1/4 Mile Results with Mild Stroker
Page: Previous  1, 2, 3, 4, 5, 6, 7, 8
GARRICK.CLARK
GARRICK.CLARK is offline
PostPosted: Tue Dec 01, 2020 9:24 am    Post subject: Re: 1/4 Mile Results with Mild Stroker Reply with quote
Gkeeton. Doing a 2007 for a customer. Tuning it is impossible without the AFR gauge as you have said. He's dropped a PLX off so looks like I've got that to fit before I jet it.
chrisflstf
chrisflstf is offline
PostPosted: Tue Dec 01, 2020 10:14 am    Post subject: Re: 1/4 Mile Results with Mild Stroker Reply with quote
Congrats jeff on the baby. I appreciate all your common sense approach to issues. Keep it up
[email protected]
gkeeton@zbzoom.net is offline
I wouldn’t say it’s impossible. You may not get the most efficient/productive use out of the engine without one though. It also decreases the time involved when you know what direction to go, or give you valuable data when trying to solve/troubleshoot an issue.
I need to get one. When I upgraded the fuel system in the 67 I now have, it pulled exponentially harder past 5k than it did before, and I dropped at least a jet size on the mains/idles. The car drove fine below 4k before, and we would have never really found the issue if it wasn’t taken to the track.
GARRICK.CLARK
PostPosted: Tue Dec 01, 2020 10:30 am    Post subject: Re: 1/4 Mile Results with Mild Stroker Reply with quote
If I hadn't got an AFR gauge on my turbo motor it would have been impossible. My motors a nightmare to tune. Bizarrely it only likes 1 combo of jets. It's 1 of those motors that really needs injection but it's finding the time to do it. Plus it's means spending more of me hard earned cash on it which I don't want to do.
74 Thing
74 Thing is offline
PostPosted: Tue Dec 01, 2020 10:47 am    Post subject: Re: 1/4 Mile Results with Mild Stroker Reply with quote
Congrats to Jeff and his family! I hope all of you are doing well.
For the leaning out in the upper rpm range problem it seems you have addressed the pump and fuel line size issues.
Are there any restrictions in the tank such as the small fitting on the outlet or possible filter/screen inside?
There was a comment about venting the tank to a proper size so there would be no restrictions in flow in the upper rpms. That is something to look at and should be able to test easily by loosening or removing the gas cap temporarily.
Is it possible there is something going on with the floats (sticking or a float adjustment necessary that got out of wack) or float bowls or restrictions on the carb inlets or larger needle/seats needed?
You are running 38 venturis and I am assuming your jetting is close with the exception of something happening in the upper rpms. There was a suggestion about changing emulsion tubes. This may be something to look closely at as well since some will enable richer mixtures in the upper rpm range. Some info is here on the effect of different emulsion tubes http://www.turbosport.co.uk/showthread.php?t=169101 http://www.timsroadster.com/html/tuning_webers.html
Per David Vizard, "Hold the tube upside down (main jet up).
The top of the emulsion tube now represents the top of the rpm range and the bottom end the bottom of the rpm range.
Where there are holes the mixture will be leaner.
Where there are no holes it will be richer.
You should be able to home in on the right tube now really quickly."
Just trying to throw some things out there to think about and consider to get this resolved and running even better.
HotStreetVw
HotStreetVw is offline
PostPosted: Tue Dec 01, 2020 1:06 pm    Post subject: Re: 1/4 Mile Results with Mild Stroker Reply with quote
Congrats on the baby Jeff.
What idle jets are you running? 3rd progression hole?
4inBhore
50 Split - 2724cc NA. Haltech injected
62 Notchback - 2542cc Turbo WIP
Erik G
Erik G is offline
PostPosted: Tue Dec 01, 2020 1:10 pm    Post subject: Re: 1/4 Mile Results with Mild Stroker Reply with quote
congrats on the little girl, and good fitting name! Can't tell for sure but that video coming home from the track looks like winding way by my folks house. I've seen and heard a lot of VW's at Sac Raceway over the last 25 years, and yours has that sound that makes me know it's gonna be a nice pass. I'll be sad if it does indeed close
jpaull
jpaull is offline
PostPosted: Wed Dec 02, 2020 9:40 pm    Post subject: Re: 1/4 Mile Results with Mild Stroker Reply with quote
Thank you Big Jack, Lingwindil, Chickensoup, C77owen, Chrisflstf, 74thing and Hotstreet, It was a great day!
74thing, thanks for all the info, After I will consider some different emulsion tubes. I need less holes at the top or smaller air jet.
Hotstreet, I did try out some ida's before, but I went back to idf's, as I really wanted to go as fast as i could with non race stuff. I know the ida's work great, but i just wanted to see how fast i can go with idf's. The ida's that i tried out but not ever at the track do have the third progression hole.
Erik G, Thanks! And yes you got that right, that part of the video is on winding way east of Sunrise blvd and west of Hazel. I'm glad you recognize the sound too, Part of that is having as much compression as the gas will take,a ignition that will burn anything, and having the carbs synched perfect.
Page 8 of 8
