05, 2014 Posts: 24024 Location: NYC/Upstate/ROW
Posted: Thu Nov 12, 2020 4:12 pm Post subject: Re: EGR rod. Ideas |
SGKent wrote: |
example:
No wonder I couldn’t find them, I was looking in the fish section. I did find a zhalibut though. Where to leave it? _________________ 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🍊 🍊 🍊 |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 13524 Location: West Coast, USA
Posted: Thu Nov 12, 2020 4:18 pm Post subject: Re: EGR rod. Ideas |
The EGR valve has a rubber diaphragm inside it. If it’s ripped, it leaks air (vacuum) and can stall the engine. With the rod connected/disconnected, the internal rubber diaphragm moves slightly and the air leak changes size. Remove the valve, make a block off plate for the plenum, and run it. If it runs well, welcome to the crew of folks waiting for solutions on EGR valves.
Robbie _________________ One-on-one tech help for your vintage Volkswagen:
www.airschooled.com
https://www.patreon.com/airschooled |
Norma Samba Member
Posted: Thu Nov 12, 2020 4:29 pm Post subject: Re: EGR rod. Ideas |
Gotcha!
Thank you. |
Norma Samba Member
Posted: Sat Nov 14, 2020 8:00 pm Post subject: Re: EGR rod. Ideas |
They do sell them for it, right? |
Posted: Sat Nov 14, 2020 8:28 pm Post subject: Re: EGR rod. Ideas |
Norma wrote: |
It’s 2020, you’re going to have to define your pronouns.
Robbie
He/Him _________________ One-on-one tech help for your vintage Volkswagen:
www.airschooled.com
SGKent  Samba Member
Posted: Sat Nov 14, 2020 9:07 pm Post subject: Re: EGR rod. Ideas |
Norma wrote: |
what is "it?" If it is the diaphragm, no. _________________ "Most people don't know what they're doing, and a lot of them are really good at it." - George Carlin |
Norma Samba Member
Posted: Sat Nov 14, 2020 9:16 pm Post subject: Re: EGR rod. Ideas |
Bloody Hell, are the EGR valves still available for purchase from a parts monger? |
Posted: Sat Nov 14, 2020 9:19 pm Post subject: Re: EGR rod. Ideas |
Interstate VW parts in Lake Elsinore sells rebuilt valves. They do not disclose what goes into the valves, rightfully so as they are devilishly hard to replicate and rebuild. Try at your own risk, or make your own out of sheet silicone, and replace it every thousand miles.
www.airschooled.com
SGKent  Samba Member
Posted: Sat Nov 14, 2020 9:54 pm Post subject: Re: EGR rod. Ideas |
Norma wrote: |
used valves if you can find a good one. Interstate in SoCal sells "rebuilt" ones, whatever that means. They want about $300 for them. The rods come up for sale too sometimes. Have to watch for the parts. It has been NLA since about 1990. I have never seen a new one, come close to low mile ones a couple times. _________________ "Most people don't know what they're doing, and a lot of them are really good at it." - George Carlin |
Posted: Sat Nov 14, 2020 11:57 pm Post subject: Re: EGR rod. Ideas |
If just hooking up the rod causes your engine to die, I suspect that something is bent or not positioned correctly. |
Norma Samba Member
Posted: Sun Nov 15, 2020 4:32 pm Post subject: Re: EGR rod. Ideas |
It doesn’t die with the rod hooked up.
Actually the opposite, it starts and runs. |
SGKent  Samba Member
Posted: Sun Nov 15, 2020 9:57 pm Post subject: Re: EGR rod. Ideas |
Norma wrote: |
so the valve has two sides to it. One side is closed at idle and the other at wide open throttle. There is a small spring in the valve that closes the one side at idle. The diaphragm prevents air from seeping into the valve and getting in as a vacuum leak. If the bus will start with the valve hooked up, then most likely the mixture is whacked from the prior owner trying to compensate for leakage at the EGR. I'd block it off with a plate, and try to start the bus after that. Who knows what the PO did to accommodate mixture problems. _________________ "Most people don't know what they're doing, and a lot of them are really good at it." - George Carlin |
Norma Samba Member
Posted: Mon Nov 16, 2020 8:40 am Post subject: Re: EGR rod. Ideas |
Yes, the spring is loose now.
I don’t know how to stabilize it.
What can I use. |
Norma Samba Member
Posted: Mon Nov 16, 2020 8:41 am Post subject: Re: EGR rod. Ideas |
The spring on the rod is loose. I haven’t opened the valve yet. |
