starting rpm?
BFB
BFB is offline
PostPosted: Tue Jan 12, 2021 11:01 am    Post subject: starting rpm? Reply with quote
what do yall figure is a starting rpm for vw engine? not idle rpm but at what rpm the engine will fire up
Most experts aren't.
chrisflstf
chrisflstf is offline
PostPosted: Tue Jan 12, 2021 11:04 am    Post subject: Re: starting rpm? Reply with quote
You mean cranking rpm. Pull the coil wire and measure it
buguy
buguy is offline
PostPosted: Tue Jan 12, 2021 11:15 am    Post subject: Re: starting rpm? Reply with quote
I don't remember exactly but i think mine is in the 250rpm range.
oprn
oprn is offline
PostPosted: Tue Jan 12, 2021 12:37 pm    Post subject: Re: starting rpm? Reply with quote
It can be a fairly wide range if your ignition and fuel system is good. In my country cranking speed is totally weather dependent. I have also had one start accidently while cranking it over with a ratchet setting the valve lash. What RPM would that be?
BFB
BFB is offline
PostPosted: Tue Jan 12, 2021 1:03 pm    Post subject: Re: starting rpm? Reply with quote
no, not really. that would be related to starter's rpm. im wondering at what rpm the engine might actually pop of and start running on its own.
oprn... start accidently while cranking it over with a ratchet setting the valve lash. What RPM would that be?
thats awesome! and scary as hell, im sure
bugu.. i think mine is in the 250rpm range.
if oprn had his pop of by hand then 250 wouldnt be unreasonable. and on that note, if you push start a vw they seem to fire at a pretty low rpm, at least when i have
UK Luke 72
UK Luke 72 is offline
PostPosted: Tue Jan 12, 2021 1:22 pm    Post subject: Re: starting rpm? Reply with quote
My 2276 wouldn't start below 200 rpm, that was likely a crank trigger issue though.
2276 Beetle build https://www.thesamba.com/vw/forum/viewtopic.php?t=670744&highlight=2276+beetle+daily
2276 EFI Conversion https://www.thesamba.com/vw/forum/viewtopic.php?t=689172
HotStreetVw
HotStreetVw is offline
PostPosted: Tue Jan 12, 2021 2:08 pm    Post subject: Re: starting rpm? Reply with quote
pull it behind a truck and with the clutch out and key on run. watch the speedo and back calculate the rpms from tire size and ratios.
I've pushed started a bunch of cars, it doesn't take much.
4inBhore
50 Split - 2724cc NA. Haltech injected
62 Notchback - 2542cc Turbo WIP
buguy
buguy is offline
PostPosted: Tue Jan 12, 2021 4:00 pm    Post subject: Re: starting rpm? Reply with quote
Agreed. It doesn't take much. I just know mine logs around 250 rpm on the starter. I'm pretty sure when i had the 1200cc i could have spun the tire by hand and it would have started.
Pruneman99
Pruneman99 is offline
PostPosted: Tue Jan 12, 2021 4:07 pm    Post subject: Re: starting rpm? Reply with quote
Shocked
Why was the ignition on while doing a valve adjustment?
oprn
oprn is offline
PostPosted: Tue Jan 12, 2021 4:35 pm    Post subject: Re: starting rpm? Reply with quote
Pruneman99 wrote:
Shocked
Brain fart. Embarassed
Pruneman99
PostPosted: Tue Jan 12, 2021 4:37 pm    Post subject: Re: starting rpm? Reply with quote
Lol. It happens. Must have scared the bejesus out of you.
chrisflstf
PostPosted: Tue Jan 12, 2021 5:11 pm    Post subject: Re: starting rpm? Reply with quote
The starting rpm, being when consecutive plugs fire without stopping, cannot be any faster than the rpm that the starter can spin the motor. It may be some less. Most good motors will start within 1 or 2 revs.
Floating VW
Floating VW is offline
PostPosted: Tue Jan 12, 2021 5:27 pm    Post subject: Re: starting rpm? Reply with quote
If you have good compression, a proper air/fuel ratio in at least one cylinder and the right ignition system, I'm guessing the lowest RPM you need to start the engine is . . . 1.
"It's time you started treating people as individuals, rather than mathematically predictable members of an aggregate set, regardless of how well that works."
Iowa Mark
Iowa Mark is offline
PostPosted: Tue Jan 12, 2021 6:26 pm    Post subject: Re: starting rpm? Reply with quote
I agree. Old John Deere 2 cylinder engine. Using the exposed flywheel, bring the engine up on compression , turn the key on , adjust the choke and pull the flywheel through TDC. PoP! and we are running. One quarter turn.
buguy
buguy is offline
PostPosted: Tue Jan 12, 2021 6:37 pm    Post subject: Re: starting rpm? Reply with quote
The best starting mine has ever been was with the silly turbo, mechanical secondary 450 cfm 4 barrel drawthrough.
cbeck
cbeck is offline
PostPosted: Tue Jan 12, 2021 7:51 pm    Post subject: Re: starting rpm? Reply with quote
How fast can you hand crank a model t?
My cut in half and rebuild thread
www.thesamba.com/vw/forum/viewtopic.php?t=647779
Rome
Rome is offline
PostPosted: Tue Jan 12, 2021 9:04 pm    Post subject: Re: starting rpm? Reply with quote
VW provided a hole in the Beetle's rear apron and a support on the rear bumper for a hand crank thru 1948. Discontinued as of the '49's per VWoA's "What year is it" brochure.
A local friend had a '57 (?) single-cab pickup on which he rebuilt the 36 hp engine to factory tolerances. He demonstrated starting the engine using a hand crank. It only took maybe 1/3 to 1/2 turn of the crank, though a hefty turn. This was his yellow pickup in the background of Stock Steve's photo at the Orangeburg, New York Vintage VW Club of America meet in spring 1991. George is wearing the blue cap by the white awning, selling parts.
madmike
madmike is offline
PostPosted: Wed Jan 13, 2021 5:06 am    Post subject: Re: starting rpm? Reply with quote
Iowa Mark,,I had a 1939 B 'Poppin Johnny' hurt my back stating it 'hot ,,fired right up cold,lol
'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
"If I'm ever on Life Support,UNPLUG Me, Then Plug me back In see if that Works"
oprn
oprn is offline
PostPosted: Wed Jan 13, 2021 5:27 am    Post subject: Re: starting rpm? Reply with quote
I was going to mention tractors and aircraft starting by hand too but that is a bit different as they have magnetos that have a hand crank timing delay mechanism that snaps quickly to to give a good hot spark no matter how slow you turn them over.
The OP is not off the mark too far actually as I have noticed that to modern cars with their electronic ignition do require a higher starting speed and more turns before they will fire. None of the modern cars I have owned or driven start on the first or second compression like the old STOCK VWs used to. They all seem to have to make a dozen or so rounds before they go.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Wed Jan 13, 2021 5:31 am    Post subject: Re: starting rpm? Reply with quote
Ever seen a Split started with a hand crank?
So i'd say 1 rpm can do it.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
