Soft top frame pivot bushings
av8shunmeckaneck
av8shunmeckaneck is offline
PostPosted: Tue Jan 12, 2021 3:36 am    Post subject: Soft top frame pivot bushings Reply with quote
I've had this idea for a long time to have a bushing that keeps the hoop and the rest of the frame together during top removal. Not sure if any body makes something like this already. Didn't see one on TTS.
Enjoy.
Last edited by av8shunmeckaneck on Tue Jan 12, 2021 10:09 pm; edited 1 time in total
Joe 20
Joe 20 is offline
PostPosted: Tue Jan 12, 2021 8:14 pm    Post subject: Re: Soft top frame pivot bushings Reply with quote
Question I don't know if I understand what you are talking about but mine doesn't come apart. The parts are supposed to stay together aren't they? It is a real nice piece you made I guess to replace the "factory" piece?
"Someday the world is gonna be populated by nothing but Volkswagens'" Corporal Klairvoy
74 Thing
74 Thing is offline
PostPosted: Tue Jan 12, 2021 8:28 pm    Post subject: Re: Soft top frame pivot bushings Reply with quote
Pivot Pin?
https://www.thethingshop.com/TOP-FRAME-PIVOT-PIN/productinfo/181871PIN/
av8shunmeckaneck
PostPosted: Tue Jan 12, 2021 10:17 pm    Post subject: Re: Soft top frame pivot bushings Reply with quote
My pins just behind the rear doors are spot welded to the tab. Are they supposed to be welded to the frame? I could see if they were welded to the main portion of the top frame, pointing inward, the tension of the hoop could hold it on the pins.
el_safari
el_safari is offline
PostPosted: Wed Jan 13, 2021 5:48 am    Post subject: Re: Soft top frame pivot bushings Reply with quote
Enjoy.
Hi Great idea!
Did you make your own?
Quite often the parts of the top frame are bent and it will be then easy to work on them Cool
La terre n'est qu'un seul pays
Dougster43
Dougster43 is offline
PostPosted: Wed Jan 13, 2021 1:07 pm    Post subject: Re: Soft top frame pivot bushings Reply with quote
My pivot pins were spot welded in as well. I had to use a cutoff wheel to remove them. I then drilled a few small holes in back of the replacement pins (in the flat back part) for welding them back on.
kenj06
kenj06 is offline
PostPosted: Wed Jan 13, 2021 6:00 pm    Post subject: Re: Soft top frame pivot bushings Reply with quote
interesting idea. Never really paid attention but I have bolts on mine, no pin.
I haven't removed the top that often but may start when I have the hardtop ready to go.
av8shunmeckaneck
PostPosted: Wed Jan 13, 2021 11:05 pm    Post subject: Re: Soft top frame pivot bushings Reply with quote
el_safari wrote:
Hi Great idea!
Quite often the parts of the top frame are bent and it will be then easy to work on them Cool[/quote]
Yes, I made these myself.
-kenj06,
I too don't take the top off very often, but when I do, its a massive pain with the hoop flopping about. Its usually to transport plywood or long/large items.
P.S.< Last night I put the top back on myself and it wasn't too bad.
Rev. Scott
Rev. Scott is offline
PostPosted: Fri Jan 15, 2021 12:24 pm    Post subject: Re: Soft top frame pivot bushings Reply with quote
How much extra exertion do you have to apply to "stretch" the frame over the pins? The frame is already prone to bends and weaknesses (cracking). I like the design. Also, do you have to drill out the frame to accept the new bushing (adding further weakness)? When I remove my top (cue the innuendos), I put a "zip tie" to keep the frame parts from going all dangerously floppy. A little R&D and some QC field testing...I'm following...
"I haven't seen one of those since I was shootin' at 'em!"
THINGONER
THINGONER is offline
PostPosted: Mon Jan 18, 2021 11:07 pm    Post subject: Re: Soft top frame pivot bushings Reply with quote
Nice! I like it
av8shunmeckaneck
PostPosted: Fri Jan 29, 2021 10:09 pm    Post subject: Re: Soft top frame pivot bushings Reply with quote
Nothing extraneous to expand the frame over the pins. My frame sits on the pins without squeezing them or trying to spread open.
Still not clear if the pins are supposed to be welded in or not but in any case it works better to have them welded in.
BNMike
BNMike is offline
PostPosted: Sun Jan 31, 2021 7:44 am    Post subject: Re: Soft top frame pivot bushings Reply with quote
My top attachment pins are welded on, and as I recall they were permanent on the '73 that I had new.
BNMike
