Block off for 36hp
Sharp64
Sharp64 is offline
PostPosted: Fri Dec 25, 2020 4:06 pm    Post subject: Block off for 36hp Reply with quote
I am running a WW “okrasa” kit in my 60. PO installed an electric fuel pump and regulator and just used the stock pump as a pass through. I’m getting a leak or “weeping” somewhere and want to just get rid of the stock fuel pump altogether and run SS lines hidden behind the shroud. Does anyone make a billet or plain steel block off plate? Haven’t compared but is the footprint similar or the same to the one for 40hp and later?
1960 Indigo Blue Ragtop (Blue Barry)
1967 Ghia
1985 Westy Money Pit
“...some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn.” - Michael Caine
Chickensoup
Chickensoup is offline
PostPosted: Sat Dec 26, 2020 8:30 pm    Post subject: Re: Block off for 36hp Reply with quote
someome with a vertical mill will make you one in mili seconds. or you could make one. i dont think it gets much easier than that Wink
'65 Tourist Delivery Build
'66 RIP
Tom_Kathleen
Tom_Kathleen is offline
PostPosted: Sun Dec 27, 2020 5:49 am    Post subject: Re: Block off for 36hp Reply with quote
Send me the fuel pump so I can see the shape and thickness of the block off and I can make you one. PM me about material and cost. Here are pictures of a fancy one I make for a 356 Porsche. Tom
Manxter #16, 1968 Meyers Manx & Kick-Out SS #16 (WIP)
Manx Club & CVA
Sharp64
Sharp64 is offline
PostPosted: Sun Dec 27, 2020 8:14 am    Post subject: Re: Block off for 36hp Reply with quote
Tom_Kathleen wrote:
Send me the fuel pump so I can see the shape and thickness of the block off and I can make you one. PM me about material and cost. Tom
Thank you for the offer. I can get one made along with some other items that I have cut, but was trying to see if any company was producing them and had them “on the shelf”. Wonder if there would be a market for such a thing?
1967 Ghia
esde
esde is offline
PostPosted: Sun Dec 27, 2020 9:14 am    Post subject: Re: Block off for 36hp Reply with quote
If you have a gasket, you have the template. All you need is a chunk of 3/16-1/4" aluminum.
IMO, most of the 36hp market is geared towards keeping things sorta stock, or using period correct upgrades. No doubt you would sell a few, but I doubt it'd be a hot item.
modok wrote:
Sharp64
Sharp64 is offline
PostPosted: Sun Dec 27, 2020 9:26 am    Post subject: Re: Block off for 36hp Reply with quote
Maybe I’ll start a new trend. Retro custom sort of thing. Which is what I’m going for with mine. Going to block off the fuel pump. Bend up some SS lines for behind the shroud and Powdercoat, paint and anodize some items.
1967 Ghia
Tom_Kathleen
PostPosted: Sun Dec 27, 2020 9:41 am    Post subject: Re: Block off for 36hp Reply with quote
The reason I asked for the 36HP fuel pump was that I would need to know the thickness of the block off so the original studs could be used. This way the engine could go back to stock easily. That is why my sample Porsche 356 block off is so thick. Tom
Manx Club & CVA
Sharp64
Sharp64 is offline
PostPosted: Sun Dec 27, 2020 11:08 am    Post subject: Re: Block off for 36hp Reply with quote
I’ll take a measurement shortly and advise.
1967 Ghia
