T4 #4 piston
grvwsic
grvwsic is offline
PostPosted: Wed Nov 25, 2020 4:41 pm    Post subject: T4 #4 piston Reply with quote
Is there a trick on removing the #4 piston on a 1.7 Type 4?
I can't seem to get the right angle to push the pin out. Now it's stuck.
My first T4 to rebuild. It's been sitting waiting for me to do something.
Any advice is appreciated. Thanks
APPLEGREENVW
APPLEGREENVW is offline
PostPosted: Wed Nov 25, 2020 5:35 pm    Post subject: Re: T4 #4 piston Reply with quote
Look up youtube.
Parts for sale https://www.thesamba.com/vw/classifieds/search.php?username=APPLEGREENVW
02/76 Beetle sedan
View user's profile Send private message Send e-mail YouTube Gallery Classifieds Feedback
oprn
oprn is offline
PostPosted: Wed Nov 25, 2020 5:40 pm    Post subject: Re: T4 #4 piston Reply with quote
Just unbolt the rod and take it off on the bench.
busdaddy
busdaddy is offline
PostPosted: Wed Nov 25, 2020 5:48 pm    Post subject: Re: T4 #4 piston Reply with quote
Heat the piston up with a propane torch, the pin will be much more co operative Wink
Слава Україні!
grvwsic
grvwsic is offline
PostPosted: Wed Nov 25, 2020 6:18 pm    Post subject: Re: T4 #4 piston Reply with quote
Thanks all! Just not thinking clearly. My brain turned into noodles.
I will follow your suggestions.
Thanks again.
oprn
oprn is offline
PostPosted: Thu Nov 26, 2020 7:49 am    Post subject: Re: T4 #4 piston Reply with quote
My current machinist claims VW piston pins are way too tight. Says they should be a thumb press fit at room temp in the pistons. He could be right as in all the years I have been playing with these engines I have never seen them loose enough to slide out on thier own. You always have to hammer them out even on high mileage engines. The small end of the rods is another story though. This tells me that with the pins so tight in the pistons the pins are not rotating properly in the pistons.
It could also be an indication that these engines are not running at thier design temperature what with every man and his dog throwing away the thermostats.
GARRICK.CLARK
GARRICK.CLARK is offline
PostPosted: Thu Nov 26, 2020 8:24 am    Post subject: Re: T4 #4 piston Reply with quote
Take rod off.
Then if your saving the piston. Put rod in a fixture. Heat up both sides of piston were the clips fit and lightly tap the gudgeon pin. Try tapping the pin from both sides, often the pin moves easier from left to right OR right to left.
orwell84
orwell84 is offline
PostPosted: Thu Nov 26, 2020 3:04 pm    Post subject: Re: T4 #4 piston Reply with quote
Pins never seem to just push out for me when I am taking apart a used engine. They always seem to require a light tapping. When everything is all clean again they seem to fit correctly again.
busdaddy
busdaddy is offline
PostPosted: Thu Nov 26, 2020 3:24 pm    Post subject: Re: T4 #4 piston Reply with quote
Used engines build up a narrow ring of scum on the pin each side of the rod, that's usually what makes it bind coming out. Carb cleaner helps, but heating the piston always solves the problem.
Слава Україні!
oprn
oprn is offline
PostPosted: Thu Nov 26, 2020 6:49 pm    Post subject: Re: T4 #4 piston Reply with quote
Pin bosses on the piston never seem to show any wear but the small ends of the rods sure do! When you get new rods they are always a thumb press fit but new pistons have to be tapped in or heated.
According to him that is wrong. I can tell you it was a treat to assemble the engine after he fitted the pins properly! He goes for a 1/4 to 1/2 thou clearance, tells me they come as an interference fit out of the box.
modok
modok is offline
PostPosted: Fri Nov 27, 2020 1:55 am    Post subject: Re: T4 #4 piston Reply with quote
in order to get the pins out you usually have to cut the burr off the edge of the c-clip groove, then heat up the piston. The pin should then slide right out.
True of most pistons like this, in many kinds of engine.
tho if the pistons are not good enough to re-use, then.....i would not bother with that, just get it apart quick and dirty whichever way you want short of bending the rods in the process, unless the rods are junk too..... ok just get a hammer Shocked
grvwsic
grvwsic is offline
PostPosted: Fri Nov 27, 2020 12:32 pm    Post subject: Re: T4 #4 piston Reply with quote
The pin was sprayed with Liquid Wrench and left overnight.
I couldn't remove the rod but was able to move it a bit 1/4 "
Worked on it this morning and got an angle. It tapped out with a little persuasion.
Finally!.
Thanks all and stay safe.
GARRICK.CLARK
PostPosted: Fri Nov 27, 2020 1:10 pm    Post subject: Re: T4 #4 piston Reply with quote
It's had a heavy blow by problem that engine. Are you going to get a 1911 piston kit for it
grvwsic
grvwsic is offline
PostPosted: Fri Nov 27, 2020 1:39 pm    Post subject: Re: T4 #4 piston Reply with quote
Was planning to get the heads redone, get the seats replaced also buy a 96mm big bore. But I'll see what I could do so that it will be ready for the spring season
GARRICK.CLARK
PostPosted: Fri Nov 27, 2020 1:48 pm    Post subject: Re: T4 #4 piston Reply with quote
Have you looked at the cam lobe's yet. Try get a close up shot of the lobe's through the cylinder spigots. Ta
grvwsic
grvwsic is offline
PostPosted: Fri Nov 27, 2020 2:14 pm    Post subject: Re: T4 #4 piston Reply with quote
I m planning to split the case sometime next week,
but here are shots of two of the cam lobes. not too clear
intake 2/4
exhaust 1/3
GARRICK.CLARK
PostPosted: Fri Nov 27, 2020 2:24 pm    Post subject: Re: T4 #4 piston Reply with quote
Yeah it's got a groove in the middle hasn't it.
European Motor works have some good type 4 parts.
grvwsic
grvwsic is offline
PostPosted: Fri Nov 27, 2020 2:46 pm    Post subject: Re: T4 #4 piston Reply with quote
Thanks for the heads up. Now I know what to look for when I go shopping for parts. And won't be a surprise.
GARRICK.CLARK
PostPosted: Fri Nov 27, 2020 3:01 pm    Post subject: Re: T4 #4 piston Reply with quote
Always fit new exhaust valves.
When it's back running Wright down the milage for ref purposes.
Exhaust valve's don't last as long as a type 4 bottom end can.
Johnston lifters are compatible with scat type 4 cams.
raygreenwood
raygreenwood is offline
PostPosted: Fri Nov 27, 2020 3:39 pm    Post subject: Re: T4 #4 piston Reply with quote
Please do not do that.
Its been a long time since Johnson lifters were "automatically" compatible with type 4 cams. They went out of business back in 2003-2004. They were down for two years and came back under ownership of Topline.
Their lifters were NOT the same....and its really hard to say because right around this same time....the available oils became....probably a lot more "not the same"...than even Johnson lifters.
For quite some time Webcam and Scat...ahd been having all of their lifters made by Johnson...and I will say they were excellent. No issues.
But since about 2005-2006....Web cam and Scat (pretty much made on the same blanks)...have been VERY specific about lifters...because they can only guarantee what they can "guarantee".
In fact...last year I asked webcam if they could regrind my 1996-ish Web #73...which ran 89k miles on then supplied Johnson lifters...and both look superb....but I mixed the lifters up by accident so cannot really use them.....so asked if they could regrind and re-harden and supply new lifters.
They said yes...they can regrind and reharden....but no...they cannot supply new lifters that they can guarantee....at all.....because the metallurgy is that different now.
Ray
